Old 11-26-2014, 08:58 AM   #1009
pleong
Drives: 2013 Whiteout FR-S
Meaty Tire Thread
I have 18x10 +40 ZE40s and running 285/30/18 tires -2 camber up front and -2.5 camber in the rear.. Running KWV3 coilovers, whiteline adjustable toe arms, camber bolts and LCAs, HVT Camber Plates
I just lowered the car back down last night after installing the stoptechs.. So the springs haven't settled in yet, but the rears poke out like crazy..
As far as tire to spring clearance it seems to be ok, until I put some load on it.. Wanted to ask before I hit the road and cause some damage to my wheels and/or springs...
Anyone have any rubbing issues? @Jive Turkey @OmarGC @AutoRnD
Passenger rear
Passenger front
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 11-26-2014, 03:06 PM   #1010
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Man that is a lot of rear poke, mine are no where near that and I'm currently -1.7ish out back.
As far as rubbing I personally have no issues, but am also only on 265/35's both front and rear. I cant recall the username at the moment but there is someone rubbing under full lock up front on the inner brake line bracket/mount...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 11-26-2014, 05:54 PM   #1011
s2d4
s2d4's Avatar
Rear camber doesn't look like -2.5 if front was -2.
Front should always poke more on a square setup as the back has extra ~10-15mm.
Old 11-27-2014, 10:34 PM   #1012
fstlane
fstlane's Avatar
Drives: BRZ Limited
Something meaty for Thanksgiving!
255/40/17 R-S3s, 17x9+42 Rota Titans, front 10mm spacers, RCE Yellow springs, -1.8° rear and -3.1° front camber.
fstlane is offline   Reply With Quote
The Following 3 Users Say Thank You to fstlane For This Useful Post:
Jive Turkey (11-28-2014), nlamon33 (11-27-2014), sprintertrueno86 (11-28-2014)
Old 11-30-2014, 02:22 PM   #1013
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Check out our new Drag86 wheel package!
Pure Automotive is offline   Reply With Quote
The Following 7 Users Say Thank You to Pure Automotive For This Useful Post:
Flow (11-30-2014), Koa (12-24-2014), Lorico (03-24-2016), Norville Rogers (08-28-2016), OmarGC (11-30-2014), texasbound972 (12-21-2014), ultra (01-10-2015)
Old 11-30-2014, 02:46 PM   #1014
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
More pics. Still need something better to take pictures with
The Following 5 Users Say Thank You to TylerLieberman For This Useful Post:
boucher (12-07-2014), Guff (11-30-2014), MisterSheep (11-12-2015), OmarGC (11-30-2014), Xuningshen (12-11-2014)
Old 11-30-2014, 02:52 PM   #1015
pleong
I just checked, I don't have any issues rubbing on the brake line braket/mount
I think you're right.. I'll probably need to get an alignment again.. I did corner balance the car and the rear raised up a lot when I did it.. Thanks for the reminder!
Old 11-30-2014, 05:06 PM   #1016
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Looking good Tyler. I been on the fence with getting these fenders and last night I seen a pic of a swp FRS with them and it had me sold. Now I'm torn again... This is the first pic that I've seen that shows a good angle of the differences in front and rear track. As much as it would benefit with an steering angle kit and sliding, I'm not sure if I could live without bringing the rear out.
Thank you for making me struggle again :'(
Omar GC
Instagram: 2jzus
Old 11-30-2014, 05:26 PM   #1017
TylerLieberman
Drives: '24 GR86
Lol thanks.
The front is about the same as the rear now as far as width goes. Think of it like an s14 running stock rear quarters and origin 20mm fronts.
Old 12-08-2014, 01:39 PM   #1018
SavEvoIX
Drives: Evolution IX, 13' FR-S White Out
I just purchased some Enkei RS05-RR 18x9.5 +43 square wheels for my wife's FRS. She has TRD springs. What is the max width I can go with before I hit the spring perch?
SavEvoIX is offline   Reply With Quote
Old 12-08-2014, 06:00 PM   #1019
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
probably a 245, you sure those will clear as is without spacers up front?
Jive Turkey is offline   Reply With Quote
Old 12-08-2014, 06:09 PM   #1020
TylerLieberman
Drives: '24 GR86
Yeah, as Jive said. You NEED a slip on spacer up front to clear the perch with that wheel. I know people here have run it without and it rubs.
I think a 3mm slip on is what people are using.
Old 12-08-2014, 07:17 PM   #1021
SavEvoIX
Not sure from what I've found everybody that has these has Coilovers not springs. So even going from a 245/40 or 255/35 should be the same then?
Old 12-08-2014, 08:34 PM   #1022
Jive Turkey
the tuna, no crust.
you won't fit a 255. hell some meaty 245's won't even fit.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
