Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 11-19-2014, 06:20 PM   #827
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Got in contact with Dave from Headgames and he is going to send me the assortment of lash caps. We measured the lash ourselves and will be doing this in house to help speed up the process.
PrimeMotoring is offline   Reply With Quote
The Following 4 Users Say Thank You to PrimeMotoring For This Useful Post:
Creole (02-05-2015), Frs300 (11-19-2014), Luckrider (11-19-2014), Sportsguy83 (12-03-2014)
Old 11-24-2014, 11:31 AM   #828
PrimeMotoring
So i was able to get measurements for every single lash cap available from Subaru directly. They sell the caps individually by size varying every .001 of an inch. Ill post pics later today of the list. We measure each lash and pick a cap. Tedious but will be worth it in the end.
The Following 3 Users Say Thank You to PrimeMotoring For This Useful Post:
Frs300 (11-25-2014), MooseWRX (11-24-2014), Sportsguy83 (12-03-2014)
Old 11-24-2014, 09:40 PM   #829
Frs300
Frs300's Avatar
Drives: Pile of junk
so you need to measure all of them then order the caps? watch shit be out of stock lol
Frs300 is offline   Reply With Quote
Old 11-24-2014, 11:32 PM   #830
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I doubt they'd be out of stock. It's standard practice when rebuilding an engine to measure and buy appropriately.
slicktop is offline   Reply With Quote
Old 11-25-2014, 08:29 AM   #831
Frs300
Frs300's Avatar
I know im just being a smart ass about my luck
Old 11-26-2014, 11:16 AM   #832
PrimeMotoring
Nope, theyll be here Tuesday lol
The Following 2 Users Say Thank You to PrimeMotoring For This Useful Post:
Frs300 (11-26-2014), Sportsguy83 (12-03-2014)
Old 11-26-2014, 12:06 PM   #833
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Guaranteed there will be something wrong. Box/invoice will say .002" and the part will be a .200" or something.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Frs300 (11-26-2014)
Old 11-26-2014, 08:47 PM   #834
Frs300
Frs300's Avatar
and back together wednesday right lmao :P
Old 11-28-2014, 11:02 AM   #835
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Next Friday bro.
Old 11-28-2014, 11:07 AM   #836
PrimeMotoring
In your own mind yes. Then you can tell @King Tut and he'll send a mass email out to everyone that I promised you Wednesday lol
Old 11-28-2014, 12:45 PM   #837
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
Damn this car still isn't fixed? @Frs300 probably has the worse luck than anyone else on here.
Touge_ninja is offline   Reply With Quote
Old 11-28-2014, 12:49 PM   #838
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I only go off what Brandon tells me. I just want him to have his car back ASAP with a reliable engine. I don't do mass e-mails.
Old 11-28-2014, 01:23 PM   #839
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Never noticed this thread was moved here, I only assumed it was closed. Here is an update for everyone.
First off I wanted to mention because some people like to give this project a time frame. We had agreed with @Frs300 to bring the car to us to tighten up some loose ends, tune the car and give him back a 100 percent perfect vehicle to enjoy. Since FRS300 had been royally screwed over time and time again and he being in the military, we along with Junior agreed to do the labor and tuning 100% FREE of charge. Any parts needed would be covered by FRS300 at our cost.
Car arrived and notice a nasty tick coming from the head plus the car smoking quite heavily. We pull the motor and discover, other than the missing/stolen parts, that the one cylinder head was not torqued down whatsoever and some head studs were hand tightened. This led to the cylinder head lifting and coolant mixing with engine oil. This caused heavy scoring throughout the cam journals, cylinder walls, rod and main bearings, crankshaft etc. The motor needed a complete overhaul. Heads were sent out to Headgames to repair and set the lash properly which due to the high volume of work they do, we only received the heads back recently. The block is at the machine shop also being honed, cleaned and pressure tested. New piston rings were ordered from CP which have taken an eternity and still waiting to come in. Rod and main bearings are here.
I maintain communication with FRS every single day via text or facebook PM. Unfortunately for him though is that we was dismissed from the military 6 months too soon and we both agreed to hold off on the project for some time since the cost of parts would have been too much for him to bare until he was able to find a job and get priorities straight. Luckily everything is looking up for him and we are currently only waiting on piston rings to resume reassembling his motor and getting his car out to him. He was able to send me a clutch disk to replace his old one that was "misplaced" by Toni.
P&L Motorsports was also kind enough to send him one of their kits because he was so turned off with the FA20club offering. We will be using the PTE 6266 with the P&L kit and also adding a Flex Fuel kit, ARP Head Studs (toni reused the originals), Full Blown Oil Cooler, FBM Fuel Pump Kit and Mishimoto Radiator to the mix.
Good on you guys. That's heartwarming. Respect.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Marchy (01-03-2015)
Old 12-07-2014, 11:27 PM   #840
PrimeMotoring
So do we all, dont understand the need for the same constant comments.
As for updates, these showed up this past week
Lash is set now and the long block is back together. Just need to assemble accessories and drop the motor in before break in and eventual tune. Fingers crossed there are no more snags in the road.
The Following 5 Users Say Thank You to PrimeMotoring For This Useful Post:
Bach415 (12-09-2014), Reaper (12-08-2014), SkAsphalt (12-08-2014), slicktop (12-08-2014), Sportsguy83 (12-09-2014)
ban lexusb3, dude where's my clutch!!, fa20club, fa20crap, fashitstorm, goodguyprime, happy ending, i am sofa king we todd it, lexusb3 is toni, looks good!, shithappenscontinuously, stolen skid plates., toni, toniiswhack, unbelievable!
new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series RavSpec Wheels and Tires 8 06-15-2014 10:07 AM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
NEW Work Wheels Inside! JDMenrique FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 04-08-2013 03:13 AM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
