| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: '13 Firestorm FRS
18x9.5 tires for Seattle weather (damp)
Hi all,
I just purchased a set of Advan GT's in 18x9.5 +40. Do you guys have any recommendations for tires to fit the car? The car is often driven in a spirited matter on backroads. The weather in Seattle is a mix of showers and dry, so the roads vary between dry and damp, and sometimes they are completely wet though this isn't that often. Please note that the car isn't driven in heavy rain/snow. My budget is $1000 or less. I was thinking Yokohama ADVAN Sport V105 in 255/35/18 or 245/40/18. I'm also not worried about the life of the tire. Any suggestions? Thanks |
| The Following User Says Thank You to sittinSideways For This Useful Post: | NWFRS (11-23-2014) |
#2 |
Drives: Raven FR-S 6M
Continental Extreme DW. Really good in wet pretty good in dry.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | sittinSideways (11-25-2014) |
#3 |
Drives: 2013 DGM BRZ
Continental Extreme DW may not be quite as aggressive as you'd like in the wet and dry and they tend to have soft sidewalls which gives up quite a bit of the FRS steeling feel that we all love.
I'd suggest Michelin Pilot Super Sports. They're one of the best road tires in both dry and wet, affordable, and even though you don't care, are a ~40,000 mile tire. I've put about 30k on mine so far including a couple track days and some skidpad time. These truly have the best handling of any street tire I've used and the wet traction is incredible. Here's a bit of testing compared to both the V105 and Conti DW. http://www.tirerack.com/tires/tests/...y.jsp?ttid=174 http://www.tirerack.com/tires/tests/...y.jsp?ttid=148 Additionally I'd suggest the 255/35 over the 245/40. The 245/40 is nearly 5% taller than OEM tires which effectively gears your car higher(Slower off the line) and pushes the rotational weight of your tire further out. Last edited by Akari; 11-22-2014 at 01:58 AM. |
| The Following User Says Thank You to Akari For This Useful Post: | sittinSideways (11-25-2014) |
#4 |
Drives: 13 FRS Satin
Depends on what low temperatures you get in your area. If the temperature doesn't drop below -10ish, you make be able to get away with using a non winter tire. If it does but no snow, you'll probably want to consider a winter performance tire. (Just a consideration)
#5 | |
| The Following 2 Users Say Thank You to Akari For This Useful Post: | DAEMANO (11-23-2014), Xero-Limit (11-22-2014) |
#6 |
Engineering Student
Drives: Scion FR-S 2015
255/35/18 is better for you. 245 there will be stretching... I would say stick with Extreme contact or Ventus v12 unless the rs3 is less than 1k.
#7 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
| The Following User Says Thank You to Xero-Limit For This Useful Post: | sittinSideways (11-25-2014) |
#8 |
Member of the year - 2016
Drives: Scion FRS
The person wants tires for wet weather, yet wants to run 245/255's.
Huh...
#9 | |
I haven't tried the Pilot Sports yet, don't they need to be properly warmed up? Or they good at pretty much all temps? |
#10 | |
#11 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Why not fit your stock wheels with winter tires. Put the appropriate tires on those Advan GT's for summer. Why spend $3k on wheels and skimp on tires? The tires are where you make everything come together.
| FS: Winter Tires and Weather-tech Mats | harkbrz | Canada Classifieds | 13 | 01-29-2015 07:01 PM |
| Winter Tires Seattle/Vancouver area | rixter145 | Northwest | 9 | 10-06-2014 02:48 AM |
| Damp rid, condensation and moisture | radroach | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 08-27-2014 11:21 PM |
| Tires for cool/cold weather (not snow) | Khyron686 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-13-2014 12:04 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
