CANADA Canada
Old 11-20-2014, 09:48 AM   #7029
Chico
Drives: '14 BRZ WRB
Originally Posted by Simon99 View Post
Comment on it i'm almost 100% sure of switching. My 19 yo self can't justify paying 700$ a month for a car i'm not driving 5 months a year, sadly...
It's a fun car but I found it was a jack of all trades, master of none. Overkill for daily driving to work and back...to have any fun you need to be well above the posted speed limits and it wasn't the greatest track car; heavy so brakes/tires get expensive and the awd means there's not much driver involvement if that makes sense. Just mash the throttle and the diffs sort it out. Good wakeup call when you move to a light, rwd track car! Gas gets expensive too. If I was to go back to a hatch I'd probably consider the GTi, Focus ST or Fiesta ST. Awd was a blast in the winter but it's not necessary.
I tend to agree what everyone else is saying. Keep the BRZ and drive it all year. Good winter tires and you're good to go.
Chico is offline   Reply With Quote
The Following 3 Users Say Thank You to Chico For This Useful Post:
jhx741 (11-20-2014), KingGeo (11-20-2014), normancw (11-20-2014)
Old 11-20-2014, 06:06 PM   #7030
Mgb_bj70
Drives: 2013 fr-s
Add my 2 cents, from an economics point of view, the depreciation is a sunk cost... If you can swing it - drive it in winter! If you live in the country, It would be interesting to test hakkas with studs and a couple of bags of sand. I can report back next year on that set up as that´s my plan.
Good luck with your decision. Michel
Mgb_bj70 is offline   Reply With Quote
Old 11-20-2014, 06:56 PM   #7031
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Anybody know of some good black friday sales? (car related)
Simon, I'd say just drive it. Get good snow tires and you'll be ok.
What do you think farmers did 60 years ago without 4x4 and bias ply tires? lol
The only reason mine is away is because it's my first new car and I'd like the underneat to be oil free when I start modding. Don't forget that something like an EVO is actually going to cost you more money in the long run
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 11-20-2014, 09:50 PM   #7032
HeadBanger
HeadBanger's Avatar
Any wheel aficionados here?
I want some 17x9 +30. But they're 5x114.3
Obviously I'll need conversion spacers, but I don't want to get screwed and buy the spacers and wheels and it not fit
The Following User Says Thank You to HeadBanger For This Useful Post:
OrangeGuitar (11-21-2014)
Old 11-20-2014, 09:55 PM   #7033
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
You'd need adapters so add 20mm at least, which means your wheels will have an effective offset of +10 or lower.
Won't fit or it will look like this:
Slick is offline   Reply With Quote
The Following 2 Users Say Thank You to Slick For This Useful Post:
86gt? (11-21-2014), FRS_Ken (11-21-2014)
Old 11-20-2014, 10:02 PM   #7034
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Get small converting spacers and you should be fine. I think the smallest you can find is 15? or 11mm? Not sure.
You're gonna poke out about an extra 6 cm, compared to stock. (If you go with 15mm spacers)
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 11-20-2014, 10:19 PM   #7035
HeadBanger
HeadBanger's Avatar
FT86 SpeedFactory has 15mm spacers.
How do I figure out the camber that I need? I've seen photos of our cars running these exact wheels, so I know it's possible. I just don't want to be running camber that will give uneven wear, or make the car not perform as well. These are pretty much my favourite wheels ever and I really want them
Old 11-21-2014, 07:25 AM   #7036
jvincent
jvincent's Avatar
The wheel section has a link to a graphical fitment guide that is pretty good.
A +30 with spacers is going to look bad though.
Old 11-21-2014, 08:16 AM   #7037
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
I saw a B16 Sentra that looked exactly like this on the 417 earlier in the week. Not sure now it made it through Quebec Hellaflush laws.
pushrod is offline   Reply With Quote
Old 11-21-2014, 09:34 AM   #7038
Slick
Slick's Avatar
Factory wheels are 17x7 +48.
Same size wheel in a +15 (assuming 15mm spacers) is going to move whole wheel out by 33mm.
Add 2 inches width to that wheel adds 25mm to each side of the wheel.
So the outside will now be 58mm further out (6cm like AznKirby said), while the inside will be only 10mm further out.
Only the hella-stanced guys are running those kinds of offsets, with lots of camber to pull in the top of the wheel.
For reference, my wheels are 18x9 +35, so a 17x9 +15 will poke out 2cm more. Its gonna rub the fenders.
FRSToyota86 (11-21-2014), FRS_Ken (11-21-2014)
Old 11-21-2014, 03:58 PM   #7039
jvincent
jvincent's Avatar
I love me a good Canadian Tire sale.
My preferred oil is 45% off this week instead of the usual 30-35%.
Just picked up 5x5l jugs. All set for next season.
Old 11-21-2014, 05:40 PM   #7040
normancw
normancw's Avatar
Drives: 128i
What oil do you use?
normancw is offline   Reply With Quote
Old 11-21-2014, 06:14 PM   #7041
pushrod
Benched 86lb
pushrod's Avatar
Doesn't matter, he just bought it all
The Following 5 Users Say Thank You to pushrod For This Useful Post:
86gt? (11-21-2014), jvincent (11-21-2014), normancw (11-21-2014), OrangeGuitar (11-21-2014), Pbrown (11-21-2014)
Old 11-21-2014, 07:57 PM   #7042
jvincent
jvincent's Avatar
Quaker State Ultimate Durability 0W20.
I spent a bunch of time on bobistheoil guy and reading spec sheets for different oils and it's got a good rep and numbers.
The Following User Says Thank You to jvincent For This Useful Post:
