11-17-2014, 04:34 PM | #5615 |
AutoX-10/10ths every run
As of yesterday evening. Put the blower on at 34.4K. Still running great.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following 7 Users Say Thank You to whataboutbob For This Useful Post: | Lawnik (11-18-2014), MINOCIN (11-17-2014), OICU812 (11-17-2014), sato (11-17-2014), SprintexUSA (11-17-2014), The Racers Line (11-18-2014), Xero-Limit (11-20-2014) |
11-17-2014, 06:27 PM | #5616 | |
That Guy
Drives: 2013 asphalt FRS MT
11-17-2014, 06:51 PM | #5617 |
Drives: 2014 FT86
Agreed. 91 octane is definitely asking for it. The right fuel lets you get away with soooo much!
11-17-2014, 07:09 PM | #5618 | |
Just a dude
Drives: Scion FR-S 2013
Fair enough, is the 210+ a 2015 release, any eta?
11-18-2014, 12:05 AM | #5619 | |
I have two questions regarding this: 1)Does this increase that volumetric efficiency at all supercharger speeds, or more so at higher rpm? 2)Does the adiabatic efficiency improve at all rotor speeds and pressure ratios as well (especially lower pressure ratios)? If I am interested in a low power installation, either the 210 with the 75mm pulley or the 210+ and the same pulley, would I see any difference between the two? Could I get away without an intercooler easier with the 210+ as compared to the 210? |
The Following User Says Thank You to R2 For This Useful Post: | Calum (11-18-2014) |
11-18-2014, 05:42 AM | #5620 | |
That Guy
11-18-2014, 01:12 PM | #5621 | |
Drives: 2014 FT86
The volumetric and adiabatic efficiencies both increase at all RPMs. You would see the power increase on a non-intercooled application using the same pulley. You would be less pressed to use an intercooler or smaller pulley, but the gains would still be there. This leads me full circle back to the 10% I was talking about. The coating just goes after that last bit of efficiency left on the table inside the current unit. |
The Following 2 Users Say Thank You to SprintexUSA For This Useful Post: | 86 South Africa (10-25-2017), Lawnik (11-18-2014) |
11-18-2014, 02:08 PM | #5622 | |
Sounds good, thanks for the response. I'm a fan of maximizing things to the full extent possible. Now, I have one final question: With this new coating, are there any clearance or reliability issues when used in very cold environments? I'm thinking of condensation that freezes inside the rotor housing and turns into a layer of frost. This frost would likely be thin but would certainly be greater than the clearances. Would this be an issue for this new coating, or even the standard 210 without the coating? |
11-18-2014, 03:13 PM | #5623 |
Drives: 2014 FT86
Morning frost or overnight freezing has never been an issue with rotor clearances. A bead of water or sheet of paper is actually thicker than the clearances inside the unit.
Frost from heavy nitrous use might cause an icing issue, but that's a big "IF". I wouldn't run a wet nitrous system on this since the intercooler is in the way. Low oil levels in winter are something to watch out for. As long as the gears can reach the oil bath, you're in good shape. |
The Following 2 Users Say Thank You to SprintexUSA For This Useful Post: | 86 South Africa (10-25-2017), R2 (11-18-2014) |
11-18-2014, 03:54 PM | #5624 | |
That Guy
11-19-2014, 02:00 PM | #5625 |
Drives: 2014 WRB BRZ
What MAP sensor are you guys running, or how are you reading your boost pressure? I have a ScanGauge II reading from the ODBII port right now, but I think it tops out at like 5 psi. I remember hearing of problems with other MAP sensors, but haven't had chance to read this whole thread.
11-19-2014, 03:24 PM | #5626 | |
Drives: UK GT86
I just run the OEM sensor. There's no need for a larger sensor unless you want to use an OBD based gauge, but you don't really need to know boost on a SC as you can't over boost, or if you want to run SD.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | CarzCarzCarz (11-20-2014) |
11-19-2014, 07:33 PM | #5627 | |
Super 86
Drives: Red 86 GTS
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
The Following 2 Users Say Thank You to Khorne For This Useful Post: | CarzCarzCarz (11-20-2014), jflogerzi (11-20-2014) |
11-19-2014, 09:27 PM | #5628 |
Drives: GT 86
Where did you get that gauge pod from mate
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
