Old 11-14-2014, 09:58 PM   #1289
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Mechazawa View Post
I have done it several times. Works great. The bead need not be continuous ether. I usually do three evenly spaced beads about 1 inch long each.
Thanks, I'll see what my welder says about it.
He also suggested welding a v-band on it and fab a custom stainless pipe to the airbox. But I think that's gonna be quite pricey and too much trouble.
Fizz is offline   Reply With Quote
Old 11-18-2014, 05:59 PM   #1290
Astroboy
Astroboy's Avatar
Drives: None
Where is your vacuum at when idling. Mine use to range in 19, and now it's around 20. Could it be Because of the bypass valve I installed
Also, what afr is everyone seeing in wot and about 70-80% throttle?
Astroboy is offline   Reply With Quote
Old 11-18-2014, 08:39 PM   #1291
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Firstly are you running an aftermarket wideband sensor and gauge? They would normally give more accurate readings than the stock sensor. And a reading taken on the dyno using the tailpipe probe will be slightly different again.
So basically someone's AFR reading using a proper wideband may differ from yours if you're on a stock sensor....and any comparisons would have to be taken with a grain of salt.
Old 11-19-2014, 12:17 AM   #1292
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
I've been using the android torque. My afr is 14.65-14.7 during idle. And during wot it is around the 12s so idk.
Old 11-19-2014, 08:36 AM   #1293
GremlinGSP
One issue I've had with the pipe from the airbox to the turbo is it is very picky about placement. I have the Perrin intake and it wants to push the pipe into the pulleys. I've got it pulled towards the front of the car with zip ties for the moment.
I would love to see an option or fab for metal piping instead of the silicon right there in the bay. Or at least a bead on the turbo to help keep that pipe on.
Wonder how much that would cost to fab.
GremlinGSP is offline   Reply With Quote
Old 11-19-2014, 01:29 PM   #1294
Astroboy
Astroboy's Avatar
Drives: None
That's what I did to my car with zip ties aswell
Old 11-20-2014, 11:26 PM   #1295
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Could someone please tell me the ID and OD for the turbo coolant hoses?
Old 11-21-2014, 05:22 PM   #1296
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
The coolant hoses are a 5/16" (ID) hose. The hoses shipped with the kit are around 9/16" OD.
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Fizz (11-21-2014)
Old 11-23-2014, 08:21 AM   #1297
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
So what's your status? Are you still gathering "intelligence" or installing the parts?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 11-23-2014, 09:25 AM   #1298
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Kit should arrive soon, but won't have time to install till mid December when I get some time off work.
So at this stage I'm trying to gather as much intel on various install tips/tricks and just trying to learn from other peoples experiences.
Old 11-23-2014, 06:01 PM   #1299
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Originally Posted by protpibe View Post
I think the stock 2.5" is just a slotted flange, and I agree that it was a giant pain in the ass.
@protpibe; did you have any issues with exhaust fumes getting into the passenger cabin? I'm not hearing an exhaust leak (or at least I think I don't) but I'm growing tired of smelling non-catalyzed exhaust in the passenger compartment.
I'm suspecting this flange to flange seam. I'm going to put the car in the air soon
Old 11-23-2014, 07:18 PM   #1300
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
I got an AVO oil cooler
I've had the AVO stage 1 for a year with oil temp up to 240F and water temp up to 200F. After the oil cooler, oil temp up to 200 and water temp up to 195.
I got the anti tramp differential bushing. Power seems to be more instantaneous. Guess it works and it was easy to install.
andrewFT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrewFT86 For This Useful Post:
MFB (11-26-2014), mwjcyber (11-24-2014)
Old 11-23-2014, 08:53 PM   #1301
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Do you still have a catted front pipe?
You might want to try squirting some soapy water (dishwashing liquid works best) onto the flanges and see if they bubble.
The Following User Says Thank You to Fizz For This Useful Post:
@Art_Mighty (11-24-2014)
Old 11-24-2014, 09:16 AM   #1302
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Actually, I did. As long as that flange isn't sealed 100%, you'll smell it.
LIke someone else suggested, spray some soapy water on the flange seam. Make sure you do it when the car is cold, and have someone assist you because you won't have much time. Once it's hot/warm, it will just evaporate.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
