Old 11-17-2014, 05:32 PM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Question Slow Acceleration with Low RPM Launch
When I launch (dump the clutch) at around 1000 rpm from a standstill it takes about a second of "pedal to the medal" before the car gives any significant amount of acceleration (maybe 2mph/second). Is this because it's just running at very low rpms, or is it something more? Do I have a "Dead pedal" and need to reset the ECU by pushing the gas pedal up and down 20 times (method explained here http://www.ft86club.com/forums/showthread.php?t=39480)?
Is this normal? I'm currently running 91 octane from Costco. It was significantly worse when I was using 87 octane for 3 or so tanks in a row for reasons already explained in other discussions.
carma143 is offline   Reply With Quote
Old 11-17-2014, 06:39 PM   #2
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Is this a serious question? Because taking off at 1k rpm is too low, let alone "launching"
blue cat is offline   Reply With Quote
Old 11-17-2014, 06:42 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Dumping the clutch from idle speed won't really get you anywhere very fast, lol.
Stang70Fastback is offline   Reply With Quote
Old 11-17-2014, 07:02 PM   #4
Akari
Drives: 2013 DGM BRZ
I'm not really sure what more you're expecting out of a 2.0L NA engine at idle speed. Our engines love to rev!
Akari is offline   Reply With Quote
Old 11-17-2014, 07:17 PM   #5
xwd
I'm not sure how you even "dump the clutch" at 1000 RPM. I think I'd have to practice that. My diesel truck has pretty good acceleration at 1K RPM but then again it's a 7.3L engine and redlines at 3800 RPM.
The Following 2 Users Say Thank You to xwd For This Useful Post:
JohnJuan (11-17-2014), sato (11-19-2014)
Old 11-17-2014, 07:39 PM   #6
carma143
carma143's Avatar
"Is this because it's just running at very low rpms,"
You have answered my question. Thank you very much. When I said "launching" I meant accelerating from a standstill. I don't like the feeling of slowly letting off the clutch until about 6 mph when accelerating from a stop, like I normally do. I have tried revving to ~1250 rpm at a standstill and then quickly letting go of the clutch fully while pressing the gas pedal slightly more. This method typically results in a very slow acceleration, taking about 4 seconds to cross a one way street. If this is normal then I am fine with it.
The Following User Says Thank You to carma143 For This Useful Post:
Old 11-17-2014, 07:45 PM   #7
Stang70Fastback
A.K.A. Starlord
So what you're saying is, you don't like driving properly? Maybe you should have bought the automatic...
Seriously, how long is it taking you to feather the clutch? There is a difference between "dumping" the clutch like you describe (aka, just letting it go and slamming it into gear) and quickly feathering it. It's something that shouldn't take more than a full second once you're even somewhat adept at it.
If you're legitimately just popping the clutch all over the place then you will eventually break something, or piss off your passengers, who will wonder why you can't drive properly. If you are seriously so lazy that you can't even bother to properly feather the clutch, do both yourself and the car a favor and go trade it for an automatic. You'll both be much happier.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
fika84 (11-20-2014), JohnJuan (11-17-2014)
Old 11-17-2014, 08:20 PM   #8
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
you are not driving correctly. need to find someone to tutor your driving technique. and do not put 87 octane. although it is not going to have any immediate damage besides retarded timing (= more fuel consumption and less power and bunching of knocking) , but it just not right.
Speed2th is offline   Reply With Quote
Old 11-17-2014, 08:55 PM   #9
blue cat
blue cat's Avatar
It's not normal, how are you able to safely enter traffic if the car is accelerating so slowly? Rev it out more, try around 3k or so and feather out the clutch a bit longer, maybe a full 1-2 seconds. The longer feather is healthier than a quick slip at very low RPMs. If you still don't like revving it out try to roll on the throttle more as you release the clutch.
Old 11-17-2014, 08:55 PM   #10
carma143
carma143's Avatar
It's not as if I'm popping in the clutch every single time I drive (I see how my OP could sound as if that's the ONLY way I accelerate from a standstill). Normally I do feather the clutch, which results in a fairly smooth ride, not the jerky ride I was prone to create in the 2 weeks of learning.
I popped in the clutch to accelerate from a standstill several times, recorded the response of the car, and posted it online to ask if this was normal. When I had the 87 octane gas, the throttle would sometimes cut out when pushing the gas pedal all the way down even, myself believing this occurred because the computer detected a possible "knock".
I was testing if there were better ways to accelerate from a standstill than feathering the clutch, because it ever so slightly wears out several components.
Maybe it's me being overly sensitive, but it sounds like you already have some sort of grudge towards me.
Old 11-17-2014, 08:57 PM   #11
carma143
carma143's Avatar
This is what I do normally. My OP didn't reflect what I was trying to say.
Old 11-17-2014, 09:06 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your first post made it seem like you were launching the car from a standstill at 1k RPM, which is odd considering you'd just stall the car if you popped the clutch at that RPM.
There isn't enough torque at low RPMs in this engine to do what you want to do.
That, and your choice of words was very poor to convey your thoughts in the first post.
When launching a car like this, you need to slip the clutch a lot to maximize engine torque transfer to the wheels.
When accelerating, same concept. You shift at a RPM (usually close to redline) to maximize available torque.
-alex
Old 11-17-2014, 09:07 PM   #13
blue cat
blue cat's Avatar
No worries, if thats the case then it just sounds like your original post describes you under revving and stalling the engine.
Old 11-17-2014, 09:19 PM   #14
DeeezNuuuts83
Drives: 2006 Evo IX SE
Is this your first manual transmission car? It's a pretty easy car to get going from a standstill.
DeeezNuuuts83 is offline   Reply With Quote
dead pedal, octane, response, slow
FRS auto -slow acceleration at 70km/hr Zhangy Scion FR-S / Toyota 86 GT86 General Forum 9 11-12-2014 12:33 AM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 10:14 AM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 04:25 PM
Not disappointed but curious. Why BRZ's acceleration numbers are relatively slow? Wait4BRZ_STI? BRZ First-Gen (2012+) — General Topics 46 04-10-2012 10:46 PM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 06:56 PM
