Old 11-14-2014, 04:57 PM   #2171
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Also, isn't it true that the breather tube is mainly only filled under heavy throttle situations while the crankcase can is more commonly filled during for normal driving conditions?
When I bought the car, the previous owner just had the breather tube hanging, and I never had an issue with it until I had my first track day and I had oil all over the place under my hood.
blackfireball5 is offline   Reply With Quote
Old 11-14-2014, 05:00 PM   #2172
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
When it's first started and cold it's dumping water vapor out of that tube as it heats up and boil's the moisture into vapor, in your case into your intake and potentially condensing in the intercooler. Frequent shirt trips?
Old 11-14-2014, 05:03 PM   #2173
blackfireball5
Completely mixed. During the summer I would drive it to work and back everyday which is like at least a half hour. But if I got to a friends house and things it might be about 10-15 minuets. I would usually let the car warm up before taking off though.
What's a short trip? Like 5 minutes? 15?
Old 11-16-2014, 04:12 PM   #2174
blackfireball5
Is this the correct part I'd need?
https://www.subarupartsdepot.com/par...&siteid=215079
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 11-17-2014, 10:14 AM   #2175
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The problem is that even if that microfiber gets soaked, the filter is an oiled filter. There is no way it will let a significant amount of water in unless the filter is submerged in water. My advice would be to switch your Radium catch can to a vented setup and see if this problem goes away. That is really the only place I can see that much water getting in unless you have a serious boost leak and it is getting in through your intercooler piping somewhere.
Old 11-17-2014, 10:15 AM   #2176
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by blackfireball5 View Post
That appears to be a BRZ MAF sensor which might have been damaged when water went across the hot wire.
Old 11-17-2014, 01:03 PM   #2177
blackfireball5
That is the correct part I need though right?
Here is the Toyota one but I think they are the same:
http://toyotaparts.bochtoyotasouth.c...nsor&position=
And will I have problems with a vented catch cans with emissions, that was really the only reason I went with it. I posted about it a while back and no one seemed to be able to tell me if I'd have problems in Ohio with that.
I'd get a vented FBM can now if I was 100% certain I'd have no issues with emission testing.
Wheelwell Profile
Old 11-17-2014, 01:19 PM   #2178
dabocx
dabocx's Avatar
Drives: Scion FRS
How much have people made with the gtx2867 on e85?
dabocx is offline   Reply With Quote
Old 11-17-2014, 02:43 PM   #2179
blackfireball5
I contacted Radium and they said the catch can should catch any water vapor before it get's to the intake.
So with all of this information, here is my plan:
1. I'm going to wrap my air filter with one of those water repellent bags.
2. I will convert my PCV Radium catch can to vent to atmosphere using a small cone filter.
As far as i'm concerned, if I can do both things and they are both relatively cheap, why not.
So my PCV catch can would look something like this instead of recirculating back into the intake.
Old 11-17-2014, 03:07 PM   #2180
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would leave your filter alone. The emissions guy is probably not gonna like seeing a vent to atmosphere catch can when he pops your hood. With that being said, just remove it when you go in for emissions testing.
Old 11-17-2014, 03:32 PM   #2181
Reaper
Reaper's Avatar
Drives: violent
461 whp 393 wtq maxed out. Check my build thread the dyno should be in there.
Old 11-17-2014, 03:35 PM   #2182
blackfireball5
So you are saying I shouldn't worry about bagging my air filter, and go ahead with my plan to vent the PCV catch can and just hide/remove it when I go in for an emission check?
Old 11-17-2014, 04:01 PM   #2183
Reaper
Reaper's Avatar
Drives: violent
Yes. Like I told you in the last 30 posts.
Old 11-17-2014, 04:05 PM   #2184
blackfireball5
ok, thanks.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
