Old 11-16-2014, 01:53 PM   #1
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Optimal tire size for DD and canyon driving?
About to get a set of Summer PSS and before I stick with 215/45/17 I was wondering what the consensus was on the "optimal" tire size for this car was. (my tims are 17x7.75 if that matters)
The 215's are thin, but the PSS should offer good grip still, right?
225's would be slightly different without upsetting anything - slightly more grip, slightly more beefy look (but still thin).
Then there's 235's - but will they kill my gas mileage completely? Or ruin steering feel?
Oh - running everything stock, so stock suspension/ride height. 235's might not even give me "the look" without lowering the car.
Thoughts from the masses?
ashtray is offline   Reply With Quote
Old 11-16-2014, 02:02 PM   #2
kodyo
Drives: Scion FR-S
235s seem a bit wide for that rim size, but maybe that's just me. I'm running 225s PSS on my 7.5" wheels and am pretty happy with those so far.
kodyo is offline   Reply With Quote
Old 11-16-2014, 02:11 PM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I'm a Dunlop guy. I like the DZ101. It offers a good mix of grip and tread life optimal for a DD.
hmong337 is offline   Reply With Quote
Old 11-16-2014, 02:13 PM   #4
CSG Mike
CSG Mike's Avatar
You're in socal. Get a stickier tire.
SkAsphalt (11-27-2014)
Old 11-16-2014, 03:37 PM   #5
Pete156
I like to eat!
PSS, 225
Twice the performance of the Primacys, a solid safe great handling tire.
Pete156 is offline   Reply With Quote
Old 11-16-2014, 07:39 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
For me, I really like the 205/45-17 size Max Performance category tires I'm currently running (Kumho LE Sport) on my still stock suspension FRS... much more optimal than the stock tire size for a 7.5" width rim. Diameter is ~.3" less, so speedometer will be a little off, but in the proper direction (reading faster than you are actually going.) Benefits is you do gain better acceleration/deceleration when on and off the throttle from the better 'gearing', chassis agility is noticeably improved, CG is lowered by half the diameter decrease (So it's ~.15" lower than stock), and you have tire mass equal to or even less than the stock tires (= better ride quality).
The stock tire size for this car probably should have been 205/45-17; it fine tunes the chassis even more and quickens its responsiveness. The last thing you want to burden this car with is heavy boots (big, wide sticky tires)...you really notice the loss in agility. What you want is lightweight "track shoes" (narrow somewhat sticky tires) that maximize the chassis's potential. A maximum agility setup trumps a setup with higher traction but with more numbness in the chassis response...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 11-16-2014, 08:37 PM   #7
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I run a 245/40/17 (17x8 wheel) Starspec II in the summer, OFT stage 2, Perrin Intake and I still get 30mpg in the summer on average, and 33 on the freeway. Unless you change your driving habits you shouldn't see to much of a change in mpg going to a softer 225 tire. But if those few mpg are important then maybe a 215 is what you need.
I ran 205's on my 2200lb Hondas but wouldn't go that small on this car if I was also looking for grip feel. 215 min, 225 DD imo, but I'm also very happy with the DD feel of my 245/40s.
Go here for calculating tire dimensions: http://www.miata.net/garage/tirecalc.html
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 11-16-2014, 08:59 PM   #8
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
245s on 17x9 for an aggressive turbo car and I do fine. 22 mpg on e85 at 450+whp. Cheap ventus v12s too.
Old 11-17-2014, 12:29 AM   #9
Vracer111
Vracer111's Avatar
I should note that the 205s I'm running have a wider tread than the stock 215 Michelin Primacy HP's along with better traction in all conditions, and simply unreal wet weather ability - contact area is both larger and wider than stock. It is almost just as planted in the dry as it was with the 215/45-17 Extreme performance track tires on 17x8 +36mm Kosei K4R's, but with better agility and steering feel. In the wet though, nothing I've tried before comes close... It feels more stable than the stock tires do in the dry and is loving this 40'ish degree wet weather we are having... grip grip grip with no complaints.
205/45-17 on 17x7.5 wheels:
Old 11-17-2014, 12:44 AM   #10
Superhatch
AIM4APX
Superhatch's Avatar
@Vracer111
That's awesome that you have a 205 that works well for your needs.
I'm a little surprised that a 205/45 is wider than a 215/45 I think the sidewall to sidewall measurement is smaller by about .4", but perhaps it's because they are a little stretched that the tread width is larger?
Got this from tire rack, I think it explains it...and I learned something today!
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
The rule of thumb is that tire section width changes by 0.2" for every 0.5" change in rim width, being reduced if mounted on narrower then measuring wheel and increased when mounted on wider wheels.
Old 11-17-2014, 01:03 AM   #11
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
With your wheel width of 17x7.75, I would either go 215/45/17 or 225/45/17. I'm running the same tire in 215/45/17 on a 17x7 wheel. The level of grip is excellent for street driving. However, it will leave you wanting more if you decide to autocross/track.
I wouldn't even consider the 235/45/17 size. The thicker sidewall would take away steering response and the larger diameter would make acceleration more sluggish with the taller gearing.
Oh, and with the PSS, I would recommend running lower pressures than stock for better grip. 31 or 32 psi is working well for me.
Old 11-17-2014, 01:25 AM   #12
juliog
juliog's Avatar
Drives: 86
Keep in mind that the actual width of the tire varies per manufacturer/tire model, e.g. not all 225s are the same width..
juliog is offline   Reply With Quote
Old 11-17-2014, 02:19 AM   #13
M23
Drives: 86
Hoosier A6 tires.
M23 is offline   Reply With Quote
The Following User Says Thank You to M23 For This Useful Post:
continuecrushing (11-25-2014)
Old 11-17-2014, 12:14 PM   #14
ashtray
I don't think I am going with 235's, but if I did, I think they would be 40 series - I'd have to run it through the calculator to see if that worked. I wouldn't want a taller tire.
Leaning towards 225/45 at the moment. (ok, I realize this might be taller than a 215/45 on a 7" wide wheel, maybe, but it would be as tall as I'd want to go.)
Won't be doing track days or autox. If I ever decided to, I'd get a separate set of wheels/tires.
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 11:08 PM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 01:01 PM
Optimal tire for 17" rim RealShkillz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-20-2015 05:18 PM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 09:41 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 01:40 AM
