Old 04-02-2014, 12:10 PM   #127
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by deconzme View Post
all I did is strip the two (RCA) wires longer, and shove them in the holes on the 16 pin connector, and everything works just fine. Guess I won't bother to do more. Thank you for your write-ups
I would recommend getting the proper connector from @SVXdc. Just having them shoved in may not last long.
Flat Black VW is offline   Reply With Quote
Old 04-02-2014, 12:11 PM   #128
Flat Black VW
Originally Posted by zc06_kisstherain View Post
@Flat Black VW
What size is Grommet? looks like perfect location for BRZ Premium people for rearview camera
Grommet was about the size of a dime IIRC.
The Following User Says Thank You to Flat Black VW For This Useful Post:
zc06_kisstherain (04-02-2014)
Old 05-24-2014, 03:54 AM   #129
notout86
Drives: GTS 86 auto
People,
Do you have a way to save your head unit settings in order to restore after disconnecting power? Fujitsu TEN head unit.
GTS86 Auto (Australia)
Old 05-28-2014, 03:38 AM   #130
notout86
Drives: GTS 86 auto
A good camera mounting position that is only about 35mm off center can be made under the badge by filling and levelling the surface with epoxy putty or similar. Test with BluTac beforehand.
Old 05-29-2014, 09:23 PM   #131
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Originally Posted by notout86 View Post
People,
You don't need to disconnect the main power to the HU to install a camera and do the bypass.
===========UPDATE============
For newer units, it seems like the new firmware has fixed the bypass trick. I don't have a shot of my current firmware, but I bypassed the VSS, which enables video playback only until GPS get a lock. Once GPS gets a signal lock, video playback is disabled again (blue screen with sound only). The new firmware must be using the GPS speed to trigger the lockout. =(
aznatama is offline   Reply With Quote
Old 08-17-2014, 07:39 PM   #132
notout86
Drives: GTS 86 auto
Instead of using the grommet to route the wire you can pop one of the light housings out and route through the hole, then put the light back. The light housing has a foam dust seal that is thick enough to absorb the wire.
Old 11-14-2014, 06:31 AM   #133
pepe
Drives: gt86
as we would do to have front and back camera?
pepe is offline   Reply With Quote
Old 11-14-2014, 04:27 PM   #134
notout86
Drives: GTS 86 auto
Sorry, I don't understand the question. Wiring under the foam is just for the installation of a rear camera.
Old 11-16-2014, 09:26 AM   #135
MasterMech77
MasterMech77's Avatar
Drives: 2014 Scion FRS 10 Series
If anyone was looking for a backup camera that does not require drilling holes or "mod"
http://www.ebay.com/itm/Brand-New-Ca...-/141314675831
Just found it while I was looking for an easy to install backup camera
2014 Sc10n FRS 10-Series
#655 of 2500
MasterMech77 is offline   Reply With Quote
The Following User Says Thank You to MasterMech77 For This Useful Post:
notout86 (11-16-2014)
Old 11-16-2014, 09:46 AM   #136
pepe
Drives: gt86
It looks great this camera!
My last question relates to install a camera at the back and one on the front of the car.
Old 11-16-2014, 05:03 PM   #137
notout86
Drives: GTS 86 auto
That camera looks handy. It positions it nearer to the center of the car which is good too. The camera will also be recessed and less obtrusive. Good lateral thinking.
Does it work off 6Volt too? That would mean convenience of integration with the Toyota86 head unit. Does it have a wire to cut to remove the guidelines?
I am not clear from the pics but it looks as if the video cable does not go inside the light.
I could be muddled about this as I have forgotten the exact setup within, but if it does then it may not be necessary to go through the grommet?
Old 11-16-2014, 05:23 PM   #138
Foobar
SLO NO MO
Foobar's Avatar
I have a rear and front camera. I used a switching box I got off of aliexpress to allow me to hit a button to turn on the front camera whenever I want, and reverse always overrides like usual. It triggers the reverse signal to the head unit in either case to make it switch on.
Old 11-16-2014, 05:28 PM   #139
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
What do you use the front for? To avoid front bumper scrapes when parking?
B-R-Z is offline   Reply With Quote
Old 11-16-2014, 05:30 PM   #140
Foobar
SLO NO MO
Foobar's Avatar
Exactly. I've learned to know exactly where the front is eventually, but it's added insurance.
Here's an example of the switch: http://www.aliexpress.com/item/front...675896600.html
The Following 2 Users Say Thank You to Foobar For This Useful Post:
B-R-Z (11-16-2014), notout86 (11-16-2014)
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
