Old 11-07-2014, 07:52 PM   #71
s2d4
s2d4's Avatar
Originally Posted by Fast_Freddy View Post
If you say so.
Weak sauce.
Old 11-15-2014, 08:40 AM   #72
DarkSunrise
DarkSunrise's Avatar
if your intake is stock its suprising the maf is out that much, is that filter oiled ? might be worth cleaning maf sensor.
@steve99 - I cleaned out the MAF sensor and switched to a different brand of 93. I also just finished a set of track days. Would you mind taking a look at a log?
http://www.datazap.me/u/darksunrise/...a?log=0&data=1
Also is it still worth doing a MAF rescale? It looks like my LTFT's are within +/- 4%, so that's good, but still seeing my AFR's running rich on WOT pulls.
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 11-15-2014, 03:27 PM   #73
phrosty
Thanks!
Fuel trims may level out over time if you've solved the problem. Until they're fixed, you're going to lose a bit of power at WOT especially in the low end.
phrosty is offline   Reply With Quote
Old 11-15-2014, 03:56 PM   #74
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by tennisfreak View Post
Give the ECU time to adjust?????
Isnt the point of a tune to change your ECU to work with the mods???????????
I'd be freaking pissed and demand a refund if a stage 2 tune gave me 3 whp with that list of mods.
No waiting on a ECU learning period, something is wrong with that tune.
WTF? I've helped a friend install a boss 302 intake manifold on a 2011 mustang and a tune, and my god even that needs time to learn on the first start up it sounds extremely rough almost a misfire and eventually the tune begins to adapt and learn the engine, its literally the same for this car......
Old 11-15-2014, 10:48 PM   #75
steve99
Drives: FT86
Thanks!
Fuel trims ess than 4% is good they will vary a bit with large changes in air temeratures as some compensation is applied to maf vs IAT.
Dont rely on wideband afr reading uness yu have correct bosch sensor and cotroller fitted.
your afr and commanded afr pretty good only about 5% out but the oft guys offset the OL maf scale on stage 2 tunes a bit to make it run on the rich side for safety. If you have good fuel you could do your open loop maf scaling to get the afr a bit closer on WOT but you migh get knock s if you do maf scaling just keep an eye on any hgh rpm knock.
was a tiny bit of flkc but only less than 0.6 so ok.
DarkSunrise (11-16-2014)
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 10:04 PM
Stock Dyno vs GReddy Intake Dyno JTOFJPN Engine, Exhaust, Transmission 0 06-01-2014 04:56 AM
Stock Dyno and Perrin Stage 1 Results brillo Software Tuning 4 01-24-2014 09:26 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-28-2013 12:41 AM
