Old 11-12-2014, 11:58 PM   #71
bryan0101
Drives: 2015 BRZ Series.Blue on blue
So the LED stripe is mounted on the outside? How'd u route the cable?
Originally Posted by koteman View Post
Stillen roof spoiler and led strip
bryan0101 is offline   Reply With Quote
Old 11-13-2014, 12:06 AM   #72
koteman
koteman's Avatar
Drives: Scion frs
Under the strip on the roof drilled a hole
koteman is offline   Reply With Quote
Old 11-13-2014, 01:36 AM   #73
bryan0101
wow...drilling hole on the roof. That's beyond my skillset and bravery.
Old 11-13-2014, 08:15 AM   #74
koteman
koteman's Avatar
Drives: Scion frs
It's on the seem weld under weather striping it's not a big deal just run the wire through then sillicon it shut
Old 11-13-2014, 03:33 PM   #75
bryan0101
Thanks for the tips.
so which LED strip you used on it?
It does look very good!
Old 11-13-2014, 03:36 PM   #76
koteman
koteman's Avatar
Drives: Scion frs
Just a cheap eBay 5m strip of 5050 red leds 300 leds in 5m. Then reflective tape and clear sillicon
Old 11-13-2014, 09:17 PM   #77
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Any of you gents aware of this one? https://www.japanparts.com/parts/detail/45825
Mim is offline   Reply With Quote
Old 11-14-2014, 11:37 PM   #78
bryan0101
Looks sweet, and of course abit pricy w/ the shipping and all. Still I think deserve its own DIY thread if anyone ever have it install!!!
And just to throw the idea out there, there are high quality WEATHERPROOF and not too expensive LED strip out there.
http://www.customdynamics.com/trufle...d_lighting.htm
Old 11-17-2014, 11:06 AM   #79
Rosticles
Drives: 1966 Mustang, 2013 FR-S
http://www.ft86club.com/forums/showthread.php?t=75887
Rosticles is offline   Reply With Quote
Old 11-18-2014, 12:49 AM   #80
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
In case you didn't see this thread I made...cheap option: http://www.ft86club.com/forums/showthread.php?t=72225
Phaedrus29 is offline   Reply With Quote
The Following User Says Thank You to Phaedrus29 For This Useful Post:
thatfilipinoguy (04-19-2016)
Old 11-18-2014, 01:03 AM   #81
bryan0101
One concern I have as I am sure other ppl have as well. I got a rather expensive tint job done, so whatever solution it might be, it has to not stick to the rear windshield. Nontinted ones i am sure is fine.
Old 11-18-2014, 09:16 AM   #82
Rosticles
I, along with a lot of others who purchased wheelhaus's solution, have tinting. The 3M adhesive will not pull off your tinting unless it is done poorly.
Old 11-18-2014, 02:57 PM   #83
bryan0101
I understand it *should* not damage the tint.
But no one can be 100% certain that over time, when the 3m tap is melted, and you want to uninstall it, there are no chance of damaging the tint, OR just leave a deep mark/residue/whatnot on the windows/tint surface. And you cannot use a razor blade or other chemical to clean it because it'd destroy the tint.
I have 3m crystalline installed from auth. dealer w/ lifetime warranty, and it was not cheap, so I probably wait for a vendor/soution that I can safely mount it without taping to windows, just like the OEM is doing.
To me, any mod/solution should be better than OEM in every ways, so as to worth the time and money. That's just me.
Old 11-25-2014, 09:37 AM   #84
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
That's actually why I designed the bracket for mine (found here). You may be able to retrofit wheelhaus' third brake light with my aluminum bracket design if you were so inclined. It makes it easy to remove for tinting and cleaning.
fatherfork is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
Subaru FT86 still not have the green light! ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2011 04:57 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
