Old 11-12-2014, 06:20 PM   #57
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by extrashaky View Post
I'm having a difficult time imagining a situation when I would need to go from 6th to 3rd.
Maybe he's going 20 MPH in 6th gear and decided he's doing it wrong? Lol.
Stang70Fastback is offline   Reply With Quote
Old 11-12-2014, 06:22 PM   #58
Pkush
I've never done it but imagine cruising at 60 mph in 6th and you suddenly need to quickly overtake or avoid an accident or something. Downshift to 3rd to get the most kick...I guess. But i'm not experienced it's just my theory
Pkush is offline   Reply With Quote
The Following User Says Thank You to Pkush For This Useful Post:
Stang70Fastback (11-12-2014)
Old 11-12-2014, 07:03 PM   #59
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Originally Posted by Stang70Fastback View Post
You can skip as many gears as you want if you properly rev match. Just adds 0.0001 extra wear to the synchros. If you go straight from 6th to 3rd without matching engine speed or slowing down a lot and just slam it into gear you risk locking the rear wheels, but that's about it (obviously assuming you aren't going into 3rd at a high-enough speed to over-rev it.)
I'm gonna get flamed for this, but I only downshift by rev-matching. I'm new to driving manuals, so I still don't have the clutch control to let it out slow enough to downshift without blipping the throttle in-between. I'm learning now how to, but yeah, see below for why I downshift rev match from 6th -> 3rd.
Where I'm at in Texas, I use highways whose exits lead to turnarounds fairly quickly, so I exit the ramp at ~70mph, cruise in 6th to the turnaround, downshift to 3rd or 4th before it, and putz my way through. Never really was one to engine brake going through all the gears.
Jyn is offline   Reply With Quote
Old 11-12-2014, 07:56 PM   #60
stugray
Drives: 2013 GBS BRZ Limited
If I am just cruising along at 55MPH trying to get good gas mileage, I'll be in 6th at 2500 RPM.
If I suddenly see I need to pull off a pass, I can down shift to 3rd which would be 4900 RPM just past the torque dip.
If you stomp it there you will soon find yourself upshifting again soon.
Old 11-12-2014, 08:07 PM   #61
extrashaky
Drives: 2014 BRZ Limited
Okay. I guess it just seemed like a bigger RPM jump than it is.
Old 11-12-2014, 08:18 PM   #62
If you're referring to what I was saying about the stepped downshift, It's not a matter of engine braking, it's literally clutch disengage, 6-5-4-3, rev-match, clutch engage.
It's just so the 3rd gear syncro doesn't have to do all the work of spooling up the input and counter shafts.
That technique is definitely not controversial.
Old 11-12-2014, 08:19 PM   #63
Anything on that first gear lockout? I looked - didn't find anything.
Old 11-12-2014, 08:28 PM   #64
Stang70Fastback
A.K.A. Starlord
No, you won't get flamed. The people getting flamed are the ones telling everyone to double-clutch all over the place. Rev-matching is good practice if only because it makes for a much smoother ride, and makes you look more bad-ass (and can be handy on the track.)
Rev matching is what you are SUPPOSED to do. Any modern automatic gearbox car rev-matches for you, and there are even manual vehicles (such as the 370Z) that will rev-match for you. Rev-matching is the proper technique.
Old 11-12-2014, 08:48 PM   #65
extrashaky
And it also reduces wear on your clutch.
The new Corvette has active rev matching. If you downshift, it will match the revs for you so that you don't have to blip the throttle. Which made me wonder, if you're accustomed to blipping the throttle and blip it anyway, does it rev match your rev match?
Old 11-12-2014, 08:53 PM   #66
Stang70Fastback
A.K.A. Starlord
When I drove the 370Z I actually never thought to mess with the auto rev-match... a failure on my part, clearly.
...does it rev match your rev match?
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Jyn (11-13-2014)
Old 11-12-2014, 09:21 PM   #67
stugray
In the pic above you posted.
What is the "First shift restrict ball" for?
I would assume to restrict you from going into 1st? From where?
1st is the only gear that has one.
Old 11-12-2014, 09:42 PM   #68
Is that the same diagram to which you were referring? I don't know what it does and I don't like making assumptions.
What I am interested in is actually learning something new and correcting misunderstanding should any exist.
Old 11-12-2014, 09:45 PM   #69
I double-clutch between rev-matches.
Old 11-12-2014, 10:33 PM   #70
Teseo
Drives: frs
Question:
Its bad if i press the clutch→ blip throttle→downshift→ realese clutch all with fluid motion?
Manual in DMV? DatDudeLoso Mid-Atlantic 25 06-19-2013 12:29 PM
Should i get manual or AT? mistax Other Vehicles & General Automotive Discussions 98 02-28-2013 06:25 PM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 11:24 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
