#2129 | |
My opinions are constantly evolving; do note the date/age of my posts when comparing them. Newer posts will supersede old ones. |
#2130 |
I'm with the folks that mentioned more camber and raised car. Kwv3 can get -2.5 naturally and then some, done at a confient shop. Camber bolts can also add camber. Camber plates, I'm a meh, but that's because my Vorshlags makes noise when it's cold on the passenger side. And yes, after raising my V3's (from 1.5 fingers to 3), the car feels more stable during transitions, prior to erratic behaviors when gas'ed and transition'ed at the same time. That's before the rear LCAs. I would rather invest in rear LCA over camber plates. But that's just me, the rear LCA was the better improvement.
#2131 |
Because compromise ®
Drives: Red Herring
AST Dampers?
Does Andy or Mike (or anyone else for that matter) have an opinion on AST dampers? I'm interested in the quality of damping and reliability; I have read that there have been issues with distribution in the US which doesn't affect me. Having said that I don't care if the damping characteristics of one brand are incrementally better than another because I won't be buying more than one set to do side by side comparisons. In the couple of Porsche and Bimmer forums I have looked at there doesn't seem to be that many people with AST; JRZ and MCS seem to be the more highly regarded of but I don't know if this is warranted. In Oz AST are significant cheaper, for comparable models, than JRZ or MCS. Also, in their favor is the fact that they can be serviced here as opposed to MCS which has to be sent back overseas for servicing. I kid you not! (I don't the situation with JRZ).
Yes, I have considered at Tein SRC (forgive me for mentioning them in the same breath as the above brands) but the Australian distributor has never imported a set and the manual is not available in English. This does not fill me with confidence. Also, getting different spring rates from standard is a bit of a drama according to the importer. Ta.
#2132 | |
They do offer a double digressive piston upgrade here for their 4100s which is interesting. I'm going to try to talk to them at the PRI trade show in December. The 5000 series are a pretty serious piece of kit but for the money I'd be looking at JRZ (at least over here). If your AST distributor over there has a good reputation and works well with customers then I think they're an option worth considering. - Andy |
#2133 | |
Drives: Red Herring
Here,even with the double digressive valving the 5200s are about $1500 less than the MCS 2 ways and about $1200 less than RSpros! For me that is a significant difference in price. Local servicing is also a major factor in purchase. Spending $800 just to freight the dampers there and back if they needed work is a cost I do not want to wear.
#2134 | |
RS Pros are AMAZING and worth every penny. But the cost to send them to the states for service would be painful. - andy |
#2135 |
Drives: 2015 FR-S (Halo)
So I have a track question - for reasons that are entirely legitimate, I went with the AT (I can drive MT quite well, but this is my daily in terrible high grade stop and go traffic, among other reasons) and I know this means I lose about 8-10 hp from what I've seen on the dynos and I'm sure a couple other lower stats. I know the gearing is different, but is the final drive as well?
I was at auto club speedway this past weekend and while I was able to hold speed with much faster cars due to the handling when in twistier sections, my acceleration out of harder corners wasn't good despite me always keeping my shifts, from what I understand, good and being in the power band. For me, when coming out of 2nd I feel like I spend a bit of time just working my way out of a low rpm range and that's where everyone else with more HP shoots away. I know part of this is the fact that this car isn't a gt3 or a zr1, but I feel like there's spots where I'm wasting time not at high rpm and I can't get there fast enough. I was thinking about changing the final drive - nothing TOO drastic as it's still my daily but to something that would help me get up to higher revs faster. I'm not too worried about my top speed, so do you think this is a wise choice? Thanks! Sent from my HTC One_M8 using Tapatalk
#2136 | |
Drives: 2013 WhiteOut FR-S
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
#2137 |
What RPM are you at in 2nd gear?
2022 BRZ Build 2013 FR-S Build |
#2138 |
To be thorough, in my last lap I tried practically every shift point from 6000 (low IMO) to bouncing off the rev limiter. Over 10 shifts, probably. They all were a bit slow when I was coming off an apex into a straight. I'm a bit new to the track but it's also an AT so my gearing is a bit different.
#2139 | |
You can't go wrong with the JRZ and SRCs, but with a strong support for AST, you can't go wrong that way either. |
#2140 | |
What kind of times were you running? |
#2141 |
Drives: Toyota 86 GTS
Regarding bedding of pads, i've decided to switch between dedicated pads for track and stock pads for street due to horrible dusting and noise (project mu HC800+). What's a safe procedure for bedding in of pads before and after track time performance wise?
Can i just rock up swap, do the bedding procedure and jump on or is there any timeframes involved? And is there any downside to swapping frequently/infrequently of the pads? Cheers
#2142 |
Drives: GT-86
You have noise with the project mu's? After bedding mine make no noise now. The dust also to me isn't very much.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
