Old 11-06-2014, 05:07 AM   #323
Calum
That Guy
Drives: 2013 asphalt FRS MT
Can you elaborate on that for someone who has no idea what that means?
You can see the tool marks on the flanges. (Swirl patterns from the cutter) My worry is that those tool marks are deep enough to prevent a good seal. But Dimman is the professional machinest and has seen many, many more parts than I have. If he's saying its only a weird lighting situation I'll take his word for it.
Old 11-06-2014, 08:48 AM   #324
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
x2 Is that good or bad!? lol
yomny is offline   Reply With Quote
Old 11-06-2014, 09:00 AM   #325
Calum
That Guy
read the post above yours
The Following User Says Thank You to Calum For This Useful Post:
yomny (11-06-2014)
Old 11-06-2014, 10:19 AM   #326
yomny
yomny's Avatar
Anyone so far has had any issues with leaks via the exhaust port flanges?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Old 11-06-2014, 11:14 AM   #327
s30series
Drives: 2015 BRZ Series.Blue
LOL
It's not going to leak. The flanges are the flattest I've ever seen a header flange. The stock Subaru gaskets are very good quality.
If you do the install correctly and tighten down the studs, nothing is going to leak.
s30series is offline   Reply With Quote
The Following 2 Users Say Thank You to s30series For This Useful Post:
rb6freak (11-06-2014), yomny (11-06-2014)
Old 11-06-2014, 05:25 PM   #328
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Originally Posted by Calum View Post
Wanna see a guy get frustrated? Show those flanges to @Dimman. Most of the header looks great, but that's a sealing face, finish the damn job!
That's a CNC machined flange, the surface texture is tooling marks--there's no sealing issue here. If it was the surface of a cylinder head, yes you want to maintain an almost mirror RA finish. This this an exhaust flange. What's important is that it's flat, the gasket will take care of the rest.
Mrc@ptuning is offline   Reply With Quote
The Following 5 Users Say Thank You to Mrc@ptuning For This Useful Post:
Calum (11-06-2014), civicdrivr (11-07-2014), lucid215 (11-07-2014), rb6freak (11-06-2014), Snowball (11-06-2014)
Old 11-08-2014, 12:08 PM   #329
yomny
yomny's Avatar
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header (200+whp 93 pum...
@Mrc@ptuning does the header have rasp? This also goes for any member that has it installed. I'm sure mine isn't any different but I running stock cat back and I have rasp when blipping throttle or accelerating. I'm new to the header world mostly I've owned forced induced cars. Thanks
Old 11-08-2014, 12:33 PM   #330
Snowball
Snowball's Avatar
Drives: 2013 Whiteout Scion FR-S
Hey yonmy, do you have any video of your car with the header? I was looking to run it with the stock catback as well. Thanks
Snowball is offline   Reply With Quote
Old 11-08-2014, 12:35 PM   #331
yomny
yomny's Avatar
I'll take one today with my camera. It doesn't sound bad, but used to the stock exhaust there's definitely more sound coming from there. I'll get the video up.
Old 11-08-2014, 12:38 PM   #332
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Anytime you're on the throttle or a specific RPM?
I can barely hear some but only at low RPMs (around 2k).
I have stock catback as well.
Old 11-08-2014, 01:00 PM   #333
yomny
yomny's Avatar
With the windows down I could hear it pretty much most of the time. It just sounds like the sound it makes, not a leak. I'll check tomorrow for leaks again. I started the car while on jack stands and checked but no leaks that I could detect. On a cold start you could really hear it.
Old 11-08-2014, 01:25 PM   #334
yomny
yomny's Avatar
Here are a couple of videos, now that i see them the rasp sounds a bit louder from the outside, then again no camera mic setup is perfect and things sound slightly different(better) in person. I tightened the header/head nuts to 25-30 ft lbs(glimpsed thick manifold flange) same as the overpipe to header to front pipe.. I'm 99% sure that all is pretty tight as i didn't hear anything when i was laying under the car while it was running. I also tightened each runners connecting nuts... or what ever those are called as well as the vband. Maybe the guys could chime in, they would know if it sounds like this @Mrc@ptuning @peace2ptuning @ptuning and what specs to torque these to.
[ame]http://youtu.be/4qK5bBUSafE[/ame]
[ame]http://youtu.be/TPGNDOXBwaY[/ame]
The Following 3 Users Say Thank You to yomny For This Useful Post:
Crosscharge (11-08-2014), rb6freak (06-30-2015), Snowball (11-08-2014)
Old 11-08-2014, 01:43 PM   #335
s30series
What kinda of midpipe do you have? Is your whole exhaust stock except for the headers?
Old 11-08-2014, 01:53 PM   #336
yomny
yomny's Avatar
Yeah stock except tomei over pipe. I know bigger diameter exhaust will flow better and less restriction makes for smoother sounding exhaust. The sound comes from the header. I think these nice looking stainless mirror finished exhausts/headers sound like this. Could be the material is thinner? I'm just speculating, I don't know anything about metals or exhausts but I know back in the days in my s2000 I had a Megan header and sounded similar.
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 07:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 09:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 10:17 PM
