| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Wish Nissan made one
Drives: '13 WRB BRZ Premium
Subaru VIN Decoding: What all the numbers and letters mean
http://www.cars101.com/subaru/vin.html
Now that some of us are getting VIN numbers for our inbound cars, I thought it might be interesting for people to understand what these VIN #'s mean. You will have 17 digits.. A combination of letters and numbers. Digit 1: J = Country of assembly = Japan Digit 2: F = Manufacurer = Fuji Heavy Industries Digit 3: 1 = passenger vehicle Digit 4: Z = Product line Digit 5: C = Body (C may stand for Coupe) Digit 6: A = Engine Type Digit 7: ? = Model type and trim. Mine is B and I have a premium. Digit 8: 1 = Code for restraints (seat belts and airbags) Digit 9: ? = Mystery code #.. Somehow a check for accuracy Digit 10: D = Model year (D = 2013) Digit 11: 1 = transmission (1 = Manual) Digits 12: Something to do with the line it came off of. Digits 13-17: Sequential order of production. 00175 would be the 175th car built. 03980 would be the 3,980th car built, etc.. I'm not sure what happens when they hit 10,000.. they must change the 12th digit or something?? So we should all have very similar VIN's.. Some poeple are funny about being worried about posting their Vin #. But, there should only be a couple digits that would vary at all.. In our case, digits 7, 9, 11, and 14-17. |
#2 |
Drives: A4, Isuzu Vehicross
Digit 7: ? = Model type and trim. Mine is C and I have a limited. Just received my VIN!!!
#3 | |
#4 |
Drives: Ultramarine FR-S AT
The pre-production cars may have taken some of that pool?
#6 | |
Drives: BRZ and NA
With pure numbers (I'm not sure how they work with the letters), the check digit(s) are chosen such that when the number is run through the checking algorithm, the end result is 0. That way any valid number + check digit run through the algorithm will always produce the the same result. In the computer world, if a TCP packet (or any other kind of transmission packet that's has a check sequence) gets recieved and it has an error, the algorithm will report that and the program can ask for a retransmission of that packet. The same thing happens when checking memory for bit-flips or invalid writes. ![]() Let me know if you want to know more. Knowing the details isn't really necessary to understand what the check value is doing though. |
| The Following User Says Thank You to Grimlock For This Useful Post: | Fly Guy (05-05-2012) |
#7 |
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
#8 |
^ Yep.. you're right.. sorry, that's what I meant to say.
#9 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I'd like to see a FRS VIN to compare.
Mine matches up. C for Limited, 1 for Manual, etc. The trim level code is interesting. B for Premium and C for Limited leaves A for a base model. |
#10 |
Drives: 2013 Subaru Impreza Sport
Test drove an FRS today, took a pic of the vin under to hood (the sticker had the Subaru emblem all over it haha). Vin is jf1znaa17d2700068.
It was an automatic, so it seems like it might be the same code per the 2 for the 11th digit. So FRS is A, BRZ premium is B, and BRZ limited is C for digit 7. |
#11 |
Drives: BRZ(sold), STI
Can someone with an automatic post their 11th digit pls?
#12 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
9 is the check digit (calculated for CRC check).
11 is the plant. 12-17 are sequential frame numbers.
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#13 | |
Corner Junkie
The FR-S could certainly be considered a base model, so A trim could still work for a Subaru Base. Or not. I do wonder if the VINs are sequential across just the makes or all cars. i.e. Is my car #195 of BRZs, or of all BRZs/FR-S' off the assembly line. And it is for all markets, or just the US? Hmm.. |
#14 | |
| Decoding the oddities of the Subaru BRZ owners manual | blackmist27 | BRZ First-Gen (2012+) — General Topics | 18 | 03-23-2012 03:37 PM |
| Brz Production Numbers | WRB Bandit | BRZ First-Gen (2012+) — General Topics | 29 | 03-07-2012 09:53 PM |
| Any Idea of U.S. Pre-Order Numbers? | markemark24 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-21-2012 12:29 PM |
| Japan BRZ / 86 pre-order numbers | AVOturboworld | BRZ First-Gen (2012+) — General Topics | 55 | 01-21-2012 02:18 AM |
