Old 11-05-2014, 11:53 PM   #2101
bjun
bjun's Avatar
Drives: white premium brz M/T
I don't know why my picture turned sideways, but besides the rear camber, does my alignment look ok for track setup? I already purchased whiteline rear LCA to fix my huge negative camber in rear
bjun is offline   Reply With Quote
Old 11-06-2014, 10:40 AM   #2102
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
IMO not enough front camber. You'll wear the outside shoulders of the tire pretty heavily. Toe is pretty much what I'd aim for (maybe a bit less rear toe? not sure how sensitive the BRZ is to that)
The Following User Says Thank You to DocWalt For This Useful Post:
bjun (11-06-2014)
Old 11-06-2014, 11:22 AM   #2103
bjun
bjun's Avatar
If I bring the rear camber to -2.5 how much front camber should I have to have optimal track performance? I don't daily my car so wearing out tire isn't too much issue but also do not want extreme alignment setting that would destroy my tiree prematurely
Old 11-06-2014, 11:51 AM   #2104
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd personally go for somewhere in the -2 to -2.5 range. Your toe settings are more critical for tire wear on the street, and as close to 0 as you can get will minimize inside shoulder wear.
I'll let someone with more track experience with this platform give you better numbers, but check the alignment threads on the forums.
bjun (11-06-2014)
Old 11-06-2014, 01:50 PM   #2105
CSG Mike
CSG Mike's Avatar
How much experience do you have?
Do you have camber plates?
What kind of tires and suspension do you have? It seems you're slammed if you're at -3.3 without arms.
Old 11-06-2014, 04:35 PM   #2106
bjun
bjun's Avatar
No camber plates. And not much experience.
I have the hankook evo2s 255/18. Kwv3 coilovers, ptuning front+rear sways and whiteline endlinks. About to install whiteline lca. I'm not slammed but I did get rid of wheel gap.
Old 11-06-2014, 09:12 PM   #2107
CSG Mike
CSG Mike's Avatar
If you're interested in tracking with KW V3, you need to raise your car.
bjun (11-07-2014), raul (11-07-2014)
Old 11-07-2014, 01:53 AM   #2108
bjun
bjun's Avatar
Yea I figured my cars a bit low but I hate wheel gaps lol
But I've tracked like this before and it wasn't so bad. Actually it still performed well. But I think the camber is too much. I like the toe. So what camber front/rear would you suggest? I was thinking -2f/-2.5r
Old 11-07-2014, 02:10 AM   #2109
CSG Mike
CSG Mike's Avatar
You can hate wheel gaps all you want, but as you develop as a driver, you will run into problems.
This is a thread for performance driving applications, and I'm telling you that you're too low for a performance application of the KW V3. You're gonna run out of stroke length, and that'll cause your rear end to respond erratically.
Do you want to look pretty or go fast?
You could, theoretically, do both, but not with a KW V3.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
bjun (11-07-2014), Campo (11-13-2014), Captain Snooze (11-07-2014)
Old 11-07-2014, 02:35 AM   #2110
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
all this talk about camber is making me want to get camber plates on my fronts.. Tired of having 1.5 lol
bkblitzed is offline   Reply With Quote
Old 11-07-2014, 08:26 AM   #2111
bjun
bjun's Avatar
Which performance coilover would you recommend?
Old 11-07-2014, 09:52 AM   #2112
troek
troek's Avatar
Drives: 2012 Toyota 86
how low are you exactly?
troek is offline   Reply With Quote
Old 11-07-2014, 10:06 AM   #2113
bjun
bjun's Avatar
I don't feel like I'm too low. I don't find it difficult driving on normal streets. I am still like 3 inches off the ground on front and like 5 inches in rear from the rear diffuser. However, I am on max low on front as KW will take me(I know this is bad for handling) but in the rear my coils have plenty more to drop.
Old 11-07-2014, 10:14 AM   #2114
jvincent
jvincent's Avatar
@bjun, please don't take this personally, but have you read the following thread?
http://www.ft86club.com/forums/showthread.php?t=67345
The Following User Says Thank You to jvincent For This Useful Post:
bjun (11-07-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
