Old 11-04-2014, 10:28 PM   #113
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yeah, I guess so. I'm really on the fence but am not above being shamed into it.
Much shame in your general direction.
Old 11-04-2014, 10:37 PM   #114
Ok, I'm on it.
Old 11-05-2014, 04:11 PM   #115
Mustered up the strength to yank it. Immediately felt it backing out of the driveway. The feel is even better but I will say, for a normal sized person, pedal force might be a bit much in stop-and-go traffic.
I'm a bit of a sasquatch.
edit: If you don't mind a good manly clutch feel. I recommend both. It feels amazingly direct and crisp.
Andrew025 (11-05-2014), arobb10 (11-06-2014)
Old 11-06-2014, 09:43 AM   #116
37
degrees
37's Avatar
Drives: 6MT BRZ
MTEC makes a replacement spring that might prove to be a good balance. No idea on the spring weight compared to stock. Judging by wire dimensions alone it looks to be 40~50% lighter than stock, right about where a normal clutch pedal return spring would be.
http://www.mtecind.com/diy/scion-frs...pring-install/
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
jcw99 (11-21-2015)
Old 11-06-2014, 11:08 AM   #117
Koa
Originally Posted by 37 View Post
Killer. That's exactly what I'm after.
Looks like the AutoZone part might be the same as the 30620-AA111. The compound angles on the banjo area look the same to me.
edit: If the line doesn't fit with your slave then I don't see why you couldn't just route it like this -3 AN line from @Chase Bays. If he's still on the forum, maybe he can comment on the effect of reducing the line size (which should in effect be the same as shrinking the slave size, barring any potential existence of a delay valve).
edit again:
That explains the alignment issue you're seeing. The OEM Forrester part looks like it's in the same casting as the BRZ.
Now I wonder what might be different in the part you bought versus the original part from Subaru. Yours might be lacking a delay valve (if it exists) where the OEM parts have them. Just a thought.
Hi guys, I own the FRS twin, but I have a long-standing relationship with the local Subaru dealership's service department down the street.
I would like to know if this Forester part will be a 1:1 swap? Would love to pick it up rather than go to Toyo of Kirkland ($$$$ plus an hour drive? no thanks!)
Old 11-06-2014, 02:51 PM   #118
37
degrees
37's Avatar
Drives: 6MT BRZ
30620AA111 is a 1:1 swap with the FRS/BRZ slave. It's the same casting with a smaller piston. The slave that @Ultramaroon purchased is for an older Forester, hence why it's not a 1:1 swap and doesn't match at the banjo mount.
You'll also want two new 114130151 crush washers and a small bottle of brake fluid if you don't already have it.
Official parts list:
1) Subaru 30620AA111 clutch slave
2) Subaru 114130151 crush washers (x2)
3) Small bottle of DOT 3 or DOT 4 brake fluid
The Following 4 Users Say Thank You to 37 For This Useful Post:
FeRS (03-01-2022), Koa (11-06-2014), Teseo (11-06-2014), Ultramaroon (11-06-2014)
Old 11-06-2014, 03:05 PM   #119
Except these aren't return springs. They are assist springs. This is an important distinction.
37 (11-06-2014), jcw99 (09-11-2015), travisb (11-09-2014)
Old 11-06-2014, 03:12 PM   #120
Yeah, I removed my reference to the wrong part even though I'm keeping it. @37 made a good point about just turning the banjo fitting. It works.
Uggh... I don't want to redo the photos but so many people will see it...
Old 11-06-2014, 03:25 PM   #121
37
degrees
37's Avatar
Drives: 6MT BRZ
edit: nevermind. You're correct - I just checked the action and the spring cams over center. It does appear to assist.
Your CarQuest part number was incorrect but the Subaru part was fine. Your part is from an earlier Forester where the Subaru part (30620AA111) is a later model and fits 1:1 in the BRZ. Your local parts store probably just got you the wrong part. No worries.
Old 11-06-2014, 04:29 PM   #122
Nomenclature notwithstanding, I'm genuinely curious how this wouldn't be distinguished as a return spring. Removing a return spring can also make a pedal feel heavier depending on the clutch pedal design.
I know it sounds like I'm nitpicking but a return spring works to bring the pedal back to its resting position. It works in the same direction as the return spring in the master cylinder.
As part of an over-center mechanism, this one works opposite. It is at is maximum compression when the pedal is at rest but doesn't apply any force to the pedal.
edit after seeing your edit: Yaay!
I really appreciate the verification. Thank you.
Old 11-06-2014, 08:02 PM   #123
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Is the one I found the correct one?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-06-2014, 09:22 PM   #124
37
degrees
37's Avatar
Drives: 6MT BRZ
This one? http://www.autozone.com/drivetrain/c...er/383444_0_0/
The list of vehicles looks correct, as does the photo. I'd say it's probably the correct replacement part.
Personally I'd rather spend the extra $15 and buy an original. At least you'd know what you're getting.
Old 11-06-2014, 10:58 PM   #125
Phantobe
Phantobe's Avatar
I'll call them & see if they know the bore size on the cylinder.
That $15 I save is for my OFT fund haha...
Old 11-07-2014, 12:15 AM   #126
Good choice
Are these fake? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 12:57 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
fake Bugatti anyone? bofa Other Vehicles & General Automotive Discussions 16 07-18-2011 02:20 PM
