Old 04-14-2014, 01:33 AM   #15
Dezoris
Dezoris's Avatar
Originally Posted by mav1178 View Post
Once you set up the base shaft's "anchor" point (where the outside piece threads to), to swap between the Tug View & the UPM takes me about 60 seconds.
As for the color, it's prettier when new. Once you've used it for a while, it is less pretty. But the red tow hook ring looks darker in person.
The above pictures in my review threads were all taken with an external flash, so the colors are saturated and overexposed.
-alex
Would you buy it again or stick with stock?
Seems expensive for what it is.
Old 04-14-2014, 11:47 AM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Seems expensive, yes, but this is the only tow hook on the market that incorporates GoPro mount and a license plate relocation mount in one design. Granted, you have to buy 2 different parts to make it work, but compared to the Grimspeed mount (which I previously owned) the Raceseng part was so much easier to install and remove.
If I was only using the tow hook for towing, I'd go with stock since the cost is zero.
-alex
Old 04-14-2014, 12:22 PM   #17
ddeflyer
So I ended up ordering the RacesEng one with a GoPro mount for the front. I still will probably end up getting another tow hook of some sort for the second rear mount but that is a lower priority. In the end the better license plate mount compared to the grimmspeed one I have now made my mind up. Thanks for the advice, especially mav1178.
ddeflyer is offline   Reply With Quote
Old 04-14-2014, 02:25 PM   #18
ayau
Drives: Some rust bucket
Am I the only one who finds mounting a GoPro at the front bumper useless? It helps show your driving line somewhat, but you can't see what your hands and head are doing.
Old 04-14-2014, 02:31 PM   #19
CSG David
CSG David's Avatar
All about dat perspective and camera angle. How else can you get an Oscar nomination?
The Following 2 Users Say Thank You to CSG David For This Useful Post:
ayau (04-14-2014), Ultramaroon (11-05-2014)
Old 04-14-2014, 02:33 PM   #20
ddeflyer
My best result has been from the roof of the car. I used to do front bumper but it really tells you alot less about your line. I just got the gopro mounting one because, well, why not? Maybe I will use it someday when doing multiple cameras or something. It adds some cost but it is on top of an already very expensive (for what it is) part. I really choose it for the easy change of the license plate holder.
The Following User Says Thank You to ddeflyer For This Useful Post:
CSG David (04-14-2014)
Old 11-02-2014, 08:03 AM   #21
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Anyone know of any tow hooks that have a longer shank on them? Need one for my rear. It has to pass over the RB diffuser - I will be drilling a hole through the diffuser.
stevo_12v is offline   Reply With Quote
Old 11-02-2014, 08:40 AM   #22
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by solidONE View Post
Those Godspeed hooks were $50-60 MSRP wen I checked months ago. Now they are $80... sheesh. supply and demand I guess.
I bought mine from godspeed for 8$ off of their facebook group buy. Not a typo 8$
Old 11-05-2014, 10:46 PM   #23
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
If someone wants to make ones like this for FRS/BRZ, I will absolutely buy two. MUST BE FUNCTIONAL, not for show.
https://www.machtschnell.com/categories/tow-straps
Alan is offline   Reply With Quote
Old 11-05-2014, 11:25 PM   #24
I'd advise against that because you end up with a huge bending moment. Just begging for trouble.
Old 11-06-2014, 05:00 AM   #25
stevo_12v
Stock tow hook has a long shank(relatively speaking). I only need another 20-30mm extra length to clear my RB diffuser
The Following User Says Thank You to stevo_12v For This Useful Post:
rever5e (11-06-2014)
Old 11-06-2014, 01:46 PM   #26
Gotcha. Stock one is pretty long.
Old 11-06-2014, 01:57 PM   #27
Reaper
Reaper's Avatar
Drives: violent
Just use a racequip strap instead.
Old 11-06-2014, 08:39 PM   #28
rever5e
OEM towhook. Free, and it takes 15 seconds to put in. If i had a dedicated racecar, i'd probably put straps on it. Tow hooks are not for the street.
rever5e is offline   Reply With Quote
tow hooks ? for what-- rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 54 03-18-2015 07:06 PM
2 tow hooks please DrDuquette Want-To-Buy Requests 1 08-16-2013 08:46 AM
Tow hooks Chen Northwest 25 01-05-2013 09:40 PM
Tow hooks Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 12 11-11-2012 06:22 PM
Front tow hooks for BRZ gmookher BRZ First-Gen (2012+) — General Topics 0 10-29-2012 06:26 PM
