Old 11-01-2014, 06:58 PM   #15
mitch t
mitch t's Avatar
Drives: stx class lava frs
My friends at MotoIQ posted a little review and install article yesterday! Thanks Mike!
They got some really good shots of the installed skid plates, as well as a really detailed install. It sure helps to have a lift, and good lighting.
http://www.motoiq.com/MagazineArticl...kidplates.aspx
mitch t is offline   Reply With Quote
The Following User Says Thank You to mitch t For This Useful Post:
whataboutbob (11-01-2014)
Old 11-05-2014, 07:42 PM   #16
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
Originally Posted by mitch t View Post
hey guys, I am getting some orders on these parts (thanks Robert!), so I think I need to point out that this part is designed to fit the FRS specifically, but since the BRZ has a different bumper, it would need a slightly different part to fit as well. If there is is some demand, i will get to work on that next!
Thanks,
I want a BRZ version! Please?
MysteryMachine is offline   Reply With Quote
Old 11-05-2014, 09:43 PM   #17
harkbrz
Drives: Subaru BRZ 2013
Second that. Brz kit pls
Check Out My Build
harkbrz is offline   Reply With Quote
Old 11-06-2014, 12:02 PM   #18
Steege
Steege's Avatar
Drives: 2013 BRZ Limited
Thirded. lol
Steege is offline   Reply With Quote
Old 11-10-2014, 09:49 PM   #19
mitch t
mitch t's Avatar
I am on it, guys! I will be getting the design done soon, and I am trying to be ready to ship parts in about 2 weeks or so!
The Following 2 Users Say Thank You to mitch t For This Useful Post:
Steege (11-15-2014), whataboutbob (11-12-2014)
Old 11-10-2014, 10:16 PM   #20
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Wish I had this...oh about 1 week ago. Got my first under bumper scratch being neglectful pulling up to a curb in a parking spot. I knew better and still did what I did. I am ordering these!
AVodka14 is offline   Reply With Quote
Old 11-10-2014, 10:22 PM   #21
Natheria
Overlord
Natheria's Avatar
Drives: SWP 13 BRZ, 94 Miata
Bumping with another request for a BRZ compatible version!
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
Natheria is offline   Reply With Quote
Old 11-10-2014, 10:23 PM   #22
AVodka14
AVodka14's Avatar
The protection looks minimal along the anterior aspect of the underside of the bumper. Especially where the fangs are. Is it just me or does coverage seem minimal where the underside of the bumper takes the brunt of scrapes if they happen. May just be the pics...
The Following User Says Thank You to AVodka14 For This Useful Post:
Dipstik-sportech (12-04-2014)
Old 11-11-2014, 01:56 AM   #23
mitch t
mitch t's Avatar
AVodka14,
the plates do project further forward where the fangs are, but only slightly. We went through several revisions on the design, to maximize protection, without exacerbating the problem of striking the ground. I feel that the current revision does a good job.
as a side note, you can see on the MOTOIQ article,
My bumper is damaged in the area you mentioned, but that damage is what prompted me to design the plates in the first place, and I ran low and with no skid plates for like 1.5 years or so
BTW, do you work in health care? i am told that the fangs are actually the Superior Lateral portion of the bumper!
AVodka14 (11-11-2014)
Old 11-11-2014, 12:04 PM   #24
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I just installed the skid plate last week. The guard is located correctly at the lowest point along the leading edge of the bumper, it does not extend out to the fangs. But the fangs are slightly higher than the rest of the bumper and the plate. The scraping damage I have received up to this point are all covered by the skid plate.
Thank you to Mitch, and to Whataboutbob for showing how the skid plate is installed and how it looks.
MTCRX is offline   Reply With Quote
The Following 3 Users Say Thank You to MTCRX For This Useful Post:
AVodka14 (11-11-2014), MysteryMachine (11-11-2014), whataboutbob (11-12-2014)
Old 11-11-2014, 02:13 PM   #25
MysteryMachine
I am wondering that too... especially after seeing this picture - it appears to protect the underside but not the points/corners.
If it could go right up to the actual corner on the body, or even better just a little around the corner, it would protect so much better... right on the corner gets the scratch that is visible!
The Following User Says Thank You to MysteryMachine For This Useful Post:
Old 11-11-2014, 09:00 PM   #26
AVodka14
AVodka14's Avatar
AVodka14,
Thanks for the feedback. I am deciding between these and a lip spoiler. To cover up damage and prevent further damage.
Yes, I am in healthcare. What about anterior superolateral?
Old 11-11-2014, 10:08 PM   #27
mitch t
mitch t's Avatar
Mystery Machine,
I think part of what you are seeing is the difference between an FRS and a BRZ. I got a good look at the BRZ today, and the underside of the bumper has a much larger flat spot for the plates to attach to, so they will end up covering more area, and getting closer to the edge of the bumper. On the FRS, the bumper starts to curve upward much earlier.
MysteryMachine (11-13-2014)
Old 11-11-2014, 10:16 PM   #28
mitch t
mitch t's Avatar
AVodka14,
I hear you on the front lip. There are some good looking ones out there, and I would probably have one too, if I wasn't an autocrosser.
Probably worth noting here that you bring up a good point about my plates. They will not take the place of careful driving, and are meant to help mostly on driveways and rain ditches where the striking point is more the bottom side of the bumper. If you are hitting the front, (as in high, square curbs or parking bricks or posts) they won't be as helpful.
Draco_PR23 (11-12-2014), MysteryMachine (11-13-2014)
MXP Equal Length Header and Dyno (updated fitment with skid plate, second post) Fofofawcett Engine, Exhaust, Transmission 28 09-08-2016 02:35 AM
LED number plate light install Desi Gt86 AFRICA 4 09-01-2014 04:45 AM
Sand/grit on top of skid plate 1Cor10:23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 12-18-2013 12:13 PM
Sand/grit on top of skid plate 1Cor10:23 Scion FR-S / Toyota 86 GT86 General Forum 0 12-18-2013 12:11 PM
86 on Skid Pan rileyrally AUSTRALIA 3 06-04-2012 02:16 AM
