#43 | |
2022 BRZ Build 2013 FR-S Build |
#44 |
Drives: '13 BRZ Ltd
I believe the recommendation from Shiv is to let it idle for 60 seconds after a reflash without touching the throttle pedal.
#45 |
Might pay to wait a little longer if it is apparently still self calibrating.
#46 |
Nah, must be the OTS tune since Freddy says so.
#47 | |
Drives: Passat
In my case there was no settling in time between flashes and pulls but it's a moot point now that s2d4 has everything figured out, as usual. |
#48 |
Drives: '13 FR-S Whiteout
After flashing, isn't it 50 miles for the fuel trims to relearn?
#49 |
It can take A LOT longer than 50 miles for the trims to stabilize, depending on a lot of factors.
Plus, unless the tune was WAY off, it wouldn't drop power like this. It's been confirmed that the car was flashed and basically run on the dyno immediately after startup, so I'm sticking with VVT being disabled.
#50 | |
#51 |
When it comes to fuel trims, it's not so much miles as it is how much time you spend in each trim bucket.
#52 | |
Maybe people who knows about it can chime in.
#53 |
Easy, don't make statements until it's been confirmed.
#54 |
#55 |
@steve99 @BuBlake
Did six 3rd-gear pulls tonight on the highway. Would love to know what you guys think: http://www.datazap.me/u/darksunrise/...e?log=0&data=1 One thing I noticed upfront was that my IAM started off around 0.88, but quickly rose after that. Not sure how long it's been that way.
#56 |
Drives: Passat
When has that ever stopped you? No, I think you nailed it. His MAF needs to be re-scaled and the ECU needs a lot of time to learn those big fuel trim changes caused by the exhaust mods. Although the OP only questioned the possibility that his engine might have been too cold on the post-tune pulls, your assumption that it definitely was too cold must surely be correct since it is your assumption. Bravo. |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
| Stock FR-S/BRZ shock dyno & stock FR-S spring dyno | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 08-07-2014 09:04 PM |
| Stock Dyno vs GReddy Intake Dyno | JTOFJPN | Engine, Exhaust, Transmission | 0 | 06-01-2014 03:56 AM |
| Stock Dyno and Perrin Stage 1 Results | brillo | Software Tuning | 4 | 01-24-2014 08:26 AM |
| FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) | Pure Automotive | Forced Induction | 57 | 03-27-2013 11:41 PM |
