Old 10-03-2012, 10:30 PM   #15
bpracer
Drives: Asphalt FR-S
Originally Posted by Jeff Lange View Post
Pretty much every other Toyota model (save for M14 models like Tundra, Sequoia and Land Cruiser), use 76ft-lbs, but the FR-S uses Subaru studs with a finer thread pitch. 89ft-lbs is correct, as was mentioned.
Jeff
Fine pitch threads take less torque to stretch the stud to its correct clamping force.
Coarse thread takes more torque for the same size stud of the same material. You have less mechanical advantage with coarse threads.
I always put anti-seize on all wheel studs and then you would use less torque. You are not overcoming as much friction to stretch the stud as on a dry thread.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
The Following User Says Thank You to bpracer For This Useful Post:
Tristor (04-16-2018)
Old 10-03-2012, 10:51 PM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I RallyX a WRX on 72 ft-lb lug nuts, so I have no idea why the BRZ requires 89.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 10-03-2012, 11:32 PM   #17
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Sorry, I didn't mean that it required more torque because it has a finer pitch, just that it had a finer pitch. Poorly worded post is poorly worded.
Oh well.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Old 11-04-2014, 07:07 PM   #18
lonborghini
lonborghini's Avatar
Drives: '15 red FR-S SSC
Originally Posted by #87 View Post
Don't worry if you service at the dealer you will get at least 200 ft/lb. More is better right?
Wrong. Over torquing damages the fasteners by stretching them and damaging the threads. Would you rather have your wheels fall off because the lug nuts were under torqued and fell off because the wheel studs broke? Either way it's messy.
lonborghini is offline   Reply With Quote
Old 11-04-2014, 07:11 PM   #19
8R6
8R6's Avatar
Drives: FRS
Originally Posted by sarcasm
hi. nice to meet you.
Originally Posted by 2012
hi! me too!
8R6 is offline   Reply With Quote
The Following 6 Users Say Thank You to 8R6 For This Useful Post:
BrightSlide (05-28-2017), endless_pain (11-16-2015), gramicci101 (11-04-2014), kster1 (11-04-2014), Phaedrus29 (11-04-2014), wparsons (11-05-2014)
Old 11-04-2014, 07:11 PM   #20
gramicci101
Off Topic
2012? #87 hasn't posted since June of 13, and the post you corrected was sarcasm anyways.
edit: Beaten to the punch. Curses.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
8R6 (11-04-2014), Chimera (04-12-2018), wparsons (11-05-2014)
Old 11-05-2014, 07:59 AM   #21
wparsons
wparsons's Avatar
I find it strange that the torque spec for WRX's is much lower than 89, despite running the exact same studs, hubs, etc.
Since swapping to ARP studs and Muteki AR48 lugs I've been torquing to 80ft/lbs. The Muteki packing suggested 75-85, so I went with the middle. Zero issues with them backing off over time.
flickr
Old 11-05-2014, 11:52 AM   #22
8R6
8R6's Avatar
Drives: FRS
did you swap out the studs for any particular reason? longer length? stock ones broke? etc.?
just curious, cuz thats one of the things on my "50/50 should i do or not" list. lol
The Following User Says Thank You to 8R6 For This Useful Post:
Old 11-05-2014, 11:54 AM   #23
wparsons
wparsons's Avatar
Broke a couple stock ones, and wanted the option of spacers up front to get to the camber setting I wanted (-2*). Turns out I didn't need spacers, but I'm glad I swapped the studs anyway.
Fronts are really easy to do, just pull the wheels, calipers and rotors off and you can swap them with the hub in the car. Rears you'll need to pull the hubs.
I pull my wheels before every autox/track event, so the better studs will be cheaper in the long run instead of constantly replacing the stock ones.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
8R6 (11-05-2014), DAEMANO (11-05-2014)
Old 11-05-2014, 01:57 PM   #24
wbradley
Sarcastic SOB
wbradley's Avatar
I thought I saw 78 ft/lbs somewhere.
The '15 WRX is 89.
Old 11-05-2014, 02:14 PM   #25
DAEMANO
Time Traveller
Do the rear hubs have to come off with 50mm (Nismo lenght) studs as well or just the 60mm ARP extendeds? Reason I ask is that I have both 50mm and 60mm extended studs and if I can save any time on the install by putting the 50mms in the rear I'll do that.
Old 11-05-2014, 05:09 PM   #26
wparsons
wparsons's Avatar
I don't think you can sneak the 50mm nismo ones in, but I could be wrong. I know there's no chance in hell the ARP ones will get in.
flickr
Old 04-16-2015, 06:01 PM   #27
Skegrider
Skegrider's Avatar
Drives: 2015 BRZ Sport Tech 6 spd
Would 90lbs still be fine with after market wheels? I have a set of TSW Bardo's installed. Thanks.
Skegrider is offline   Reply With Quote
Old 06-27-2016, 05:24 PM   #28
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i was browsing and brought this up from old thread.
i always torqued to 80 lb and had no issue.
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 04:10 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 02:04 PM
What's the reason for Torque dip in BRZ Dyno ? yuli8466 Engine, Exhaust, Transmission 82 06-23-2012 07:06 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 09:33 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
