Old 11-04-2014, 09:28 AM   #1
DarkSunrise
DarkSunrise's Avatar
Near Stock v. OFT Stage 2 Dyno
Just reporting the results of some dyno testing.
Runs 1 & 2 were with:
- stock tune
- Perrin non-resonated CBE
Runs 4 & 5 were with:
- OFT Stage 2
- JDL catless UEL header
- JDL overpipe
- Magnaflow catted/resonated FP
- Perrin resonated CBE
- K&N drop-in
The baseline runs were really promising, making 177 whp with just an exhaust. (I was told stock cars usually dyno around 165 whp on this dyno, so maybe all the track days broke in the engine well.) But the stage 2 runs were disappointing, making only 178 whp.
One thing to note: We literally installed the parts and put it straight on the dyno, so not sure if the ECU needs time to adapt maybe? @Shiv@Openflash
Or the exhaust components need time to break in, not sure. Or perhaps the coolant temps dropped out of optimal. There's a lot of possible explanations, so probably best not to jump to conclusions yet.
The good thing is it sounds amazing. I was worried about how loud it would be, but it's actually pretty tame. Slightly louder than before, but with a muted rumble to the sound. I've been driving around the past few days just listening to the exhaust purr.
I'm going to take the car to the track this weekend and properly put it through its paces.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Cop (11-05-2014), Steve201brz (11-07-2014)
Old 11-04-2014, 09:33 AM   #2
J_kennington
Drives: 2013 asphalt scion FRS
Most definitely needs time to adjust after a flash.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
The Following User Says Thank You to J_kennington For This Useful Post:
MisterSheep (04-27-2016)
Old 11-04-2014, 09:57 AM   #3
jdmblood
jdmblood's Avatar
Drives: white subaru brz
not really likely that all of those mods only added 2 hp
jdmblood is offline   Reply With Quote
Old 11-04-2014, 09:58 AM   #4
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Give the car 100 miles to learn the fuel trims etc, then dyno again.
Triumphrider is offline   Reply With Quote
Old 11-04-2014, 10:04 AM   #5
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I just recently got the OFT and def give it some more time to learn. I flashed before starting my 6 hour drive and thought hmm this is nice. Two hours later I was like F*ck Yeah
177 is the highest ive seen for a stock car. Not believing you only gain 2hps.
And you should get E85 in there, if you have access to it
GotBRZ1691 is offline   Reply With Quote
Old 11-04-2014, 10:16 AM   #6
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Have you tried getting a real tune specifically for your mods? You will see much better gains for sure..
Generic tunes are always going to be conservative and not be able to take full advantage of mods, that's just there nature.
Also, take actual numbers (IE the 177rwhp starting point) with a grain of salt, every dyno will read differently and vary day to day. The same car could make 155hp on one dyno and 175hp on a different dyno a week later. The 4000rpm area looks to have seen some gains at least..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Fast_Freddy (11-05-2014)
Old 11-04-2014, 10:36 AM   #7
jvincent
jvincent's Avatar
To the OP, the ECU definitely needs time to learn.
The actual numbers really don't matter, just the relative change.
Old 11-04-2014, 10:46 AM   #8
ja1217
Drives: 2004 Toyota RAV-4 5M
Just curious if this was this Brady's dyno at Pure Automotive Performance? If so, I'd definitely agree that the track days can help break the engine in. I dyno'd there at 181whp with stock tune, stock exhuast, and just a K&N drop in filter. Conditions were pretty much ideal that time (cool November air, much like your dyno was, I'd imagine). Dyno'd again earlier this summer when I got a tune under more humid conditions and only got 177whp stock, 185whp tuned (Delicious Tuning, still stock exhaust).
That's disappointing about only getting 2whp out of the tune and exhaust mods. I'm planning on doing similar mods this winter and hoping to get up around 200whp, but we'll have to see. Hopefully giving the car a chance to learn it will pick up some more power.
Also, you said you are taking it to the track this weekend. Are you the other FR-S signed up for Summit Point Main with NASA Mid Atlantic? If so, I'll see you there. I'll be running in Time Trials.
ja1217 is offline   Reply With Quote
Old 11-04-2014, 11:03 AM   #9
akyp
Drives: 2012 86
I believe OFT stage 1 alone adds 3-5hp to bone stock cars so I would be disappointed too.
akyp is offline   Reply With Quote
Old 11-04-2014, 11:27 AM   #10
tennisfreak
Drives: 2018 BMW M240i
Give the ECU time to adjust?????
Isnt the point of a tune to change your ECU to work with the mods???????????
I'd be freaking pissed and demand a refund if a stage 2 tune gave me 3 whp with that list of mods.
No waiting on a ECU learning period, something is wrong with that tune.
The Following User Says Thank You to tennisfreak For This Useful Post:
Old 11-04-2014, 11:27 AM   #11
tennisfreak
Old 11-04-2014, 11:52 AM   #12
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
If you're WOT it's closed loop
Sent from my OnePlus One
drewbot is offline   Reply With Quote
Old 11-04-2014, 12:26 PM   #13
wootwoot
Drives: FRS
Lol... So much butt is hurt in this thread its hilarious....
Why would you not contact Shiv before doing anything else? I would have called him from the Dyno. He stands behind what he does and will sort this out, but at least give the guy a chance before you make a public thread bashing his livelihood.... Damn.
Also, the area under the curve looks like you picked up good power to me.
The Following 6 Users Say Thank You to wootwoot For This Useful Post:
Bimble Bamble (03-13-2015), chas3wba0 (11-05-2014), DAEMANO (11-06-2014), Pseud0logik (11-15-2014), ramiram1984 (11-05-2014), Triumphrider (11-04-2014)
Old 11-04-2014, 12:27 PM   #14
DarkSunrise
Some good comments on here. One thing I want to caution is not to jump to conclusions too early. The car went straight from lift to dyno and the engine hadn't been run in about 2-3 hrs. Could be a number of explanations, which I'm hoping Shiv or other tuners can shed some light on.
Yeah I was a bit disappointed, was expecting to see 10-15 whp gain at least. It's cool though, just hoping it's a fluke and now trying to figure out what's going on.
Yeah I'll probably re-dyno after my track days this weekend. Not fun having to spend money for another dyno session, but would rather know for certain what's going on. I will say, the butt dyno feels like there were some gains in the top end at least.
Also 177 whp is pretty high for sure, but it was repeatable. Looks like ja1217 was saying he dyno'd at 181. I think these engines gain a decent amount of power after breaking in at the track.
Yeah custom tune will be my next step if I don't see any improvement on the next dyno. I might just have the unlucky combination of engine/parts that doesn't match well with OFT.
Yep will shoot you a PM.
Thanks, that makes me wonder if it had to do with coolant temperature then.
2022 BRZ Build
2013 FR-S Build
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 10:04 PM
Stock Dyno vs GReddy Intake Dyno JTOFJPN Engine, Exhaust, Transmission 0 06-01-2014 04:56 AM
Stock Dyno and Perrin Stage 1 Results brillo Software Tuning 4 01-24-2014 09:26 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-28-2013 12:41 AM
