Old 11-03-2014, 12:28 PM   #393
Aktane
Drives: 2013 Scion FR-S Hot Lava OFT Tuned
Shiv@Openflash:
Did you remove the 2.06 Off-The-Shelf from your Open Flash Tablet site?
I am using them, and wanted to recommend to a friend but all I'm seeing is the V1.59 Maps.
Is something wrong with them? Or just temporary?
Others:
When I was driving yesterday testing out the map my IAM was 1.0 for most of the low speed drive but once I accelerated in a higher gear at low RPMS and it dropped to .88, and settled at .82, is that bad?
Will it go back up if I keep driving? ECU probably has about 1-2 hours of driving on it, mostly under 50 mph, until this last run where it dropped.
Thanks!
Akshay
Aktane is offline   Reply With Quote
Old 11-03-2014, 12:57 PM   #394
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi,
The v2.06 maps are definitely available for download: http://openflashtablet.com/Automotiv...ads/index.html
Also, it's totally fine for the IAM to move around from time to time. I would only be concerned if it routinely dropped below .60. To me, a IAM that stays stuck at 1.00 indicates a map that may be too conservative, leaving good power on the table.
Originally Posted by Aktane View Post
Shiv@Openflash:
Others:
Thanks!
Akshay
Shiv@Openflash is offline   Reply With Quote
Old 11-03-2014, 01:43 PM   #395
Aktane
I see them there now, at the bottom! Awesome, I will certainly pass the news along to my friend as well. Thank you for the quick reply, sir.
I'm also remembering back and the gas in my car might be from the boonies from when I took a trip, so hopefully filling it up with some better stuff soon...
Originally Posted by Shiv@Openflash View Post
Hi,
Old 11-03-2014, 04:51 PM   #396
benlaz88
Drives: 2013 Asphalt FRS
@Shiv@Openflash,
I have a question about my OFT. My CAL id show as A01C however when i plugged my OFT into my car it show B01C under the ECU info. I have the file loaded as A01C tune onto the OFT from OFM. Its wasn't like this before after i updated my OFT from OFM and downloaded the newest tune. Right now i have the A01C tuned loaded onto my car and start up fine. Has anyone notices this or is it only me? Should i worry about this?
Thanks
Ben
benlaz88 is offline   Reply With Quote
Old 11-03-2014, 04:57 PM   #397
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by benlaz88 View Post
@Shiv@Openflash,
Thanks
Ben
This is normal. With the v2.x maps, your internal CAL ID has actually been updated to B01C.
Old 11-03-2014, 05:03 PM   #398
benlaz88
Ok, so when i upload my new tune, i should loaded as B01C or i can still use the A01C?
Old 11-03-2014, 05:13 PM   #399
Shiv@Openflash
Drives: 2013 FRS
You should still pick your original A01C Cal ID. In fact, OF Manager won't let you pick anything else.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
benlaz88 (11-03-2014)
Old 11-04-2014, 07:30 PM   #400
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
@Shiv@Openflash
Hello Shiv, i am just sharing my datalogging i had today.
when i flashed when v2.06 out, i had IAM .98
I tried different gas and it's reading IAM 1
http://www.datazap.me/u/zc06kissther...ta=1-6-7-10-11
worth every penny spent on OFT
Old 11-05-2014, 01:59 PM   #401
cliffm
Is it possible to use an oft tune with E0 89?
cliffm is offline   Reply With Quote
Old 11-05-2014, 06:23 PM   #402
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
OFT v2.06 Non-Beta
Are you saying ethanol free 89 octane? Definitely not. Lowest octane that is compatible with the OFT (as well as our car) is 91 octane
Kronos is offline   Reply With Quote
Old 11-05-2014, 06:54 PM   #403
Turdinator
Señor Member
Turdinator's Avatar
The tunes Shiv created would not be a good idea on that fuel. You could however alter the his tunes to work yourself. You would have to lessen the spark advance and possibly the AFRs. I am not sure why you would do this unless you were unable to by the proper fuel in your area.
1974 TA22 Celica
2013 86 GT
Old 11-05-2014, 09:28 PM   #404
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
So my cars CAL ID is B01C and so are all the tunes on my OFT, as it came from Shiv.
trying to change out St 2 EL for St 1 93OCT and when I select the bin file, it says wrong checksum or something like that? Still reading and trying to find a fix.
GotBRZ1691 is offline   Reply With Quote
Old 11-05-2014, 09:37 PM   #405
cliffm
I didn't think one would work.. We have Ethanol Free 89 + 87, 89, 93 and 100 octane here. I usually run 93 with the Stage 1 91 tune. I'm running the stock tune with ethanol Free right now just for fun. My car seems to hum along and sounds much quieter with ethanol free.
Old 11-05-2014, 11:27 PM   #406
steve99
Drives: FT86
if you have not edited tune then just say yes correct checksum and all good
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
