Old 11-03-2014, 02:24 PM   #729
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Originally Posted by sweetfrs View Post
quick question guys i run 18x8.5 in the front and 18x9.5 in the back, but i want to do some drift days so would it be ok to take the rears off and throw on my stockers and drift?
Yes. Should not be an issue as long as your front don't rub
Ryaquinn is offline   Reply With Quote
The Following User Says Thank You to Ryaquinn For This Useful Post:
sweetfrs (11-03-2014)
Old 11-03-2014, 03:40 PM   #730
mrbbs
Drives: GT86
Had some more fun on the Ecuyers track in France, this time in the dry:
[ame="http://www.youtube.com/watch?v=7BmuVEDOENc"]Toyota GT86 @ Ecuyers (rally style) - YouTube[/ame]
Front tires: Conti SportContact 5
Rear tires: standaard Michelin Primacy HP
OS Giken LSD
stripped 40kg out from standard
Cusco 4.556 FD
mrbbs is offline   Reply With Quote
The Following 2 Users Say Thank You to mrbbs For This Useful Post:
Koa (12-06-2014), sittinSideways (11-08-2014)
Old 11-04-2014, 01:39 PM   #731
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
@slava
So do you just remove the sway bar and endlinks for track events or do you have it removed full time meaning it's not on the car when you daily it?
I'm used to the no sway bar thing with the S chassis and stuff for people running stuff like MAX kits or even wisefab stuff but you're the first I've heard of doing it on a street driven zn6.
I had thought about doing it a while back but with the somewhat low spring rates up front with the standard STANCE coilovers, I figured it wouldn't work as well as intended.
Old 11-04-2014, 10:39 PM   #732
slava
slava's Avatar
Drives: brZed
Originally Posted by TylerLieberman View Post
@slava
I don't really daily the car anymore persay, I do drive it like once a week though. Sway bars always off. Car doesn't feel much different on the road without it, though I have 8k 9k springs.
slava is offline   Reply With Quote
Old 11-10-2014, 10:15 PM   #733
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Originally Posted by slava View Post
I guess it really depends on ur current setup? Hows ur dampening and spring rates? Knuckles?
Sorry I missed your reply.
I have the PSM coils so 8/6kg. I want to replace the springs and go 10/10 though. Still on OEM knuckles.
Car is back together but I don't have the end links connected as they were hitting the base of my coilovers on lock.
Haven't slid the car yet but it seems to drive fine.
I was going to buy adjustable end links but based on the positively on running no sway bar, I might hold off and possibly remove it.
JordanWho is offline   Reply With Quote
Old 11-11-2014, 05:38 PM   #734
2014scionfrs
2014scionfrs's Avatar
Drives: 2014 Scion FR-S
sway bar removal
I removed my front sway bar and the car drives so fuckin good now. No more endlink bind, so not only did it free up steering, but I'm actually able to hold and use all the angle. Shit is amazing.
Im having a hard time understanding why removing the sway bar helps your drift? Dont most drifters put big thick sway bars on their drift cars?
2014scionfrs is offline   Reply With Quote
Old 11-12-2014, 12:37 AM   #735
slava
slava's Avatar
Drives: brZed
The car is way less snappy without it. Also this
Originally Posted by Knshro13 View Post
the factory sway bar is connected via the strut so eventually binds as you increase steering. That is because of the design of a macpherson strut. It turns too.
the best option is to increase front spring rates and to remove the sway bar. you will free up steering and the car will be more predictable in-transition.
The Following User Says Thank You to slava For This Useful Post:
2014scionfrs (11-14-2014)
Old 11-13-2014, 06:58 AM   #736
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
would it be too crazy to actually attach the sway bar link to the lower control arms instead of the strut case?
thats crazy that it binds even with stock knuckles.
Shinchu is offline   Reply With Quote
Old 11-13-2014, 09:50 AM   #737
illmattic
illmattic's Avatar
So for clarification, would removing the sway bar help this car drive better even with stock steering and just the basic Stance coil setup? Or is it something to look into once knuckles and stiffer springs are fitted?
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 11-13-2014, 11:31 PM   #738
Shinchu
Shinchu's Avatar
stance coil? you mean stance coilovers and everything else stock?
i think the key thing to remember here is... if you remove the front sway bar, you need to seriously increase your spring rate (looks like 8kg is ok but 10kg would be better) because now your springs are handling the body roll by themselves without the help of the anti-sway bar.
NOT THE STRUT TOWER BARS, PEOPLE!!!! god kills a kitten every time these internet drifters confuse sway bars with strut bars, i swear...
so yeah. remove sway bar for full counter without binding. seems even stock, they bind when you are low AF on coilovers.
thats why i am wondering if we can somehow relocate the swaybar links to bolt on the lower control arms instead of the stock location on the strut cases.
also...
CHECK THIS SHIZZ OUT!!!!!
http://www.partsshopmax.com/page.php?59
FLCA and FULL SET of rear arms coming soon!!! WOW look how straight those axles are!!!!!
love me some PBM...
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
The Following 2 Users Say Thank You to Shinchu For This Useful Post:
2014scionfrs (11-14-2014), shifter907 (11-14-2014)
Old 11-13-2014, 11:56 PM   #739
Shinchu
Shinchu's Avatar
yup.
PBM for President.
http://www.partsshopmax.com/e107_plu...c.php?10166.10
2014scionfrs (11-14-2014), slava (11-14-2014)
Old 11-14-2014, 05:48 AM   #740
JordanWho
JordanWho's Avatar
The most promising info we've had on this issue.
The Following User Says Thank You to JordanWho For This Useful Post:
Old 11-14-2014, 09:09 PM   #741
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
From last Wednesday's Sonoma Drift. They ran a special setup that was meant to be a replica of Meihan Sportsland in Japan.
WORKS is offline   Reply With Quote
Old 11-14-2014, 11:34 PM   #742
Shinchu
Shinchu's Avatar
i pass by the Powered by Max shop every day to/from work, so i will stop by when i get back from deployment to ask if they can just weld a stud on the factory lower arms for the sway bar.
that way we dont need the entire angle kit just to stop the link from binding on the strut.
if so, there will be much rejoice!
*or we could just ask on their forum?
http://www.partsshopmax.com/e107_plu...c.php?10166.20
also they just posted installation pics of their hydraulic hand brake in the owner's FR-S!
The Following User Says Thank You to Shinchu For This Useful Post:
JordanWho (11-14-2014)
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
