Old 11-03-2014, 11:19 AM   #29
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by Hawaiian View Post
it's not to preserve lifespan, but rather to give you full power under WOT.
Actually, its 2 different features for 2 different objectives
1) The compressor disengages at high RPM, because the compressors are not designed to operate at full engine RPM.
2) It also disengages at WOT, regardless of engine speed. As you stated, this reduces engine load when you call for max power (WOT).
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
jdubz13frs (11-03-2014)
Old 11-03-2014, 01:52 PM   #30
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Holy thread necro.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 11-03-2014, 03:06 PM   #31
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Yes, yes, I hate it too since it bogs down the engine
FyeaFRS is offline   Reply With Quote
Old 11-03-2014, 03:09 PM   #32
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Holy thread necro.
From yesterday?
murdoc is offline   Reply With Quote
Old 11-03-2014, 04:04 PM   #33
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by murdoc View Post
From yesterday?
From 2012. This is a very old thread.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
Hawaiian (11-04-2014), murdoc (11-03-2014)
Old 11-03-2014, 05:12 PM   #34
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Would have made more sense if he quoted the original necro bump.
Old 11-03-2014, 05:24 PM   #35
subbed!
Old 11-03-2014, 07:56 PM   #36
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Indeed it's an old thread. I resurrected it because A) it's completely relevant, and B) it's number one on Google if you search for "frs air conditioning defrost dumb feature"
pushrod is offline   Reply With Quote
Old 11-03-2014, 08:25 PM   #37
westendRIOT
Drives:
Annoying that the AC light stays dark even though the compressor is running in defog mode. Where I come from, "off" means "off"
westendRIOT is offline   Reply With Quote
Old 11-04-2014, 07:44 AM   #38
pushrod
Benched 86lb
pushrod's Avatar
Turns out my approach is imperfect: the condenser fan still runs.
lol
Old 11-04-2014, 09:02 AM   #39
CoupedUpSubie
Drives: 2013 BRZ Limited
It is actually more beneficial for any refrigeration system to run on occasion then sit. It helps keep moisture out and the seals wet so they don't fail. I would hate to have to buy a new A/C compressor a couple years down the road.
Someone said something about electrical load. The only electrical load the compressor has is the small amount for the clutch, the rest is the mechanical load of compressing something to upwards of 400 psi.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 11-04-2014, 09:03 AM   #40
The great part is everybody will disconnect it and then we will start getting all sorts of posts that say "windshield keeps fogging up what can I do?".
billwot (11-05-2014), CoupedUpSubie (11-04-2014), extrashaky (11-05-2014), flippy (11-05-2014), Ultramaroon (11-04-2014)
Old 11-04-2014, 01:05 PM   #41
I hear that from women all the time. So depressing.
Old 11-05-2014, 11:44 AM   #42
billwot
High side operating pressure for a 134A system will typically be around 200-225 on a 90F day. But the low side will still be about 30, so the actual pumping load (pressure differential across the compressor) will be about 175-200. The system high pressure switch is probably set at 250, maybe 300.
I agree with the rest of your post.
CoupedUpSubie (11-05-2014)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
