Old 11-03-2014, 10:36 AM   #15
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
Originally Posted by toast View Post
I love your A pillars, but that trunk unit is a deal killer for me. Everything in it, even the spacers look like they are built out of 3/4" MDF? Thing must weigh a hundred pounds, all behind the rear wheels.
The things that are 3/4" mdf is the main top baffle and the baffle/spacers that the sub sits in. and a few very small small strips that prop up the spacer for the front floor. Everything else, including the top floor, trim, etc, is out of 1/2" or 3/8" mdf
as far as how much it weights, quite light actually, remember i was able to build it all out of the car and by myself, easily lift the whole thing into the car as a whole piece. i would guestimate this whole thing:
is roughly around 30-40lbs at the most, it was quite easy getting it into the trunk. i would say on the whole, net weight gain for this install in the back is maybe 30 lbs. keeping in mind that the spare tire, while a donut, is not that light. infact, i would venture to say that a rear ward facing mdf box with a sub and amps sitting above the floor would add just as much weight to the car.
besides, is 30 lbs extra right behind the rear axle really too terrible for a car with 53/47 stock weight distribution?
Mobile Electronics Magazine Top 100 Installer 2012-2013
simplicityinsound is offline   Reply With Quote
Old 11-04-2014, 11:07 AM   #16
toast
Drives: 14 BSP Edelbrock BRZ
I'll take your word for it. Just looking at it, it looks heavy as hell.
No doubt it isn't much heavier than having a big sub box and the weight of the spare tire.
toast is offline   Reply With Quote
Old 11-04-2014, 03:01 PM   #17
labskaus
labskaus's Avatar
Drives: Toyota GT86
What name does the vinyl have you use on a-pillar? The struktur looks very nice
labskaus is offline   Reply With Quote
Old 11-05-2014, 12:24 PM   #18
Koa
What beautiful fab and system. Hats off to you guys for going above and beyond to deliver such a stellar package.
Check out Simplicity in Sound's Arc Audio build in my Crystal! NorCalGirl Electronics | Audio | NAV | Infotainment 4 05-20-2014 05:54 PM
RD Audio And PHD Amps! High Quality Sound!!! kmbkk Audio/Visual, Electronics, Infotainment, NAV 3 12-31-2013 09:44 AM
My Install from Simplicity in Sound jlu Northern California 4 06-08-2013 10:20 PM
My Install from Simplicity in Sound jlu Electronics | Audio | NAV | Infotainment 3 06-05-2013 05:24 PM
brianlo622's SQ build log by Simplicity in Sound |Illusion|Arc|Mosconi|Audiomobile| brianlo622 Electronics | Audio | NAV | Infotainment 24 05-01-2013 12:38 PM
