Old 11-01-2014, 05:06 PM   #2059
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Size:  43.4 KB I got this error when I am trying to read the ECU for the first time. I followed all the steps on the video by shiv.
904FRSlow is offline   Reply With Quote
Old 11-01-2014, 05:37 PM   #2060
Kodename47
Kodename47's Avatar
Drives: UK GT86
STOP - you may be using wrong definition for your tune file. For V2 OFT tunes you must use defs that come with the tune download file, do not use the V1.5 defs.
It's because of this that I feel the OFT needs to start properly knowing ROM compatibility rather than hacking ROMs to suit the OFT. It seems overly complicated if you're not familiar and with more and more people editing it's only going to lead to more bricked ECUs. Surely just basing the compatibility on the ROM series (last letter) should be adequate?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-01-2014, 07:20 PM   #2061
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Haha thanks for your concern steve, but I am certain that I am using the correct definitions. I've edited and flashed and reflashed my ecu many times xD With your knowledgeable posts as help of course!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 11-01-2014, 07:23 PM   #2062
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
^^ Yup.
Td-d is offline   Reply With Quote
Old 11-01-2014, 07:26 PM   #2063
Td-d
The symptoms you describe are of a definition that is incorrect. The consequence of editing the rom using an incorrect definition can range from poor running at best, to bricking at worst. Double check your definitions, checksum correction would not change table values at all - sits in a completely different part of the rom.
Old 11-01-2014, 07:37 PM   #2064
steve99
Drives: FT86
Originally Posted by 904FRSlow View Post
Attachment 94848 I got this error when I am trying to read the ECU for the first time. I followed all the steps on the video by shiv.
DME is bmw ecu i think you have not selected Toyota and gt86 as vehicle type and the OFT thinks your car is a bmw
Old 11-01-2014, 10:24 PM   #2065
904FRSlow
904FRSlow's Avatar
I did select 86
Old 11-01-2014, 11:13 PM   #2066
steve99
Drives: FT86
I did select 86
Thats weird
no locked ecutek or brzedit tune previously ?
oft has lastest updates ?
if so then contact vishnu guys something weird going on
Old 11-01-2014, 11:44 PM   #2067
904FRSlow
904FRSlow's Avatar
Thats weird
Will do Monday. I think it might be because my halos are connected to the ignition so they stay on as drls
Old 11-02-2014, 12:30 PM   #2068
eddieflyinv
eddieflyinv's Avatar
weird experience for me just now..
after doing some reading i figured id try the OTS stage 1 93octane tune with the Ultra94 thats in my tank right now, flashed the ecu, did the turn key on off thing about 5 times, started the car (cold start) and let it run for about 5 minutes,
got in the car and gave it just a little blip of the throttle, and when it came back down to idle the idle dipped around 4-500 and sounded like the engine was gonna die, i let it run for a bit longer, tried to move the car forward and the moment it was under any load it started to die (mind you i generally bog a bit on takeoff)
im reflashing right now back to my stage 1 91 tune
was this occurrence due to me flashing the ecu while the engine was cold ? or is it the fuel ?
ive only gone through 1/8th+ of a tank of the 94 since filling it up last night, but considering reflashing resets everything it shouldnt matter how long ive run the fuel right ?
i had set up the datalogging before even starting the car so i could see what was going on during my drive (maybe that datalog is worth sharing to the pros?)
BTW the flash file when viewed on the OFT when selecting which one i wanted to upload, had an * at the very end of the selection box.. not sure what that was about, it was the correct file for my ecu 700C, but figured id share that as well.
eddieflyinv is offline   Reply With Quote
Old 11-02-2014, 07:36 PM   #2069
troek
troek's Avatar
Drives: 2012 Toyota 86
mine did this when i flashed to the latest tune too. it learned it self out of the system after a few hundred miles. i would guess it has to do with fuel trims, as if i flash with my updated maf scale, it dosnt happen.
troek is offline   Reply With Quote
Old 11-02-2014, 09:08 PM   #2070
s2d4
s2d4's Avatar
Abort! Abort!
Old 11-02-2014, 10:58 PM   #2071
eddieflyinv
Originally Posted by s2d4 View Post
Abort! Abort!
I did! Lol, not gonna try that tune ever again 😬
Old 11-13-2014, 09:46 PM   #2072
ChuckButta
Drives: 2015 FRS RS1
So i am new to this whole tuning talk and i have been reading this thread and many others on the forums. the more i read the more questions i come up with.. So i was wondering if someone could tell me which file i should use to flash when i actually purchase the OFT.
I have a 2015 FRS RS1, only mods will be GrimSpeed Cold air, Open Flash Header, running 93 oct fuel.
I understand that each car is different etc etc, but my question is which file should be loading on my first go round ?
sorry for the newb question, but i am just learning about all this and there is soooo much info it can be tuff to make sense of it all.
Thanks in advance!
ChuckButta is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
