View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 334 79.15%
No (Please only vote after you have 300 miles or more on the odometer) 88 20.85%
Voters: 422. You may not vote on this poll
Old 10-30-2014, 09:02 PM   #197
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
i'm at 17,000 and have not heard the crickets yet. does it depend one when you bought the car? i bought in may 2013
lionbacker54 is offline   Reply With Quote
Old 10-30-2014, 09:26 PM   #198
kberkel
kberkel's Avatar
Mine is a 2013.. I could be wrong, but I think it depends somewhat on Gas? I've never thought enough to notice differences between gas stations.. but sometimes it isn't there at all.. so maybe?
kberkel is offline   Reply With Quote
Old 10-31-2014, 09:42 AM   #199
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I bought a used 2013 Limited BRZ. I can only hear chirping at idle after the car's RPMs have gone down to ~700rpm, and even then it's very hard to hear.
carma143 is offline   Reply With Quote
Old 10-31-2014, 12:09 PM   #200
White&Nerdy
Drives: 2015 Subaru WRX
I have crickets at idle, but they go away as soon as I give it more gas. I have almost since the car was new (7600 miles now).
White&Nerdy is offline   Reply With Quote
Old 10-31-2014, 01:06 PM   #201
srizzors25
Daedalus Moto
srizzors25's Avatar
Mine started making the noise around 1k miles. Audible under 1200rpms or so, idle almost all the time except for when the car is cold. Goes away as soon as I touch the gas.
Originally Posted by Stang70Fastback View Post
But hey, if they ever put out an updated fuel pump I'm sure it would make my list of things I'll eventually buy for the car.
You would hope that if someone comes up with something Subaru would volunteer to do it under warranty lol. Thinking about calling the dealer and see what they say here as well
Old 10-31-2014, 03:54 PM   #202
Blastersix
6,600 miles on the clock. Started around 500 miles. Took it to the dealer, they said "it was normal". WTF.
Blastersix is offline   Reply With Quote
Old 11-01-2014, 07:27 AM   #203
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
My car started now after 17000 km. Is there a fix for it yet. Bit hard to scan through 2 years of posts.
GeeTee86 is offline   Reply With Quote
Old 11-01-2014, 09:03 AM   #204
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
I am on my third fuel pump from Subaru. My car has 14k on it. You would think the new 15's wouldnt have this issue, but they have yet to permanently fix it.
FloridaBRZ is offline   Reply With Quote
Old 11-01-2014, 10:11 AM   #205
CoupedUpSubie
Drives: 2013 BRZ Limited
I just had mine replaced, no chirping yet but only a couple hundred miles on it.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 11-01-2014, 11:01 AM   #206
extrashaky
Drives: 2014 BRZ Limited
Because it is normal.
No. To sum up:
Ethanol doesn't consistently make a difference. Some non-ethanol gas gets rid of the crickets. Some doesn't. Most 10% fuels result in crickets. Some (usually off-brands) don't. Some E85 gets rid of the crickets, but people have reported crickets on E85. Even if you find a gas station that sells gas that doesn't give you crickets, that may change when the weather changes and the station switches blends.
Some people have had good luck with putting Lucas upper cylinder lubricant in their gas. Some have not.
Some have had good luck with putting ashless TC-W3 oil in their gas. Some have not.
Most who have had their fuel pumps replaced under warranty have had the crickets come back. Those who haven't probably will.
Toyota tried insulating the pump with sound deadening material. Apparently that caused heat issues that made the crickets worse.
You can chase cricket-free gas all over the place. You can try additives. You can replace the pump. In the end, though, it's most likely going to be just a lot of wasted time and energy attempting to change a sound that is normal for a high pressure fuel pump.
The Following 4 Users Say Thank You to extrashaky For This Useful Post:
GeeTee86 (11-01-2014), Side (02-07-2016), SmileyMe (12-31-2015), strat61caster (11-01-2014)
Old 11-01-2014, 01:35 PM   #207
GeeTee86
86 Nut
GeeTee86's Avatar
Then it is what it is. Thanks
Old 11-01-2014, 06:49 PM   #208
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
@extrashaky
Forgot that some people have their crickets go away as the the car gets run in, haven't heard mine in over a year and 20k miles.
Old 11-03-2014, 11:44 PM   #209
metier
Drives: 2015 Subaru CWP Series.Blue
I'm in the group that thinks it depends on what gas you use. I have a series.blue and for the first 6500-7000 miles I used mostly Shell and Chevron gas, and had the crickets. For the last couple of months used Shell only and the crickets where gone. This past weekend I filled up with Chevron and the crickets are back. I'm going to go back to shell gas for the next couple month and see if the crickets leave, again.
metier is offline   Reply With Quote
Old 11-04-2014, 07:26 AM   #210
Ursam
Drives: 2014 SSM BRZ
I'm at 4800 miles on my 2014 Limited and never heard the crickets yet. But I guess they can always show up down the road.
Ursam is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
