Old 10-30-2014, 07:16 PM   #1
BRZUK
Drives: GT86
Tricky question
Hi guys,
I want to know if this idea would work, on the stock dash you have you Fuel gauge,water temp,rev counter with LCD display of speed and your speedo.
Would it be possible to remove this item take it apart and remove the speedo and the needle and fit a gauge may it be MAF,Oil whatever?
Thank you.
BRZUK is offline   Reply With Quote
Old 10-30-2014, 07:18 PM   #2
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Not sure, but Perrin makes a gauge mount that covers the view of the analog speedometer and you can put a gauge in the left side fan enclosure if you so desire.
Old 10-30-2014, 07:28 PM   #3
BRZUK
Drives: GT86
I like the gauges in the side vent but i am looking for simple and clean and want one in the vent and if possible 2 in the speedo i have seen the one you mean but i just don't like the way it sticks out.
Old 10-30-2014, 07:50 PM   #4
Bigbadvoodooguru
Drives: 2014 asphalt FRS
It is a circuit board back there, and I believe one single piece. You're not going to be able to remove a section of the board.
You COULD block out all the light coming from the speedo (put something in front of the circuit board), then cut out the speedo fascia and do whatever you want there, but i don't think you'd have enough room behind to make them sit flush to the tach (aforementioned circuit board is sitting there)
Bigbadvoodooguru is offline   Reply With Quote
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
Question SwaggyB Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-06-2014 12:10 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
Reverse to First tricky FRiSson Issues | Warranty | Recalls / TSB 11 11-26-2012 08:19 PM
a question about tax... pr086 Scion FR-S / Toyota 86 GT86 General Forum 34 06-07-2012 10:11 AM
