Old 10-23-2014, 08:21 PM   #2031
CSG Mike
CSG Mike's Avatar
Originally Posted by THEmailman View Post
Ok I never thought of that but makes sense.....related then, when it comes time to replace the rotors, is it worth it to just go with a blank replacement rotor or upgrade to something a little more geared toward track duty (still keeping stock brake system)?
I recommend blanks for stock brakes.
THEmailman (10-23-2014)
Old 10-24-2014, 01:29 AM   #2032
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Got a track related question? I'll try to answer.
Originally Posted by OkieSnuffBox View Post
Are there any quality bolt-in roll bars available that have an integral harness bar?
Like these for Miata's? (I come from the BMW/Miata world).
http://flyinmiata.com/index.php?dept...%20%202%20DIAG
I have one from Cantrell Motorsports that is very high quality. They make excellent rollbars; I had their bars in past M3 and Cayman.
Shoot them an email and they can send you pics and specs info@cantrellmotorsport.com
You can see pics and specs on their Facebook page
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
OkieSnuffBox (10-24-2014)
Old 10-24-2014, 08:35 AM   #2033
jvincent
jvincent's Avatar
Since we are on the topic of rotors, just a head's up for anyone considering running the stock pads at the track.
I melted my stock pads at my last track day and somehow ended up grooving the shit out of my rotors. The price of getting faster and not bothering to swap in the track pads I guess.
Gory pics in the following post.
http://www.ft86club.com/forums/showp...postcount=6407
Old 10-24-2014, 09:36 AM   #2034
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Any idea how do these hold up? I'm due for replacements soon.
[ame="http://www.amazon.com/dp/B000BZXR6I/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3990 Q6PCETP1I&coliid=I3F1QPDE47IPYI"]Amazon.com: Centric 120.47018 Premium Brake Rotor: Automotive[/ame]
raul is offline   Reply With Quote
Old 10-24-2014, 12:48 PM   #2035
OkieSnuffBox
Drives: '23 BRZ Limited
Excellent, thanks!
Old 10-24-2014, 02:50 PM   #2036
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
The small cracks are heat checking; normal.
The rotor is fine to use, but as the cracks get larger, get ready to replace them. If a crack reaches the edge of the rotor, it's no good, and needs to be changed ASAP.
Also, it's common to run your fingernails across the face of a cracked rotor to get a feel for how wide the cracks are - the idea being that when your fingernails catch on a crack, the rotor is ready for replacement. If you do this, you'll find that visually the cracks are already getting fairly wide by the time your fingernails start getting hung up on the cracks.
If you're at the track when you find rotor cracks have become an issue, that's a good time to enjoy the fact that you were thinking ahead and so you have a spare set of rotors ready to throw on between sessions or at lunch. You're going to need them anyway, sooner or later, so why not have them with you when you need them the most?
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Racecomp Engineering (10-30-2014)
Old 10-28-2014, 04:35 PM   #2037
bjun
bjun's Avatar
Drives: white premium brz M/T
I was wondering if the STI Brembo BBK is any good for track?
bjun is offline   Reply With Quote
Old 10-30-2014, 01:26 PM   #2038
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I don't want to start another thread just for this question, but what class do forced induction twins fall into for auto x?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-30-2014, 03:00 PM   #2039
CSG David
CSG David's Avatar
Marginal upgrade to the factory brakes. You will still need to use a track pad to maximize your braking capabilities and capacity. Front Brembo BBK will help a little bit, but the rear Brembo BBK is a downgrade. If you can handle oversteer, I suggest you run non-staggered brake pads at minimum or maybe a more aggressive rear pad to maintain proper bias. We would need to use our temperature probe and paint strips to identify where your brake temperatures are at before recommending you further information.
The Following User Says Thank You to CSG David For This Useful Post:
bjun (10-30-2014)
Old 10-30-2014, 03:29 PM   #2040
bjun
bjun's Avatar
Ty so much for info. I guess I'll buy stoptech bbk later down the road then lol
Old 10-30-2014, 03:41 PM   #2041
wparsons
wparsons's Avatar
Look at other options before jumping straight to stoptech, unless you're doing it just for looks.
The Essex kits are arguably better and cheaper IIRC.
flickr
Old 10-30-2014, 03:46 PM   #2042
CSG David
CSG David's Avatar
Yes. The AP kits are arguably better than the Stoptech BBKs. The recommendation is to go Sprint Kit if you're NA and Endurance kit if you're going FI. It's much harder to bed in brakes with BBKs in general.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
bjun (10-30-2014), wparsons (10-30-2014)
Old 10-30-2014, 04:04 PM   #2043
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
A user on here that Autox an innovate sc twin is running SM if I recall correctly
Old 10-30-2014, 04:05 PM   #2044
BRZZZZZZZZZZ
Car Nut
Ok thanks, that's what I got from reading the rules but wasn't sure.
Goodbye STX, here I come SSM!
The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
finch1750 (10-30-2014), Racecomp Engineering (10-30-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
