Old 10-29-2014, 10:09 PM   #2647
Frs123
Frs123's Avatar
Drives: Raven
Originally Posted by murselyfe View Post
I miss my stock fenders.
Attachment 94642
I want to do the same with my bbs but keep them 17's
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 10-29-2014, 10:12 PM   #2648
murselyfe
murselyfe's Avatar
Drives: It's black.
Originally Posted by 636 View Post
Camber gods I need your suggestions real quick.
17x10 +15. I have PBM LCA/Megan Toe arms for the rear, so rear camber is no problem. I'm currently only on BC Racing Coilovers + BC Camber plates right now, the front plates aren't maxed out, so I can add a little bit more.
But what size tire do you guys think I should run? I'm leaning towards 215/45/17 right now.
Here's how they are sitting right now.
Front:
Rear camber may actually be a problem. The LCAs won't necessary give you the upper clearance you're looking for. To eliminate the poke and properly fit the rears into the fenders, you'll need UCAs. The LCAs will simply keep the rears where they are and only angle them.
I'd recommend 225/40 on the rears, or 215/45 depending on the look you're aiming to achieve. Fronts I'd go the same.
2013 Subaru BRZ Limited- Crystal Black Silica
murselyfe is offline   Reply With Quote
Old 10-29-2014, 10:14 PM   #2649
Frs123
Frs123's Avatar
Drives: Raven
They discontinue 225/40/17
Instagram: erik239
Old 10-29-2014, 11:22 PM   #2650
636
636's Avatar
Drives: '23 CWP BRZ
The PBM LCA's have dropped mounting points for up to 40mm's of lowering ability I thought, wouldn't that help to fit them in? I'm not planning on running more than -4/5, doesn't seem like I'll need to either.
Also, do you think I'll be able to camber the fronts enough on the stock plates? Or will something need to be done.
636 is offline   Reply With Quote
Old 10-30-2014, 11:39 AM   #2651
yohan04
yohan04's Avatar
Drives: Your sister
Pulling your fenders also might be option if you want to dial in less camber.
I gained around 20mm from pulling my fenders on my STI.
yohan04 is offline   Reply With Quote
Old 10-30-2014, 12:12 PM   #2652
aLaFleur
Front:
I ran a 215/40 on my 17x9 +30 with 15mm spacers and maxed out bc camber up front. That should perfect on those wheels
@ashtonlafleur
aLaFleur is offline   Reply With Quote
Old 11-01-2014, 12:00 AM   #2653
swpbrz
Drives: swp brz limited
I dig it. Wheelgap and all. How can I make mine look this sexy?
Originally Posted by OmarGC View Post
Please don't mind the wheel gap... She's currently a little lighter than normal
swpbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to swpbrz For This Useful Post:
OmarGC (11-01-2014), the puppet master (11-03-2014)
Old 11-01-2014, 06:23 PM   #2654
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Don't buy knockoffs and make it function
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
AznKirby (11-03-2014), PRORICAN (01-13-2015), the puppet master (11-03-2014)
Old 11-03-2014, 01:32 AM   #2655
slava
slava's Avatar
Drives: brZed
Added Stillen sides and polished my lips some.
slava is offline   Reply With Quote
Old 11-03-2014, 07:32 AM   #2656
aLaFleur
17's? Looks killer. Thinking about stepping up to 18" rears and going double staggered on mine.
@ashtonlafleur
Old 11-03-2014, 11:18 AM   #2657
slava
slava's Avatar
Drives: brZed
Yea theyre 17's
Old 11-03-2014, 10:32 PM   #2658
MR.SINISTER
Drives: SCION FR-S
those are some really cool wheels! what kind of wheels are they/ lip size?
MR.SINISTER is offline   Reply With Quote
Old 11-03-2014, 11:28 PM   #2659
mike_frs
mike_frs's Avatar
Drives: 2015 Subaru BRZ Limited
mike_frs is offline   Reply With Quote
Old 11-03-2014, 11:56 PM   #2660
Dr Evil
Dr Evil's Avatar
Drives: '93 sc400, UltraMarine
Originally Posted by mike_frs View Post
oooooooooooooooooooooooohhhhhhhhhhh yes
Dr Evil is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
