Old 10-29-2014, 02:21 AM   #351
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have the auto tranny FRS NA and plan on staying NA. The 1st thing I did was go to 4.88s. Got the gears from Robert Weir for $270. Paid my shop $500 to install them.
I love what it did for my car. Dropped 0 to 60 times a full second and dropped 30 to 70 mph time by 1 1/2 seconds.
60 mph is 2500 rpm, 70 is 2750 and I can still get over 30 mpg. This is by far the best mod I have done to my car.
Lunatic is offline   Reply With Quote
The Following 9 Users Say Thank You to Lunatic For This Useful Post:
8686 (10-29-2014), jcw99 (07-27-2017), Lonewolf (10-29-2014), makesdrivingfunagain (08-10-2016), new2subaru (06-17-2016), phrosty (10-29-2014), Rookie84 (05-28-2015), Superhatch (10-29-2014), Tye300 (10-29-2014)
Old 10-29-2014, 11:22 AM   #352
CajunFRS
Drives: Challenger R/T, CRX SI,
How did you calculate these runs?
CajunFRS is offline   Reply With Quote
Old 10-29-2014, 12:35 PM   #353
Lunatic
Lunatic's Avatar
With a "G-Tec" SS meter. It works off GPS and will give you all sorts of info.
Old 10-29-2014, 02:00 PM   #354
ja1217
Drives: 2004 Toyota RAV-4 5M
Reading through this thread I am surprised more do not have this 4.55-4.77 final drive mod as it seems for NA guys to be an awesome upgrade to do after a header and a tune/OFT...
I'd say it really depends what you want from the car. If you just want an upgrade that makes the car feel quicker in day to day traffic its probably a pretty good mod. Will it actually make the car faster? I'm not so sure. I'd be more inclined to believe that it might make the AT faster since it has a much lower gear to start with and the extra shifting won't effect it as much.
With the MT on a track, the higher final drive ratio can keep you in the powerband more, but you have to weigh that against the possible extra shifting time, so it really becomes very track dependent. For example, at Summit Point where both Myles (Racecomp Engineering) and I have run, Myles ran a low 1:28 with the final drive. With slightly less power than him (~180 vs ~185whp) and less sticky tires (235/40R17 Dunlop ZII's vs 235/40R18 Pirelli Trofeo R's) I ran a 1:27.5. Now I know it may not be a completely fair comparison (different driver, different date, different suspension setups etc.) and I'm not just trying to toot my own horn (OK, maybe just a little ) but I just want to point out that at least on track its not going to be some sort of earth shattering mod that magically makes you faster, especially depending on the track and where your shift points will be. Also, I'd imagine that for a lot of the MT cars that autocross the higher final drive ratio may make them run out of 2nd gear on a lot of the courses.
Myles' Lap:
[ame]http://youtu.be/cXSmRpz__MI[/ame]
My Lap:
[ame]http://youtu.be/HtCDpjiZj3o[/ame]
ja1217 is offline   Reply With Quote
The Following 2 Users Say Thank You to ja1217 For This Useful Post:
Lonewolf (10-29-2014), Superhatch (10-29-2014)
Old 12-24-2014, 05:51 AM   #355
iag48st
Drives: 10Series 0945
So just read the whole thread at 5:50 am and very interested in doing this.
Where do we order this 4.55 kit? and does it come with everything needed for a shop to install.
iag48st is offline   Reply With Quote
Old 12-24-2014, 06:54 AM   #356
s2d4
s2d4's Avatar
Don't lie, you didn't read all of it.
The Following 3 Users Say Thank You to s2d4 For This Useful Post:
emutcfut (12-26-2014), SportInjected (12-24-2014), Ultramaroon (12-25-2014)
Old 12-24-2014, 10:45 AM   #357
wootwoot
Drives: FRS
The Following User Says Thank You to wootwoot For This Useful Post:
Old 12-24-2014, 10:47 AM   #358
whataboutbob
AutoX-10/10ths every run
http://counterspacegarage.com/cusco-...-set-4556.html
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
iag48st (12-24-2014)
Old 12-24-2014, 03:36 PM   #359
iag48st
Lol yes I did read it! Thanks bob!
The Following User Says Thank You to iag48st For This Useful Post:
whataboutbob (12-25-2014)
Old 12-24-2014, 03:38 PM   #360
iag48st
Someone in thread mentioned they bought their kit for like $330. How does that differ with the Cusco kit?
Old 12-24-2014, 03:50 PM   #361
CSG David
CSG David's Avatar
They may have used the units from a different car (for example, a 4.77 comes from a Kia). Cusco manufactures high quality units.
Old 12-25-2014, 12:08 AM   #362
s2d4
s2d4's Avatar
The Following User Says Thank You to s2d4 For This Useful Post:
Old 12-25-2014, 01:44 AM   #363
iag48st
Thanks fellas! looks like this will be close to a $2000 mod just to get the gearing close to the manual. I wonder if its better to just trade in for a certified pre owned manual.
Old 12-25-2014, 08:42 AM   #364
Lunatic
Lunatic's Avatar
What do you mean $2000? I got my 4.88 gear set from Robert Weir for under $300 and had it installed for $500, $800 total!
The Following User Says Thank You to Lunatic For This Useful Post:
kodyo (12-25-2014)
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
