Old 10-27-2014, 10:45 PM   #1191
TimDing
TimDing's Avatar
Drives: Storm Black Manual 86GTS
Easy. Thanks for the quick reply.
TimDing is offline   Reply With Quote
Old 10-28-2014, 06:15 AM   #1192
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hands up if you are using a Motiv or JDL 2.5" overpipe. Any fitment issues with the dump pipe?
Fizz is offline   Reply With Quote
Old 10-28-2014, 10:39 AM   #1193
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
Originally Posted by @Art_Mighty View Post
This is a great question; @AVOturboworld, any info for us?
(honestly, I'm not exactly sure how one would go about getting a torque wrench to some of those bolts, so that would be another question?..)
I got around to it finally. I checked my oil catch can and it did do its job of catching oil
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
CxG (12-06-2016)
Old 10-28-2014, 11:51 AM   #1194
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I am using Motiv overpipe ... I have a custom 3" exhaust and the guy told me about having a little fitment issue when installing the overpipe and he had to modified it a bit.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Fizz (10-28-2014)
Old 10-28-2014, 01:27 PM   #1195
Astroboy
Astroboy's Avatar
Drives: None
So I finally a switched my motor for my turbo kit. I went from Toyota's synthetic 0w20, to Motul's 8100 100% synthetic 5w30. The car feels a lot smoother. I feel much more safer now while going into boost. Now all I need to do is invest in an oil pressure gauge. Any recommendations? I want a cheap 52mm oil pressure. One that I can simply just plug into the factory oil pressure sensor.
Old 10-28-2014, 02:09 PM   #1196
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Can't do that. The factory oil press. sensor is just an on/off switch for when the pressure goes really low, to turn on the light on the dash. You need a dedicated sender with a gauge to read oil press.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Astroboy (10-28-2014)
Old 10-28-2014, 03:01 PM   #1197
Astroboy
Astroboy's Avatar
Drives: None
Ok.
Will any oil pressure gauge be ok as long as I get the correct screw for where I mount it? I just want a really cheap one.
Old 10-28-2014, 03:03 PM   #1198
Sportsguy83
Drives: Limited BRZ
Ok.
you usually get what you pay for. Buy the cheapest quality brand. You can Tee into the stock oil press sensor (I recommend a SS Tee, brass ones car break easier).
Or use the plug above the block, that Fastwrx has an adapter for to convert it to 1/8 npt which basically all oil press senders are.
Old 10-28-2014, 03:37 PM   #1199
Astroboy
Astroboy's Avatar
Drives: None
That's the one I was thinking of. I'm going to just plug it above the block then. Thanks. If you don't mind me asking, what is your occupation? You seem like your a well rounded engineer.
Old 10-28-2014, 03:47 PM   #1200
Sportsguy83
Drives: Limited BRZ
mechanical engineer and thanks
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Astroboy (10-28-2014), Draco_PR23 (10-28-2014), frsvr4 (10-29-2014)
Old 10-28-2014, 03:56 PM   #1201
Astroboy
Astroboy's Avatar
Drives: None
Cool, I look up to people of those occupations. I'm going to school to become an engineer. I always like learning new things in that field.
Sportsguy83 (10-28-2014)
Old 10-28-2014, 03:59 PM   #1202
Sportsguy83
Drives: Limited BRZ
Good choice
Old 10-28-2014, 04:33 PM   #1203
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If he has a Subaru, then it is almost mandatory he goes with the cheap Prosport gauges.
Old 10-29-2014, 08:37 AM   #1204
Sportsguy83
Drives: Limited BRZ
I didn't get the memo then...
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
