#841 |
Off Topic
Would it be acceptable to have the calipers powdercoated? Would that even solve the problem?
#842 |
#843 |
Drives: 2012 BRZ Premium WRB 6MT
One of our customers sent us a nice vid of him working over a large field of GT86's with our Sprint Kit. Check it out on our blog.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
#844 |
Thanks
I ran XP10 at the track this weekend. On stock brakes and tires the backing plated turned black. On stock brakes and RE11A I turned the backing plate white.
On stock with XP10 I find the pedal is very firm and easy to use. On the AP sprint kit I find the initial bite to be non existent. The first bit of travel does nothing IMO. I got used to it thought and maybe it is a good thing because you can just stand on the brakes. Since the first bit doesn't do much it doesn't unsettle the car. Also to note the XP10 pads still have orange paint so they did not get hot at all. Not sure what to conclude but I have a few thoughts. Maybe there is a little air in system, though I bled twice and it feels firm on street pads (carbotech 1521). Or overall the car and tires are not enough for this pad compound, maybe should try XP8. Or (most likely) I'm just slow and don't get enough heat into the brakes.
#845 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#846 | |
Do you know how hot the brake temps were front to rear? |
#847 | ||
Thanks
I don't know the temps, I don't have any way to check.
#848 |
Cheap harbor freight laser pyrometer will be good enough for this; we just want to check for rotor temps to approximate brake useage
#849 |
Off Topic
AP makes thermal paint you can apply to your rotor. @JRitt sells it.
#850 | |
| The Following 2 Users Say Thank You to dradernh For This Useful Post: | 86Tony (01-30-2016), gramicci101 (10-28-2014) |
#851 |
Thanks
Just bled my brakes again for good measure based on @CSG Mike post that I should have a good initial bite. Saw 3 small air bubbles from rear caliper. Didn't see any more air come out.
Also air sprayed any excess fluid out of the bleeder nipples and wiped off calipers to see if I find any more stray brake fluid. Can't wait for this 3 day weekend at VIR to try them out some more
| The Following User Says Thank You to ZionsWrath For This Useful Post: | CSG Mike (10-28-2014) |
#852 |
Drives: 13' Scion FRS Track car
What the consensus on brake duct blowing on the rotor 'pad area' instead of the center ?
I understand it is not optimal, but is it something that should be avoided ? Logically a large amount of air coming only on one side of the disc doesn't sound like a great idea for uniform wear. Can anybody comment on that ? I have the APR brake kit and it seems like the Essex kit will play along with the kit without problem, but considering the oversized brake may not require any ducting, I am thinking about removing it all together. anybody running the essex kit with some brake ducts ?
2013 Scion Frs Track Car - Sold.
#853 |
Drives: Subaru BRZ Limited
Hi all this is my first post. I warped my front DBA 5000 rotor the other day at the track which got me thinking about a proper BBK upgrade, which brought me here.
Has anyone considered pairing the Essex kits with some of the GC8 WRX fixed 2 pots for the rears? These bolt on with a custom bracket. I played around with the brake bias calculator which showed that these calipers have the exact same brake torque as the stock FT86 ones. As the Essex kits are designed to not alter the bias with the OEM rears, it would seem the wrx 2 pots would work with this kit without altering factory bias. As the same rotor is used there would be no thermal advantage, but it doesn't appear as though this is needed on the FT86 rear. However, the calipers are alloy and would save a few lbs over stock, the fixed design would offer better feel, they would visually be a nice match for the front and the whole exercise would not be very expensive at all. Sent from my iPhone using Tapatalk |
#854 |
Drives: GT86 Cosworth
I have a setup with the subaru 2 pot rears and a custom ap fronts (similar bias to stock).
They work exactly the same as they have the same 38mm piston diameter. the rear 2 pot give a bit better feel. I bought an old set and refurbished them myself with stainless steel pistons which is other advantage (less heat transfer than aluminium). They are also light but bare in mind the kns bracket is steel... |
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 10:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 02:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 01:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
