Old 10-26-2014, 02:44 PM   #9899
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by BRZ86-R View Post
Terminator Audio System BRZ86-R
Can you share more pictures/review on that extreme dimensions front bumper?
Old 10-26-2014, 08:31 PM   #9900
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by JM9ISM View Post
Detailed my car
From what I've seen from the pro-detailing videos, they recommend consistent pressure with both hands on the orbital. You were probably doing a quick pass to spread the compound/wax in the video and I didn't see what you did afterwards - but the end result looks good!
aegisdrgn is offline   Reply With Quote
Old 10-27-2014, 04:27 AM   #9901
JM9ISM
Drives: 2014 BRZ WRB LTD
Originally Posted by rburrow87 View Post
I should really get a foam canon...
Are the tail lights painted or are those vinyl overlays? I'm thinking about trying vinyl so I can try both red and amber turn signals and see which I like more.
It is painted.
JM9ISM is offline   Reply With Quote
The Following User Says Thank You to JM9ISM For This Useful Post:
rburrow87 (10-28-2014)
Old 10-27-2014, 04:28 AM   #9902
JM9ISM
It was just a wax, so I did not need that much of pressure
Old 10-27-2014, 10:44 AM   #9903
srizzors25
Daedalus Moto
srizzors25's Avatar
lowered and aligned wooo
The Following 2 Users Say Thank You to srizzors25 For This Useful Post:
daiheadjai (10-28-2014), Ganthrithor (11-02-2014)
Old 10-27-2014, 12:09 PM   #9904
Mazikowski
Drives: 2013 GBS BRZ Limited
This weekend I did some vinyl on the tag area of my trunk lid. Pretty straight forward.
I pulled off all the emblems and the trim piece with the tag lights in it (whatever you call that bit) and completely wrapped it. Then I laid out my line in Knifeless tape (which, by the way, is FAN-FREAKIN'-TASTIC) and applied the vinyl to the trunk. The last thing I did was reassemble everything and stick the emblems back on.
For anyone who might want to do this my only suggestion is make sure you prep the surface really well and, if possible, do it in a garage or at least where there isn't much dust in the air. I washed the area (with Dawn to remove any wax) then clayed to make sure I got the cleanest surface I could before I laid down the vinyl. I still wound up with a tiny wrinkle near the trim piece (and a few behind it because I was getting lazy and they would be covered anyway) and a couple pieces of something (I think from cutting the backing from the vinyl) under the vinyl that left little bumps, but they are hardly noticeable.
I think I'm going to do the little bit of the bumper that's peeking out behind the trunk lid, as well, just to make it blend better.
Mazikowski is offline   Reply With Quote
The Following 3 Users Say Thank You to Mazikowski For This Useful Post:
00NissanNinja (10-28-2014), chanomatik (10-27-2014), GotBRZ1691 (11-02-2014)
Old 10-27-2014, 12:55 PM   #9905
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
It is painted.
looks awesome.. I want a spray gun, what do you recommend?
Marcoscrdo is offline   Reply With Quote
Old 10-27-2014, 01:11 PM   #9906
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Detailed my car
Are you running spacers on the rims? The more I see those TRD wheels the more I'm liking them
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-27-2014, 07:11 PM   #9907
Turbowned
Turbowned's Avatar
I recommend reconsidering the placement of that "SUBARU" lettering. Just my $.02
Old 10-27-2014, 07:13 PM   #9908
Turbowned
Turbowned's Avatar
PlastiDip'd the wheels with Anthracite Metallic from dipyourcar.com. Did 5 coats using 4 cans. They didn't all go empty, it's just that the cans sputter after dropping down to the last 1/4 or so. Was going to use glossifier, but I really liked how it looked without. It's more of a satin finish rather than flat. Looks better in person than in pictures.
These wheels look 10X better in one solid color!
The Following User Says Thank You to Turbowned For This Useful Post:
Old 10-28-2014, 12:41 PM   #9909
JM9ISM
15mm spacers. It is a must lol
I actually used VHT spray can
The Following 2 Users Say Thank You to JM9ISM For This Useful Post:
Marcoscrdo (10-28-2014), rburrow87 (10-28-2014)
Old 10-28-2014, 01:12 PM   #9910
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I'm actually in love with that "SUBARU" lettering placement. Good job!
Old 10-28-2014, 01:15 PM   #9911
Marcoscrdo
Marcoscrdo's Avatar
Ah i knew i should of quoted the part about washing your car, i meant the gun you used to wash car
Old 10-28-2014, 01:27 PM   #9912
JM9ISM
Whoops lol. It is Autobrite Foam Lance
Marcoscrdo (10-30-2014)
