Old 10-21-2014, 08:34 AM   #1779
48Spoons
Drives: Ultramarine FR-S
Originally Posted by Kido1986 View Post
Don't all Scions register at Toyota legally?
Yes. My registration has the make as Toyota and the model as Scion. No FR-S anywhere on it.
48Spoons is offline   Reply With Quote
Old 10-21-2014, 09:35 AM   #1780
chkltcow
Drives: 2013 FRS White w/ cone marks
Originally Posted by renfield90 View Post
They put the listing under Toyota, not Scion. Swing and a miss...
Got it!!
chkltcow is offline   Reply With Quote
Old 10-26-2014, 09:53 AM   #1781
scirocco78
Drives: Scion FRS
What are you guys running for rear toe? Has anybody beside John Hale tried other rear toe settings?
My FRS with Rivals, Perrin small front sway bar set stiff, crash bolts and Konis steps out too much on corner exit when applying the throttle. I'm tunning 1/16" total toe in. I'm thinking 1/8" total for next year. Maybe more. Any thoughts?
scirocco78 is offline   Reply With Quote
Old 10-26-2014, 11:36 AM   #1782
mla163
Overthinking it
Drives: BRZ in CS
I'm running zero rear toe. No issues with stepping out. 34/32 on tires. I'm on konis 1/2 turn from soft in rear.
FRS will be a little more loose than a BRZ.
Try some rear toe in. I wouldn't go more than 1/8"
mla163 is offline   Reply With Quote
Old 10-26-2014, 07:48 PM   #1783
renfield90
The Stig's German cousin
My setup isn't far from this - major differences are OEM shocks and the Hotchkis bar on full stiff. I have more push than oversteer at corner exit, but I can be a lot more aggressive with early throttle application. Try a bigger bar or be more patient on the throttle (I know, probably not the answer you wanna hear).
Too much toe in can make a car stable, but it won't turn as well - the outside rear will essentially be trying to steer the car in the wrong direction mid turn.
Old 10-27-2014, 10:01 AM   #1784
edj
edj's Avatar
Drives: 2022 Toyota GR86
try dropping your rear tire pressures 2 psi.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 10-28-2014, 10:18 AM   #1785
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
So
I've looked far and wide..
and it seems the only "sensible" wheel choice for a competitive C-Street car are the RPF1
everything else is either knock-off grade, or expensive (400/wheel ++)
Like OZ, Weds, Volks etc
I mean, I have no real issue going with RPF1s, but I do prefer the styling of the other brands (I also want the wheels in white).
and I'm done chasing used wheels, that shit ain't worth the hustle.
thoughts? RPF1-and-forget-about-it?
Old 10-28-2014, 10:30 AM   #1786
48Spoons
A buddy and I have both been using the Kosei K4R this year and they have been great. About the same weight as the rpf1 but cheaper and I prefer the looks. Sadly they don't come in white, but but nothing a little plastidip can't fix.
Old 10-28-2014, 10:40 AM   #1787
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I just can't dig em
but you're right, they are a really good alternative (one of my first wheels were from Kosei and they're still alive today).
Maybe if I look at enough pictures I'd be more amiable by the time spring rolls around
Old 10-28-2014, 10:58 AM   #1788
TRev
If anyone in the Twin Cities, Chicago or Milwaukee area is looking for used 17x7 rims, I have 2 sets of Enkei RPF1 (black), and a set of Kosei K1 TS for sale. Not interested in dealing with the hassles of shipping at this time.
TRev is offline   Reply With Quote
Old 10-28-2014, 11:07 AM   #1789
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Got me wishin' I still lived in the Detroit area. Ship them and I'd be interested.
bimmer635csi is offline   Reply With Quote
Old 10-28-2014, 12:31 PM   #1790
renfield90
Same wheel myself and about half the Twins at nats were using. I bought them for the price difference and to try and be different than everyone with RPF1s...look how that turned out!
The only catch is they are a +50 offset which results in a slight loss of track width compared to OEM. If you want to space them out to take advantage of the offset allowance you need lengthened studs.
Old 10-28-2014, 02:39 PM   #1791
Biggins
Drives: Yes
I have some Buddy Club P1 17x7 +42 that I got off a member here this year. They're the perfect offset but a few pounds heavier than the Enkei/Koseis. I usually run my K4R's with 5mm spacers.
Biggins is offline   Reply With Quote
Old 10-28-2014, 02:54 PM   #1792
scirocco78
Drives: Scion FRS
I tried tire pressures, shock settings and front sway bar settings. I have not done any alignment tweaking other than my initial settings.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
