Old 10-23-2014, 09:08 PM   #967
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 10-26-2014, 10:02 PM   #968
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Originally Posted by sirsol66 View Post
I can't believe that fits. Any additional photos? I can't believe you actually cleared the front strut as well as the rear quarter panel. No rub at all?
No rubbing at all front or back. Its a very tight fit. However I can go full lock with no rubbing. I need to get some more photos, only other one is below.
Shneegle is offline   Reply With Quote
Old 10-26-2014, 11:41 PM   #969
Pete156
I like to eat!
Originally Posted by Shneegle View Post
No rubbing at all front or back. Its a very tight fight but I can even turn to full lock with no rubbing.
Very nice fit. You are fortunate (don't know whether you planned it that way).
Now go out and get some springs or coilovers and see what your car can REALLY do!
You must mean tight fit, not tight fight, right?
Pete156 is offline   Reply With Quote
Old 10-27-2014, 01:16 AM   #970
Shneegle
Shneegle's Avatar
Yeah....fit.....tight fit. Happened upon a groupbuy for an offset of +35 did a fair amount of research to make sure it would not rub with 255/40. Swift springs and whiteline LCA's are next on the list.
Old 10-27-2014, 10:07 AM   #971
jaydee_do_work
jaydee_do_work's Avatar
Drives: 13' Whiteout FR-S
Guess I gotta stretch to make my work meisters fit. Anywho I got another question. My current setup is as follows
Enkei rpf1
17x9 + 35
Hankook v12
245/40 front
255/40 rear
My buddy gave me a set of used hankook rs3 225/45 up front and 255/40 in the rear. My question is what would be my ideal setup right now? Do I swap out the 245s for 255s and use the v12 in the front with the rs3 in the rear, or am I better off using both pairs of rs3
jaydee_do_work is offline   Reply With Quote
Old 10-27-2014, 03:08 PM   #972
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i think you'll be better of with RS3 all around, but 225 on 9 is kind of stretched...
in this weather it will be weird, because i think the V12 are a bit grippier than RS3 in colder weather, could be a weird driving experience if you push the car.
Jive Turkey is offline   Reply With Quote
Old 10-31-2014, 11:51 AM   #973
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
245/40/17
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
civicdrivr (10-31-2014), drewbot (11-26-2014), Hicklinc (02-13-2018), nlamon33 (10-31-2014), Racecomp Engineering (11-02-2014)
Old 10-31-2014, 05:04 PM   #974
D_Thissen
D_Thissen's Avatar
Originally Posted by ATL BRZ View Post
245/40/17
What are you lowered on? Are those RS-3s?
The Following User Says Thank You to D_Thissen For This Useful Post:
smrbb6 (09-06-2017)
Old 10-31-2014, 05:11 PM   #975
ATL BRZ
ATL BRZ's Avatar
@Racecomp Engineering Tarmac 2 Clubsport Coilovers.
Are those RS-3s?
Bridgestone Potenza RE-11A
The Following User Says Thank You to ATL BRZ For This Useful Post:
D_Thissen (11-01-2014)
Old 10-31-2014, 05:17 PM   #976
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Oops I stole your license plate idea...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-31-2014, 05:25 PM   #977
ATL BRZ
ATL BRZ's Avatar
It's cool, we're in different countries!
Old 11-01-2014, 11:54 AM   #978
BRZZZZZZZZZZ
Car Nut
Has anyone tried 275/40/17 tires? I feel like the sidewall is going to be way too tall to work but I am trying to fit more tire under my car for next year without going 18".
Old 11-01-2014, 12:09 PM   #979
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You would have to have a ton of ride height to fit tires that tall. I'm sure it could be done with the right offset and camber but it might not be the same camber as is "fast" especially in the rear.
Old 11-01-2014, 04:32 PM   #980
BRZZZZZZZZZZ
Car Nut
Looks like I am stuck at 255s then for 17".
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
