Old 10-27-2014, 11:06 AM   #1
Drewbie
Drives: 2013 Asphalt FRS 6AT
255/40 18 rear - Does it fit??
I want to do staggered Rota MXR's with 18x8.5 +44 front and 18x9.5 +38 rear. I know the wheels fit without coilovers (just going with springs). Will 255 fit in the rear? I know 245 will. And should I do 255/40 or 255/35?
Thanks yall.
Drewbie is offline   Reply With Quote
Old 10-27-2014, 11:37 AM   #2
gramicci101
Off Topic
Yes, and get 255/35's.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Drewbie (10-27-2014)
Old 10-27-2014, 12:22 PM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yes they fit just fine Those are 255's right there
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 10-27-2014, 01:44 PM   #4
Drewbie
Thank you kindly sir!
Old 10-27-2014, 01:45 PM   #5
Drewbie
Thank you! Nice set up!
The Following User Says Thank You to Drewbie For This Useful Post:
SkAsphalt (10-27-2014)
Old 10-29-2014, 03:41 PM   #6
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Yes they will. I have 40's and fit fine my off-set is only 38.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 10-29-2014, 05:44 PM   #7
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
In the interest of keeping the speedometer as close to accurate as possible, you should steer clear of 255/40-18. Good rule of thumb is you want to stay +/- 3% of OEM diameter.
255/35-18 puts you at +1.6%. At 60 on the speedo you'll actually be travelling 61.
255/40-18 puts you at +5.7%. At 60 on the speedo you'll actually be travelling 63.4.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
Leonardo (10-29-2014)
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 05:48 PM
Installed Rear Roof Visor and replica STi style Rear Spat wrb Cosmetic Modification (Interior/Exterior/Lighting) 11 10-13-2014 08:51 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 05:46 AM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 11:17 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
