orthojoe
Old 10-27-2014, 12:04 PM   #281
ja1217
Drives: 2004 Toyota RAV-4 5M
So I had an interesting experience with the pedal dance this weekend. It seems the pedal dance does nothing to help prevent the ABS system from freaking out occasionally. 2 out of the 3 times I dropped my outside wheels off in turn 2 of NJMP Thunderbolt I ABS light to come on and that seemed to turn off ABS completely and shove all the bias to the fronts. As you can see in the video, that made it very difficult to slow down in time.
ja1217 is offline   Reply With Quote
Old 10-27-2014, 12:16 PM   #282
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by ja1217 View Post
So I had an interesting experience...
How did your brake pedal feel when you braked for T5 - normal, different, or...?
dradernh is offline   Reply With Quote
Old 10-27-2014, 12:28 PM   #283
ja1217
I don't remember the pedal feeling any different. Steering felt non-existant due to the lock-up.
Old 10-27-2014, 12:45 PM   #284
dradernh
Okay. I was looking to see if pad knockback might have been going on, and it doesn't sound like it.
I'll be curious to see where this goes because I've been relying upon post 226 on this page as a firm guide to whether or not ABS will be operating as intended when the pedal dance is in effect: http://www.ft86club.com/forums/showt...=25494&page=11
Old 10-27-2014, 04:04 PM   #285
ja1217
It's quite possible that what happened to me was just a case of me kicking up a bunch of dirt, temporarily messing with the wheel speed sensors and throwing, but if that's the case I don't see anything like that in my wheel speed data. I only see a lot of inside wheel spin (clutch type LSD is planned for next year) in that turn:
{Green=Front Left, Brown=Front Right, Blue=Rear Left, Orange=Rear Right}
Turn 2 is right around the 1500ft mark and then you can see the fronts lock up going into turn 5 around 4100ft
The Following User Says Thank You to ja1217 For This Useful Post:
CSG Mike (10-27-2014)
Old 10-27-2014, 10:25 PM   #286
CSG Mike
CSG Mike's Avatar
Seems like a complete loss of front traction, which got exacerbated by you trying to turn without front grip...
You did spike to over 1000psi on the brakes that caused the traction loss to begin with, followed by some brake pulses.
The giveaway to me is that your steering wheel is turned, and the car is not turning, and there is zero weight transfer going on.
zdr93523 (10-27-2014)
Old 12-04-2014, 09:49 PM   #287
c2yp7ic
c2yp7ic's Avatar
Drives:
Just want to throw it out there that pedal dance does not work for automatics and also holding down traction control is extremely dangerous and should never be used in rain or on city streets.
c2yp7ic is offline   Reply With Quote
Old 12-04-2014, 11:04 PM   #288
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Eh, I wouldn't really call it dangerous as long as you're driving like you should be on city streets anyway.
It takes some effort/negligence to lose traction on the street.
Old 12-04-2014, 11:27 PM   #289
c2yp7ic
c2yp7ic's Avatar
Drives:
With traction control fully disabled any fancy rookie mistakes go sour real quick
Old 12-05-2014, 12:03 AM   #290
With traction control we end up with a generation of incompetent pu55ies afraid of their own shadows.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
afx (02-18-2015), Amaya (12-05-2014), Apoc (01-19-2015), FLYFISHR (12-05-2014), JouMaSeHoes (01-19-2015), Pat (12-08-2014), renfield90 (12-05-2014), StormMcCloud (12-13-2014), zdr93523 (01-08-2015)
Old 12-05-2014, 02:39 AM   #291
CSG Mike
CSG Mike's Avatar
Not sure if troll...
Old 12-05-2014, 02:43 AM   #292
c2yp7ic
c2yp7ic's Avatar
Drives:
Not sure if has subaru in real life... maybe should go back to counterstrike
Old 12-05-2014, 02:45 AM   #293
s2d4
s2d4's Avatar
Lol, you suck at trolling.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 12-05-2014, 02:47 AM   #294
c2yp7ic
c2yp7ic's Avatar
Drives:
I take that as a compliment since im not trolling
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 09:55 AM
