Old 08-25-2014, 12:52 PM   #2045
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by blackfireball5 View Post
Hey everyone, I was out working on my car today and I noticed a burning oil smell after pulling into my driveway. I can visibly see a pool of oil just to the right of the intake manifold, does anyone have any idea where it could be coming from right there? Any common leak spots? Oil pressure seems normal. :-\ Attachment 88859
The only two things I can think of is you have windowed your block or your oil pressure sensor is leaking.
Old 08-26-2014, 09:20 PM   #2046
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
well It was a long weekend but I got everything done that I wanted. I haven't noticed any more oil leaks but I will be keeping my eye on it. the modifications worked great. Temps seem to be holding better. cruising usually between 85-95C on the oil temps only rise to about 100C or a little over when really getting on it. I still need to get a better water sensor but the stock needle usually is below half way. I can run my AC now from what I can tell all the time barely creeps up to 100C oil temps when on. the Sound from the turbo is definitely changed. I wish I knew a good way to describe it. It sounds like a Kissing sound with the flutter after of the Blow off valve. or maybe the sound of suction on a plastic bag. I don't know if this is normal but the intake sits right against the bumper and next to the windshield washer reservoir and it sounds like it comes from that area so I think its just resonant noise. what do you all think? it's only when I am boosting. my butt dyno says it is pulling harder then before too but we won't know untill I have time to take it in for a base line to see if it made any changes. In the photos you can see how many bends I took out and where the outlet now comes out and into the intercooler. Added a venting location behind the oil cooler as well as you can see. I need to get a better adhesive to hold the grill in place but for now the screws are doing a great job.. just not a fan of screws near the wheels if you know what I mean. hope this helps others out there as well.
toekneehair is offline   Reply With Quote
Old 08-29-2014, 01:23 PM   #2047
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I have a new theory.
So a friend and me took apart the AC compressor to inspect and clean it up. We found no trace of a leak anywhere. I could not for the life of me find anything that could have been leaking.
However, I just recently upgraded to the radium catch can system since the previous owner left the breather hose tucked down in there. When I tracked it a few months ago, oil was spraying out of it all over the place. There is a chance that I had just missed the oil that pooled there from the hose and did not notice it until recently.
That's really the only thing that makes sense to me right now. I cleaned up the pooled oil and have been driving it for a week and have not noticed any oil pooling anymore. I still notice an oil burning smell but I don't see any visual signs of new oil anywhere and I checked my cam plate and it is not leaking. Maybe the smell is just residual oil I had missed?
If the block were to have 'windowed', would it be very noticeable? Other symptoms?
blackfireball5 is offline   Reply With Quote
Old 08-29-2014, 01:37 PM   #2048
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If you can drive your car, its not windowed.
Old 08-29-2014, 06:02 PM   #2049
blackfireball5
Haha. Then I'm probably good. Thanks.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 09-02-2014, 10:43 AM   #2050
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You're good.
Old 09-02-2014, 02:15 PM   #2051
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
I'm currently running FBM's basemap on their premium kit, and my throttle feels REALLY sensitive now. On top of that, boost starts kicking in at 2k, so I'm finding it.... difficult to drive like a normal human being. Does the basemap change the throttle sensitivity at all? I feel like I'm learning how to drive all over again.
neutral is offline   Reply With Quote
Old 09-02-2014, 02:38 PM   #2052
Dipstik-sportech
Dipstik-sportech's Avatar
Yeah that's why I went with a larger turbo, I found it went into boost so quick I was speeding everywhere lol
Old 09-02-2014, 02:46 PM   #2053
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It probably does modify the DBW throttle tables.
Old 09-06-2014, 10:39 PM   #2054
toekneehair
just to solidify the benefit of better flowing air the results are in all those bends do actually rob us of a few HP I went to the dyno today and with the piping relocation and intake relocation only I noticed a nice little bump in power. You see a little over a 20 hp bump. I was thinking maybe we would a 5-10 hp jump I was definitely happy with the results.
Old 09-07-2014, 12:29 AM   #2055
dabocx
dabocx's Avatar
Drives: Scion FRS
Going to get a turboback and turn up the boost on the gtx2867, curious to see how much i can get out of it.
After that maybe a gtx3076
dabocx is offline   Reply With Quote
Old 10-27-2014, 10:52 AM   #2056
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Any updates? Any new owners? Hate seeing this thread not on the first page to keep people from buying TR3/FA20Club turbo kits.
Old 10-27-2014, 11:09 AM   #2057
Bohlmyster
Drives: 2012 scion frs
Add me to the list. Ive had the kit now sence feb and LOVE it! I also have the FBM oil cooler and fan shroud kit that FBM custom made to fit my coyorad and e85 tune. Awsome service from FBM. Dont have any pics to post because im on a work computer and no internet at home because racecar.
Bohlmyster is offline   Reply With Quote
Old 10-27-2014, 11:14 AM   #2058
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Added you to the list.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
