Old 10-23-2014, 01:11 PM   #85
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
Subbity wub
NJ10 is offline   Reply With Quote
Old 10-26-2014, 12:26 AM   #86
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
today I did a thing
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 10-26-2014, 03:05 PM   #87
SomeoneWhoIsntMe
because both engines/transmissions are on the floor and still hooked together, I can measure stuff easily. here is the distance from the bellhousing face to the shifter on the stock trans and on my solstice trans
the solstice trans is about 4" shorter, which seems about right to me, so long as I can push the JZ back a little bit and get it up against the firewall. cool.
Old 10-26-2014, 03:49 PM   #88
gramicci101
Off Topic
Your garage is hilariously awesome. Random racing buckets sitting around on top of other chairs, tires of different brands and sizes piled up, the occasional control arm or strut assembly or brake rotor and caliper. I love that the coolant hoses were just hacked off. "Not worth saving, just cut it..."
Old 10-26-2014, 06:24 PM   #89
SomeoneWhoIsntMe
money shot
and it turns out the solstice shifter is more or less the perfect length for this swap. fuck yeah.
now I just need to hack out the stock trans mount brackets to make room for a manly transmission in the little bitch subaru tunnel
Old 10-26-2014, 09:27 PM   #90
SomeoneWhoIsntMe
fuck these brackets
Old 10-26-2014, 09:30 PM   #91
Fastbrew
Drives: 2014 Pearl White BRZ
Looks like you are battling at the gates to Mordor today lol
Fastbrew is offline   Reply With Quote
Old 10-26-2014, 09:35 PM   #92
SomeoneWhoIsntMe
The Following 2 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post:
Boofneenee (12-10-2014), the puppet master (11-02-2014)
Old 10-26-2014, 09:43 PM   #93
Fastbrew
hehe - gl Frodo.
Old 10-27-2014, 12:52 AM   #94
Fastbrew
PS - I am assuming it will look more like this soon
http://www.vorshlag.com/forums/showthread.php?t=8275
I am following that Vorshlag thread because there is a distinct possibility that will be the future of my BRZ.
The Following User Says Thank You to Fastbrew For This Useful Post:
SomeoneWhoIsntMe (10-27-2014)
Old 10-27-2014, 03:10 AM   #95
Ginzhos
Drives: 93 civic si
Did you modify/cut the mainshalt on the transmission to mate it with the vvti 1jz, or it was a perfect fit?
Ginzhos is offline   Reply With Quote
Old 10-27-2014, 07:22 AM   #96
SomeoneWhoIsntMe
@Fastbrew thanks SO much for posting that, I knew I had seen something similar but I couldn't find the thread again and forgot if it was on a BRZ or an E36 that they had to cut inside the tunnel because I read so many goddamn build threads it's hard to keep stuff straight sometimes
@Ginzhos the solstice trans is similar to the toyota R154, and the input shaft is pretty close to the same length even. the pilot and spline on the input shaft are different, so I do need to use a different clutch disc and pilot bearing. NBD.
Old 10-27-2014, 01:15 PM   #97
Fastbrew
No problem - keep up the good work!
Old 10-28-2014, 12:15 PM   #98
SomeoneWhoIsntMe
lexus ls400 hub vs. BRZ upright
it's ridiculous how chintzy subaru parts look next to manly toyota stuff. hopefully soon I'll be able to make a drawing / get a program done to spot, drill, cham, and spot face four new SHCS clearance holes on the back of the upright to make these LS400 hubs work.
akahenry (10-30-2014), civicdrivr (10-28-2014)
Dreams Priapus Off-Topic Lounge [WARNING: NO POLITICS] 15 08-05-2014 12:57 AM
Front pipe choices, resonated vs straight pipe jflogerzi Engine, Exhaust, Transmission 4 12-29-2013 11:14 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 08:33 PM
BRZ/FR-S Dreams? MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 7 03-22-2012 09:55 AM
Dreams about the BRZ 86'd BRZ First-Gen (2012+) — General Topics 20 02-25-2012 11:58 PM
