Old 10-27-2014, 12:33 AM   #1065
predator800
Drives: 2015 Scion FRS
So I just finished reading the whole thread. One question. With Canadian 91 octane how much hp would I be looking at for this kit with everything else stock and carb tune? think I read 205 to 210 using virtual dyno. I realize it depends on where your start stock.
predator800 is offline   Reply With Quote
Old 10-27-2014, 03:33 AM   #1066
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Yes, I did some testing with VirtualDyno. Posted my results here and here.
Of course the measurements are approximate, as it's not the real dyno, but gives an idea.
Other than having JR SC, my BRZ is stock, and I'm using the CARB tune. With Canadian 91 octane I got ~205-210whp according to VD, which is about 25% more than my measurements for the stock. Would be interesting to try it on a real dyno to see how much VD is off.
alpax is offline   Reply With Quote
Old 10-27-2014, 09:08 AM   #1067
predator800
Jackson Racing Supercharger Owners Thread
Thanks. I was completely sold on the system until now. More research to be done.
Old 10-27-2014, 11:39 AM   #1068
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
VD is way off. You should easily be seeing 40-50% increase with the kit.
JDMChris is offline   Reply With Quote
Old 10-27-2014, 01:59 PM   #1069
predator800
Cool because I had my heart set on this system.
Old 10-27-2014, 03:23 PM   #1070
alpax
alpax's Avatar
The manufacturer claims 50% increase in HP & 45% increase in TQ - there are dyno graphs to prove that. On the image they say it's with stock headers and exhaust, not sure what kind of tuning though.
I agree the Virtual Dyno may be way off due to the test conditions and the nature of the test itself. It might be something wrong with my specific install as well. I suspect that, as I did get the CEL once, though the car seems to work normally.
In any case, the kit has more potential, as the CARB tune is pretty conservative.
Old 10-27-2014, 03:43 PM   #1071
CSG David
CSG David's Avatar
The CARB tune has been proven to be capable of running in many environmental and elevation situations. It's not the most optimal in your exact setup, but you can be certain the kit will perform well on track and in your travels/commute.
You will need a custom tune if you intend to change any of the factory catalytic converter (header and/or front pipe). While the extra $1000 for the EcuTek + CARB tune + CARB sticker sounds a little high up front, it'll allow you to run your car with complete factory equipment as you compile the list of parts that you want for your car. Keep in mind you will need a MAP sensor once you decide to modify your emissions systems since your MAF is already maxed out from the factory. Hope all this information helps.
Old 10-27-2014, 04:10 PM   #1072
alpax
alpax's Avatar
That's what I liked about the pre-tuned kit. I could just install it myself, and run the car without worries. I know it might not give the maximum performance, which this kit can potentially deliver, but it didn't require any other modifications, and it is proven to be safe. If I will want more, there is still space to grow.
As for the performance - I don't have exact numbers for my install other than those questionable graphs from VD, but I do feel it in my daily commutes. Before I frequently felt like I wanted more power, but now the car already has more than enough to get me into troubles. The main goal is reached - it doesn't feel underpowered anymore!
The Following User Says Thank You to alpax For This Useful Post:
CSG Mike (10-27-2014)
Old 10-27-2014, 05:09 PM   #1073
CSG David
CSG David's Avatar
There are a few things being tested right now for those who are curious about additional power, but it won't be announced for quite some time until everything is 100% proven to be repeatable and when the tunes are completely refined. FYI, the CARB tune is a product of several hundred hours of tuning and testing prior to submitting to CARB and product release.
Old 10-29-2014, 06:09 PM   #1074
JerseyMike
Never posted on here but I ordered a JRSC last Monday and I'm patiently waiting for it to come in! I can't wait.
JerseyMike is offline   Reply With Quote
The Following 3 Users Say Thank You to JerseyMike For This Useful Post:
*LongFella (10-29-2014), JDMChris (10-29-2014), Xerious (10-30-2014)
Old 10-29-2014, 06:09 PM   #1075
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Welcome to the JR Family. You're going to love it!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
Old 10-29-2014, 06:12 PM   #1076
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
IKR? My kit is sitting in my closet waiting for my car to get out of the body shop D:
ScionOfHorus is offline   Reply With Quote
Old 10-29-2014, 07:33 PM   #1077
JerseyMike
I created a group on Facebook called FT86 Jackson Racing SC owners.
Old 10-29-2014, 07:34 PM   #1078
ScionOfHorus
Just applied.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
