Old 10-25-2014, 11:03 PM   #29
Erza_ft86
Drives: the raven frs
PLEASE HELP
While it's on flat ground can you grab the top of any of the wheels and rock it hard from the 10 and 2 o'clock positions? Do you feel anything loose or hear any knocking? Unloading the suspension actually loads up bushings and joints that might otherwise be loose. They get wedged in the unnatural state of fully extended linkages.
Does that make sense?
I just tried to rock it but everything felt solid and I didn't hear any noise at all. Do you think a loose lower arm would make some sort of noise?
Erza_ft86 is offline   Reply With Quote
Old 10-25-2014, 11:14 PM   #30
Not necessarily, because those joints are rubber or neoprene. If one is partially torn it would give more under a side load - like when turning.
...or I could be totally out to lunch.
Does it pull when you're braking?
Old 10-26-2014, 02:12 AM   #31
Do you have any pics of the damage?
When it pulls do you get any warning lights? The traction control and ABS systems are very sensitive too any variation in wheel rotation and should give a warning if something is out of kilter.
Old 10-26-2014, 09:04 AM   #32
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
This to me sounds like it could be a wheel bearing. I experienced this on my truck, which for some reason didn't have the "normal" grinding sounds, but when I switched lanes the truck felt like it got "wobbly" when the wheel travelled over the crown in the road separating the lanes, and generally felt like something was loose but I couldn't figure it out for the longest time. Then one day I jacked it up and noticed a super fine amount of play, had it replaced and voila no more issues. My two cents.
Gords_zenith is offline   Reply With Quote
Old 10-29-2014, 12:24 AM   #33
Updates, man. Updates!
Old 10-29-2014, 12:35 AM   #34
Erza_ft86
No It won't pull under braking unless the ground is really uneven but on flat surfaces it brakes fine. I went to the body shop that fixed my car to have them see if they missed anything and they can't figure it out so I have to wait now till Friday to take it to my regular alignment shop to see what's going on. The body shop said they couldn't give me a proper alignment because of my coilovers so I have a feeling they really didn't do too much. I have a printout of my alignment if u want to see if anything is off
Old 10-29-2014, 12:37 AM   #35
Erza_ft86
Yea when it starts to pull my traction control light will come on and I can feel it trying to kill the power. But the body shop can't seem to find anything wrong? There trying to tell me it's because I am running 255's all around and its grabbing every groove on the road, which is bull.
Old 10-29-2014, 01:10 AM   #36
I'm starting to think @dradernh was on point. No more armchair troubleshooting from me. Just really curious and hoping the best for you.
Old 10-29-2014, 12:32 PM   #37
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I agree with it sounding like the toe in the rear is off. Make sure the toe is IN and not out. As in the front of the rear tires should not be pointing away from the car. Toeing out the the rear will make the rear of the car want to step out.
Ranatsu is offline   Reply With Quote
Old 10-29-2014, 05:54 PM   #38
Erza_ft86
Here is a pic of the alignment that the body shop gave me.
Old 10-29-2014, 06:00 PM   #39
stugray
Drives: 2013 GBS BRZ Limited
You appear to have toe out on the right rear exactly as suggested above.
This would make the ass step out to the right on a left turn
Old 10-29-2014, 09:34 PM   #40
Pete156
I like to eat!
Last week you said you didn't have this! Had you posted this it would've been obvious.
You're welcome for the troubleshoot. Now start looking for bent suspension parts.
Pete156 is offline   Reply With Quote
Old 10-29-2014, 10:55 PM   #41
Back it up there, Skippy. You're welcome to reread. We'll be here awaiting your apology.
Old 10-29-2014, 11:33 PM   #42
Pete156
I like to eat!
I do not have a printout of the last alignment done from the body shop but I think it has to be something else that is going on
This is the part of OPs response I was referring to. Do you read it differently?
