Old 10-22-2014, 07:00 PM   #1625
DC2R
Drives: 2014 Scion FR-S
Originally Posted by lamune View Post
Is there a difference between removing Carhome via "factory.prop" and freezing Carhome (if you have root)??
If at all possible, I do want to go back to a custom launcher with resuming working fully. When I was testing, I had pretty sweet setup where the home button Apex, home in Apex went to Poweramp. When in PowerAmp, home went back to Apex.
Editing build.prop removes the overlay(screen with vertical rotary list of select apps) on top of launcher. Freezing the two CarHome apps allows you to remove the overlay and/or CarHome launcher í IIRC
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 10-22-2014, 07:00 PM   #1626
DC2R
Case by case basis of course, but a custom ROM can be loaded without custom recovery.
Yes i guess that's true. Was just going with a general approach.
Old 10-25-2014, 11:06 PM   #1627
Orisai
Drives: Hyundai ix45
Custom roms can be flashed without a recovery, but overall, it's much safer to do so from a recovery.
Orisai is offline   Reply With Quote
Old 10-26-2014, 04:22 AM   #1628
morgish
Drives: S13 Silvia
OBD2 USB ADAPTERS
People successfully using a USB OBD2, can you please list the make, model and settings required? Is any adapter better than the other?
I've read every post of this thread (Over some time) but hasn't seen any direct relation to a specific adapter.
Currently using the Ca-Fi mini Bluetooth adapter but would like something with a better refresh rate.
Appreciate all the time and effort everyone has put in so far, this thread has been brilliant.
morgish is offline   Reply With Quote
Old 10-27-2014, 12:55 AM   #1629
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Narcoden View Post
Using tech support via email sucks. It's taking almost a week to work through my problems. Currently my amp only turns on when I turn the head lights on. It is wired up correctly. There is something clearly wrong with mine and no offers from Ca-Fi to just replace the thing already. Everything I get an email, I have to respond and wait... Sometimes it's days before I get an email back. Do they have a phone number for support?
Sent from my Nexus 7
Have you asked Ca-Fi directly about either of things? If not, ask for a phone number number. If they say no, then ask for a replacement unit. The worst that can happen is they say no again and continue troubleshooting.
Prog is offline   Reply With Quote
Old 10-27-2014, 02:58 AM   #1630
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
They finally asked me to ship it back. I'm annoyed at how long this had taken so far. Plus it's going to take weeks to ship back, have them look at it, then either fix it or send a new one.
They will only reimburse the cost of doing it back if they find something wrong with it so I'm out of pocket what ever is going to cost me to send it back for a while.
So my car had been unusable for the past week because it's a pita to keep installing and removing the radio a few times a day to trouble shoot.
Narcoden is offline   Reply With Quote
Old 10-27-2014, 03:12 PM   #1631
Narcoden
Narcoden's Avatar
Wow, sending this back to Hong Kong cost $73. That was about the cheapest to send it back with a tracking number and insurance. Yikes.
Old 10-28-2014, 01:52 AM   #1632
Saaaaaad
Drives: Subaru BRZ 2014
Originally Posted by Mehster View Post
I had mine like this:
Does anyone know the part number of this bracket? or have a source where i could buy these brackets? My OEM brackets are different (Australian BRZ) and dont fit the ca fi unit. I may just grind down the bracket and drill in new holes, but wondering if there's a way to source these brackets.
Saaaaaad is offline   Reply With Quote
Old 10-29-2014, 09:11 PM   #1633
morgish
Drives: S13 Silvia
Originally Posted by morgish View Post
OBD2 USB ADAPTERS
After re-searching the thread, I've found examples of people using the ScanTool 425801 USB OBD2 adapter.
I also saw that someone was having trouble with this adapter and Torque. Anyone successfully using Torque with this adapter?
Old 10-30-2014, 12:25 PM   #1634
mkivsoopra
I have this setup and it works great. I had to fiddle around with some settings, but once setup, it's been super reliable.
mkivsoopra is offline   Reply With Quote
Old 10-31-2014, 12:06 AM   #1635
morgish
Drives: S13 Silvia
Awesome.
Are you able to post the settings?
Old 11-06-2014, 04:27 AM   #1636
petr
Drives: Mazda Miata
Hi!
Is there a way to freeze "USB" App that pops up and starts playing when you connect usb drive?
I didn't find it in Titanium Backup
petr is offline   Reply With Quote
Old 11-06-2014, 09:50 AM   #1637
jonzhuxD
Drives: Ultramarine FR-S
SU00301962 (RH Side)
SU00301963 (LH Side)
http://www.villagescionparts.com/pro...U00301962.html
http://www.villagescionparts.com/pro...U00301963.html
jonzhuxD is offline   Reply With Quote
Old 11-07-2014, 02:26 PM   #1638
Simok
Drives: 2013 FRS
What is the largest usb drive anyone has used with this? Or dose anyone know what it supports?
Simok is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
