Old 10-25-2014, 07:22 PM   #15
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Kill yourself
Kuros is offline   Reply With Quote
The Following 2 Users Say Thank You to Kuros For This Useful Post:
Plxdjake89 (10-25-2014), rs999 (10-30-2014)
Old 10-25-2014, 07:25 PM   #16
stugray
Drives: 2013 GBS BRZ Limited
The reason we weretelling you to stop driving it is because from your explanation, something is shifting while you are driving it AND it is doing it under relatively mellow conditions.
If instead you had said: "I got in an accident and after an alignment the car pushes a little on this one corner at the track" then that would be completely different.
If you actually DID get it up on jackstands and gave it a thorough going over, then it is probably safe enough to drive - carefully.
My mental picture when posting previously was that you were in a fairly major accident which caused damage to the suspension and you now had a steering component about to fail.
Old 10-25-2014, 07:49 PM   #17
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Originally Posted by Kuros View Post
Kill yourself
Lol
Plxdjake89 is offline   Reply With Quote
Old 10-25-2014, 07:56 PM   #18
Plxdjake89
Plxdjake89's Avatar
Originally Posted by Erza_ft86 View Post
Oh wow I guess I am a nub. Obviously driving the car is not a option
guy. Maybe you should let someone with at least a little bit of
knowledge post on what they think could be the problem instead of being a
tough guy thinking you are some kind of "pro" on giving people advice.
Thanks for wasting my time and yours.
I never said I was a pro, and I don't believe I'm preventing anyone from voicing their opinion.
Honestly, "forget about it."
sorry for being uninformative, but I just couldn't help but mess with you
Old 10-25-2014, 09:19 PM   #19
White64Goat
Game.......Set..........Match...........
Old 10-25-2014, 10:10 PM   #20
Thanks brotha yea I will keep everyone updated. I am pretty much fighting the wheel when the car starts to pull and push in the corner causing me to have a white knuckle grip. Hope it is nothing too serious.
While it's on flat ground can you grab the top of any of the wheels and rock it hard from the 10 and 2 o'clock positions? Do you feel anything loose or hear any knocking? Unloading the suspension actually loads up bushings and joints that might otherwise be loose. They get wedged in the unnatural state of fully extended linkages.
Does that make sense?
Old 10-25-2014, 10:50 PM   #21
Pete156
I like to eat!
Originally Posted by dradernh View Post
Rear toe waaaayyyyy out of whack is what comes to mind, but then that wouldn't cause a pull, it would be more of a 'push' and the car would be all but undriveable over 10-15 MPH.
+1
It doesn't take that much rear toe to cause these symptoms. My money's on this due to something bent. I also don't think the OP senses the difference between front end pull and rear end push. We'll see
Pete156 is offline   Reply With Quote
Old 10-25-2014, 10:50 PM   #22
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You're gunna need a new engine.
Oh this is the suspension sub forum; you're gunna need a new suspension. How's that for kinda suspension knowledge? Lol
It sounds like the front lower control arms are loose, and are only exaggerated the faster you go.
Old 10-25-2014, 11:21 PM   #23
Five bucks sez something like this. Torn control arm bushing? ...ish?
Old 10-25-2014, 11:43 PM   #24
Erza_ft86
Drives: the raven frs
Fuck it I'm going for it
Erza_ft86 is offline   Reply With Quote
Old 10-25-2014, 11:47 PM   #25
Hey, some of us are trying to help or at least are genuinely interested in the outcome. That would be really uncool of you to check out and leave us hanging.
Old 10-25-2014, 11:48 PM   #26
Erza_ft86
Yea it get bad when I hit about 70 mph but under that it seems ok. I was just cruising in the slow lane all the way back home from class
Old 10-25-2014, 11:51 PM   #27
Erza_ft86
I appreciate the people who really are trying to help and not just bored messing with people. I'm going to try and get my car to the alignment shop Monday if they have time for me
Old 10-25-2014, 11:57 PM   #28
Cool. Let us know. Good luck!
