Old 10-24-2014, 06:46 PM   #8723
Parappa
Parappa's Avatar
Drives: Scion FR-S White Out
Originally Posted by iStanley View Post
Tutorial?
I was planning on it...but my phone had no power when I started the install so I couldnt take photos. Here is a list of parts from ebay and some quick tips if it helps.
Ebay parts links:
Red LED Switches
http://www.ebay.com/itm/301310970001...%3AMEBIDX%3AIT
4 LED Strips
http://www.ebay.ca/itm/4x-30cm-Red-1...item4ac200de4b
Basics on wiring to cigarette lighter (He uses the same type switch)
[ame="https://www.youtube.com/watch?v=juvFWa6PcBo#t=273"]How to Install Multicolor RGB Footwell Kit from Diode Dynamics - YouTube[/ame]
How to access the cigarette lighter in the FRS center console
explains at 1:00 minute mark how to remove shifter ring trim
explains at 2:23 minute mark how to access cigarette power
[ame="https://www.youtube.com/watch?v=YYQaiv8n4es#t=160"]DIY: FR-S FT86 LED EL Illuminated Console Plate Installation - YouTube[/ame]
You will need a 3/4" spade bit to drill the hole....might have to carve it out a bit more to get the switch in.....this part took me the longest to line up the switch with the yo speed plate.
You can choose whether you want 1 or 2 switches. Wiring is still the same.
Tips for the switch
The center pole is the switch....the positive from the LED strip solders there.
The copper colored pole is for the ground. (splice ground from cigarette lighter and ground from LED strip and attach/solder here)
The silver pole at the opposite end is for power. (splice positive from cigarette lighter and attach/solder here)
You should pre solder or attach leads (wires) to your switch before you start.
Hope this helps...at least a little.....feel free to PM if you have any questions.
Parappa is offline   Reply With Quote
Old 10-24-2014, 06:47 PM   #8724
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
Originally Posted by Parappa View Post
I was planning on it...but my phone had no power when I started the install. Here is a list of parts from ebay and some quick tips if it helps.
Red LED Switches
4 LED Strips
Tips for the switch
The silver pole at the end is for power.
You should pre solder or attach leads (wires) before you start.
Wow this is great! Good mod for someone looking for something cheap and attractive.
iStanley is offline   Reply With Quote
Old 10-24-2014, 10:52 PM   #8725
kbye
kbye's Avatar
Drives: 2014 FR-S
Originally Posted by G-awesome View Post
Do you prefer the stock 2015 sharkfin design over any of the beatsonic sharkfins? I think the stock sharkfin is simple and clean but I kinda prefer beatsonic's designs for a bit a bit more styling on the sharkfin. I was thinking of ripping out the 2015 stock one for a beatsonic one instead.
Yes, in fact I bought a beatsonic antenna and changed my mind and put it on my wife's Impreza instead. It looks better on the Impreza than the FR-S, oddly enough. It was the FDA9 version.
kbye is offline   Reply With Quote
Old 10-25-2014, 01:45 AM   #8726
kbye
kbye's Avatar
Drives: 2014 FR-S
An update on the OEM sharkfin... I just did a test fit. It's 100% plug and play from 2015 -> 2014/13, despite what your dealers say.
The reason they might tell you it's not compatible is because they updated the part numbers on the entire harness from the antenna leading to the HU. But the connectors are exactly the same.
Of course this is for FR-S only, I do not know if the same thing applies to the BRZ which has satellite radio.
Old 10-25-2014, 09:02 AM   #8727
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Originally Posted by kbye View Post
Going to retrofit the 2015 sharkfin on my 2014 FR-S.
Test fitting it first to make sure it works, then going to paint match it. Sucks for SWP owners, Halo is much darker.
Might write up a DIY if I'm not lazy.
Do you have the part number by chance?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-25-2014, 10:52 AM   #8728
Datcrazyeric
gotta go slower
Drives: 2014 FR-S
If you referring to the shark fin park # I'd recommed just ordering from beat-sonic since it'll be cheaper. I work for a Toyota Dealership and even with my discount its high
Datcrazyeric is offline   Reply With Quote
Old 10-25-2014, 11:43 AM   #8729
LT
LT's Avatar
Drives: Raven FRS
225/45/17 hankook ventus s1 noble 2's.
Flappy Paddlez~
LT is offline   Reply With Quote
Old 10-25-2014, 12:09 PM   #8730
torranosaurus
Drives: 2014 FR-S
Looks good.
Did you lower it as well?
torranosaurus is offline   Reply With Quote
Old 10-25-2014, 01:16 PM   #8731
艾洛
艾洛's Avatar
Drives: Raven
Road trip! Attempting to enjoy the car as much as I can before the Winter snow enters.
艾洛 is offline   Reply With Quote
Old 10-25-2014, 02:08 PM   #8732
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
What did I do to my FR-S..??
Well I used the car to hang out with my buddy best use for a FR-S.
Old 10-25-2014, 02:31 PM   #8733
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
Nothing to the car itself, but i recieved my Tomei UEL header & keep on drooling all over it untill i can install it tuesday (hopefully)
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 10-25-2014, 02:46 PM   #8734
Datcrazyeric
gotta go slower
Drives: 2014 FR-S
Nothing yet but FINALLY received my clear sidemarker lights.
Knocking these out the second I get home.
Old 10-25-2014, 05:12 PM   #8735
torranosaurus
Drives: 2014 FR-S
Installing fourth brake led light.
Old 10-25-2014, 09:33 PM   #8736
LT
LT's Avatar
Drives: Raven FRS
Originally Posted by torranosaurus View Post
Looks good.
Thanks! Lowered on eibach sportlines and 20mm front and 25mm rear spacers.
Flappy Paddlez~
