Old 10-20-2014, 10:34 AM   #1149
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by s2d4 View Post
Good luck with that, haven't heard anyone with good experiences with MRT overlords by doing that.
Damn...yea I guessed so but was hoping otherwise.
Fizz is offline   Reply With Quote
Old 10-20-2014, 12:38 PM   #1150
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Fizz View Post
Silly question. Is it possible to install the intercooler without taking off the front bumper? There's a whole thread on guys ending up with ill fitting bumpers after removing it....apparently the sides doesn't line up perfectly once the bumper is re-fitted.
No, no way. and there are also threads out there showing how to fix the bumper if you should not get it to line back up perfectly (patience and ingenuity)
Old 10-20-2014, 08:45 PM   #1151
willharp360
Anyone with this kit running the Tomei 80r?
willharp360 is offline   Reply With Quote
Old 10-20-2014, 09:05 PM   #1152
Zenith/Nadir
Drives: 2013 GBS BRZ Limited
[ame]http://youtu.be/6qnWxlPtzH8[/ame]
Zenith/Nadir is offline   Reply With Quote
Old 10-20-2014, 10:34 PM   #1153
Skorov
Skorov's Avatar
Drives: 86 GTS White
Another question. If buying an AVO kit that includes a base map, all I'll need to get running is a license yea (I can borrow the cable from buddy)? Is the license country specific? I mean can I buy the license from the US and use it in Australia?
I plan to just run with the base map for time being, but if I want to tune it later on I would need to just pay for the cost of a tune, plus dyno time, yes?
And does anyone know if an Australian ecutek tuner is restricted from tuning a car that doesn't have local license?
Buy an overseas EcuTek license for a fair price and get your local tuner to tune use it. That's exactly what I did.
Just buy it and set everything up on a laptop, drive to tuner and leave your laptop with them while they work on your can.
Skorov is offline   Reply With Quote
Old 10-21-2014, 03:06 PM   #1154
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Would an upgrade to a 3 bar MAP sensor require adjustment to the tune right away or is it a simple exchange? Would like to have accurate boost readings with an option to go for more boost sometime later.
And yeah - I have the same problem with a bad aligned bumper. Does anyone have a link to where there are some proposals on how to fix that?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 10-21-2014, 03:10 PM   #1155
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
The tune would have to be adjusted for the 3bar map
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Flasher (10-21-2014)
Old 10-21-2014, 03:16 PM   #1156
AVOturboworld
Your car won't even start if you swap out the map sensor, as it uses it for the initial startup. Has to be tuned for.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 10-21-2014, 03:20 PM   #1157
AVOturboworld
Originally Posted by @Art_Mighty View Post
How much additional oil does the Stage 1 system hold. Also, how much is held by the AVO oil cooler?
With just the turbo kit, stick to the standard oil fillup.
With the oil cooler, you'll need a total of 6 liters (a bit over 6 quarts). Because the oil cooler thermostat plate doesn't open till it gets hot enough, you may need to fill it as normal on the initial install of the oil kit, then warm it up to get oil into the oil cooler, then top it off.
Old 10-21-2014, 03:46 PM   #1158
toast
Drives: 14 BSP Edelbrock BRZ
Questions for stage 1 kit. I want simple and am looking to run just the basemap. Since the stock map sensor only reads to ~5 psi and the kit is advertised as 6 what is controlling the boost, just the wastegate spring? Is there any kind of overboost protection in the basemap (and how does that work if the ECU can't see any more than 5 psi?) in case the hose blows off the wastegate or some other kind of catastrophe?
Also, did the people having problems with the exhaust leaks at the turbo and manifold find a solution? I saw a couple pics of failed turbo gaskets and then didn't see any more mention of it. Same thing with the failed manifold gaskets and the manifold flange warping.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
Fizz (10-23-2014), kbogarto (10-21-2014)
Old 10-21-2014, 07:18 PM   #1159
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I never really had problems with the manifold-head gasket, but I did blow out the turbo-manifold one. I quickly surfaced the flange with a file (more to clean up carbon than anything), and re-installed the turbo with a one piece stainless gasket (instead of the multi-layer steel that comes with the kit) and nordlock washers. Two track days later and the hardware has not backed off yet (which was the root cause of the issue), and remains tight.
FrX is offline   Reply With Quote
The Following 4 Users Say Thank You to FrX For This Useful Post:
Draco_PR23 (10-22-2014), kbogarto (10-21-2014), protpibe (10-21-2014), toast (10-21-2014)
Old 10-23-2014, 08:43 PM   #1160
babydriver
Hit the road and I'm gone
babydriver's Avatar
Hi, new to the forum and this is a long thread, so I apologize in advance if this has already been asked. Does this turbo kit require a different set of pistons? Years ago, a friend turbocharged a big block Mustang and went with 7:1 pistons (that's not a typo) to avoid detonation. How does the stock motor (12.5:1 CR) react to turbocharging? Are there issues with pre-detonation?
Old 10-23-2014, 09:23 PM   #1161
kbogarto
Drives: 2013 BRZ limited WRB
You don't need low compression Pistons for this kit but you need to retune your ecu to compensate for the turbo or you will blow your motor. AVO sells this kit with a ecu tune if you don't want to take it to a local tuner.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 10-23-2014, 11:08 PM   #1162
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Less compression makes it easier to increase boost without worrying about detonation as much. However there are new tools available on modern cars that make turbos more reliable and more effective. On old carbed engines the answer was low compression, large displacement, and biggest turbo you could find, then drive around with a screwdriver in your hand hoping it doesn't blow up. FI has changed the game in that respect, and the ECM suite on the FA20 has a ton of features that even sophisticated engines from the early 2000s didn't offer. Crank position resolution, direct injection, and better supporting and tuning mods (like widebands, MAP sensors, knock sensors, failsafe conditions, temp sensors, etc.) have made it possible to run silly amounts of boost on engines with very high compression.
That said, the FA20 clearly was not made for boost. LNF's in cobalt SS's have 9:1 compression with DI, but they also run 23psi stock. Most people with reliable FI on these engines seem to top out at around 14psi on pump gas, with some notable exceptions. E85, methanol, and race gas make it much easier to make more power safely. Plus these engines are still extremely new, and knowledge isn't in supply yet.
In the end, these days a modified engine is only as good as the person that tuned it. For every 400whp on 93 success story, there are a bunch of 250whp cars that blew up on the dyno that you may or may not hear about. Unfortunately, it's difficult to nail down who the good tuners are, and shops like to change names and addresses to purge their reputations.
Personally, I'm going to hold off until I find a local/semi local tuner with an excellent reputation, and I'm waiting for someone who has been running high boost for 10k-20k to post some blowby comparisons. As it is, people keep talking about stock engines with boost as a temporary condition and built engines as mandatory, and that makes Vorshlag's LS swap kit seem like a far better option.
Whatabouteggs is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
