Old 10-21-2014, 03:53 PM   #1
Darnold
Darnold's Avatar
Drives: 04' 400whp S2000, 01' DD S2000
Shifter springs/bushings/shifter performance
I'm looking to amplify my driving experience by changing out a few parts around the shifter and wanted to know others experience with SIMILAR configurations. I've read a lot of individual reviews but want to get a feel for pairing a set of springs/rear bushing and a short shifter together.
Currently looking at:
-MTEC shifter springs
-Perrin rear shifter bushing
-Kartboy short shifter
Thanks in advance!!!
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car)
Darnold is offline   Reply With Quote
Old 10-21-2014, 04:27 PM   #2
J.C.
Drives: '13 Raven FR-S
I have all three in addition to the Whiteline positive shift kit and the shifting experience improved immensely. Top it off with Motul 300 fluid in the tranny and diff and the shifts are straight buttery now. Shifts during cold mornings have also improved and are a lot less notchy.
J.C. is offline   Reply With Quote
Old 10-21-2014, 04:38 PM   #3
gramicci101
Off Topic
I have the MTEC springs, a rear shifter bushing, and the whiteline positive shift kit. And Motul 300 fluid.
The MTEC springs are wonderful! I can't say enough good things about them. They create a stronger return-to-center for your shifter, so now there are defined actions when you shift instead of amorphously going from 2nd to 3rd.
Rear shifter bushing and Whiteline trans insert help to better locate everything and keep it from moving around, so that's very helpful. I would also include the rear diff outrigger inserts. The OEM bushings are soft rubber and the diff flops around a lot when you shift or let off the gas sharply. You'll hear a *thump* when this happens. The diff outrigger bushings tighten that down a lot and remove a lot of the slop from the drivetrain.
Old 10-21-2014, 06:24 PM   #4
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I have the TRD "quick shift" kit. USA edition. It chimes with a shift bushing. I quite like it.
JohnJuan is offline   Reply With Quote
Old 10-22-2014, 09:43 PM   #5
Darnold
Darnold's Avatar
Awesome info, so as a whole your driving experience seems to have been positively amplified. I plan on changing the diff/trans fluid ASAP... With only 1000 miles second seems a bit rough of a transition even if rev matched properly.
Old 10-22-2014, 11:52 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Do you use the Motul 300 or 300LS?
Old 10-23-2014, 12:05 AM   #7
gramicci101
Off Topic
300. 300LS isn't good for the transmission, and 300 is fine for the diff. From what I understand, 300LS is for clutch-type limited slips, which we don't have. So there's no real benefit. @AZP Installs had a deal for four quarts of 300, which is enough for both.
Old 10-23-2014, 12:10 AM   #8
gramicci101
Off Topic
There is a little gear whine from all the stiffer bushings. You can only hear it if you're coasting in 1st or 2nd though.
Old 10-23-2014, 12:30 AM   #9
zooki
Drives: waiting on a 2021...
I have the exact combination as the OP with Pentosin as the fluid. Do it. Works awesome together.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Darnold (10-23-2014)
Old 10-23-2014, 12:43 AM   #10
Darnold
Darnold's Avatar
It's what in research looked to work but hadn't found a review and I don't like buying parts without knowing they compliment each other
Old 10-23-2014, 12:49 AM   #11
Cop
Cop's Avatar
Drives: 2013 FRS
I just install the TRD quickshifter a week ago and like it a lot. The throws are quite short but take a bit more effort than stock to get into gear. I may also put in the mtec springs at some point in the future since they seem to be universally liked.
Cop is offline   Reply With Quote
Short shifter, bushings, springs etc. - Does anybody have these? daiheadjai CANADA 8 05-05-2014 11:08 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 11:29 AM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 11:49 AM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 10:23 PM
