Old 10-22-2014, 06:12 AM   #71
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Awesome numbers, im shooting for mid 500's to low 600whp. How many psi did it take to reach 522? Also are these ID 1000cc?.
How do you like the 5858? Im assuming you went with the dual BB, 62 a/r ?
BRZGM3 is offline   Reply With Quote
Old 10-22-2014, 02:25 PM   #72
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
That's 24psi on a 10:1 motor. Journal bearing .82ar 5858. Full Blown 1000cc injectors
Turbo responds very well. Hardly any lag really. Once we get the trans sorted for next year we will probably move to 1600cc's and a 6266 turbo. For now, it's a handful
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 10-22-2014, 02:35 PM   #73
BRZGM3
BRZGM3's Avatar
So you're not using a return style fuel setup? What rpm do you hit full boost? Is there much left in that turbo? I know its rated to 620 but what'd your tuner think?
Thanks for the info, definitely helpful.
Old 10-22-2014, 05:02 PM   #74
spitfire481
Drives: 2JZ FRS
Stock fuel system with 1000cc port injectors and walbro 485 in tank pump
I'm not 100% on when it makes full boost. Anything over 3k rpm it will start spooling positive pressure. It's a handful to control right now so I'm not paying much attention to the aem haha.
I'd feel comfortable taking it to 30psi, but that's my safe limit with this motor. Atleast in my mind. If we keep this turbo, I'm sure it will need cams to open up the top end to make 600. Cams on another car at the shop made a big difference in spool, and peak power with much less boost
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
hmong337 (05-11-2015)
Old 10-22-2014, 10:19 PM   #75
BRZGM3
BRZGM3's Avatar
Good to know! My tuner is stuck on the idea that its unsafe to run past 20 psi with out a return fuel setup which isn't cheap.
Would you mind taking an in car video when ever you get the chance. Im having trouble finding many of these turbo's on our car especially pushing the power you are.
I bet its a handful lol, mine at 406whp 323tq was a ton of fun.
Ive got ID1000cc, dw 65 fuel pump, journal bearing Garrett 60 trim ( needs to be replaced ) flex fuel, an a tiny invidia N1. She put down 406hp at 16-17 psi. Then the rod bent due to water.
So now i have 10.5:1 built short block, ferrera +1 intake / exhaust, dual rate springs porting ect. The built heads are from Element tuning. 3" turbo back exhaust, and hopefully a better turbo. We didn't do cams because im running out of money lol. The stock cams are pretty good with the vvti so just the big valve package.
I appreciate all the feedback!
Old 10-23-2014, 03:21 PM   #76
TWMPerformance
Drives: Manual Transmission, All the Way!
Serious build. Car looks super aggressive.
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 11-13-2014, 05:07 PM   #77
spitfire481
Drives: 2JZ FRS
Rear subframe bushings, billet rear toe arms, Cusco engine mounts, and this lexus m85 3.73 rear diff go in this weekend.
Fresh coat of por15 rust paint to seal it up
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
chanomatik (12-02-2014), yourboyvic (12-09-2018)
Old 11-17-2014, 05:09 PM   #78
RedAlert
RedAlert's Avatar
Drives: Scion FR-S Firestorm Red (manual)
Damn, nice. I remember when breaking 300 was a big deal.
Originally Posted by spitfire481 View Post
I'll just leave these here for now
RedAlert is offline   Reply With Quote
The Following 2 Users Say Thank You to RedAlert For This Useful Post:
Mr. (12-06-2014), Pure Automotive (11-17-2014)
Old 11-17-2014, 06:04 PM   #79
艾洛
艾洛's Avatar
Drives: Raven
This thing is Rad.
艾洛 is offline   Reply With Quote
Old 12-01-2014, 11:49 PM   #80
spitfire481
Drives: 2JZ FRS
Bring on the beef
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
chanomatik (12-02-2014), Kris86 (06-29-2016), Mr. (12-06-2014)
Old 12-02-2014, 02:16 PM   #81
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Awesome build spitfire, cool to see the changes to your car in person and here
Marcoscrdo is offline   Reply With Quote
Old 12-07-2014, 02:57 PM   #82
spitfire481
Drives: 2JZ FRS
750hp 5" thick intercooler, new shorter hot side piping, 3" intake with huge filter behind apr brake duct vent
MoTeC
Build Thread
@spitfire481
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
IBill4You (06-26-2015), Pure Automotive (12-08-2014), Sportsguy83 (11-30-2016), yourboyvic (12-09-2018)
Old 01-24-2015, 03:51 AM   #83
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Love the build!
carlossanchez89 is offline   Reply With Quote
Old 03-08-2015, 10:47 PM   #84
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Good looking, which paint did you use for head light and tail light? If you remember how many coats?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
God's Build GodSays Member's Car Journals 13 04-17-2013 02:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 06:52 PM
